which is more dangerous for PC on 12V rail : 11.5V or 12.5V ?? - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 12-22-2018, 11:06 AM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
first question of its kind so no point googling ^^
question's in the title
so everyone saying that if voltage (especially 12V rail ie. the important rail cause all the precious stuff is fed by this one) is unstable & strays too far from base then it's dangerous
so too much voltage is dangerous (understandable)
but too little voltage is also dangerous (go figure but hey if they say so)
so my question is: for a GIVEN difference - says, 0.5V - which is more dangerous (say, for GPU or CPU): 0.5V less or 0.5V more?
pulverizor is offline
post #2 of 24 (permalink) Old 12-23-2018, 05:11 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1448 (Unique: 730)
Most dangerous? Neither will cause things to explode and hurt you... so neither?
Droop will cause instability, overvoltage might damage parts.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #3 of 24 (permalink) Old 12-23-2018, 05:56 PM
Still here...
iamjanco's Avatar
Rep: 147 (Unique: 66)
Version 2.2 of the ATX Specification specs the following about +12VDC:
Voltage Rail	Tolerance	Minimum Voltage	Maximum Voltage
+12VDC		± 5%		+11.400 VDC	+12.600 VDC
While the ATX spec is an older spec, Intel's Desktop Platform Form Factors Power Supply Design Guide (Rev 002, dated June 2018) agrees with those tolerances (at peak loading times):
Like The Pook implied though, always best to try to stay as close to a spec'd voltage as possible.
iamjanco is offline
post #4 of 24 (permalink) Old 12-23-2018, 06:37 PM - Thread Starter
pulverizor's Avatar
Rep: 0
I of cos meant dangerous for lifespan of the PC not of the user :|
so 12.5V damages & shortens components lifespan (CPU, GPU) more than 11.5V does?
you sure??
(if the voltage difference ain't that high then I can reformulate the question: 11V vs 13V which is more dangerous? ^^)
post #5 of 24 (permalink) Old 12-23-2018, 06:45 PM
High Clocker
bmgjet's Avatar
Rep: 192 (Unique: 166)
They are still the same sort of dangrous.
Lower voltage is going to draw more current (fry traces, plugs, wires) or straight out unstable.
Higher voltage will damage parts. Its going to be closer to 15V before you start having instant frying of stuff since the voltage regulation circuits are going to use 15V capacitors at a minimum on your 12v stuff.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #6 of 24 (permalink) Old 12-23-2018, 06:47 PM
9 Cans of Ravioli
The Pook's Avatar
A good PSU will shut down before it hits 11v or 13v, but I've never heard of lack of voltage killing anything. If you run your CPU at 1.0v it'll likely BSOD and be unusable but at 2.0v you'll just kill it. Can't imagine a PSU or any other component being any different.
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
WD Blue 4TB SSD
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Keyboard
Mouse
Logitech G603
The Pook is offline
post #7 of 24 (permalink) Old 12-23-2018, 06:55 PM
High Clocker
bmgjet's Avatar
Cant really compare it like that since thats the voltage supplied by the internally regulated circuit inside CPU to the cores, The damage will happen before the regulators inside the component.
Easier way to understand why low voltage will damage is because if something needs 300W say the GPU before it goes though its VRMs to supply that voltage the cores want.
300W with 11V rail thats 27.3amps
300W with 13V thats 23.1 amps.
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #8 of 24 (permalink) Old 12-23-2018, 06:59 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
In my job usually sell computers with VERY cheap ass power supply that in some cases exploded on the first power on lol.
Overvoltage can kill the hardware. I see some cheap ass PSU with 14.0V on the 12V+ killing a motherboard in 1s and in some cases also damage the CPU and RAM. Undervoltage usually after sometime melt connectors because increase the current, but I never see dead hardware for this problem, just the CPU power connector melted, replace the connector and the motherboard work just fine.
Ripple is also very bad for the components, specially capacitors. I see some PSU with severe ripple making pop corn of a motherboard
Ryzen 9 3900X/2X16GB DDR4-3733@CL16/X570-I AORUS/RTX 2080 GAMING OC/IN-WIN 301/EVGA 850W
Heatkiller REV3.0+DIY AM4 Adapter/1X120+1x240mm/DDC3.25+EK DDC Res
lexer is offline
post #9 of 24 (permalink) Old 12-23-2018, 08:06 PM
Overclocker
JackCY's Avatar
Rep: 364 (Unique: 261)
115V and 125V are both dangerous.
You're fine as long as the 12V rail is within spec as mentioned above.
High voltage can kill capacitors and FETs. Say around 16V, depends largely on parts selection and their rating.
Say your GPU consumes 240W = 20A and 12V. At 11V that is 21.82A, it's not going to melt your connectors At 6V... at which it would not run probably anyway but for theoretical purposes lets say it still does... it would draw, if it could even keep up the full 240W power draw (often power draw goes down with lower voltage), 40A, then sure it can melt things if the card was designed for say 25A max (300W at 12V).
Why are PCs still using 12V and not 24V or higher? Beats me, mostly because of legacy probably.
JackCY is offline
post #10 of 24 (permalink) Old 12-23-2018, 08:07 PM
white owl's Avatar
Rep: 136 (Unique: 103)
If you feed something less voltage and it's able to have the same output with said voltage, ohms law says it must be pulling more current to make up the difference. I'm not sure it this applies to the PC or not since the components do not feed directly from the PSU, the power is stepped up and down. I'm not sure what it's called but there are little chips that can regulate output and keep it the same even if the input voltage drops, this will cause it to draw more current. If the VRM is fed by something like this I don't think too little voltage will harm the CPU or VRM as it will be getting the same power either way but I'm not a rocket doctor and I don't know exactly how much bucking/stepping and filtering the 12v power goes through before reaching the VRM.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
