UPS online vs line-interactive : BATTERY LIFESPAN differences? - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 12-31-2018, 02:08 PM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
simple question but unable to get a clear answer by googling
is is true that the batteries of line-in UPS always have much shorter lifespan then the batteries of online (more expensive) UPS?
and if so WHY?
pulverizor is offline
post #2 of 16 (permalink) Old 12-31-2018, 02:22 PM
AllenG's Avatar
Rep: 25 (Unique: 22)
The lower end ones click in fully whenever the voltage goes out of range, fully using the battery itself and dropping off the actual power line. The on-line ups's only draw what they have to from the battery system, to make up the difference. Unless power is fully gone, in which case it is the same.
i7 990x @ 4.69GHz
Asus Rampage III Extreme
EVGA GTX780 FTW ACX 2.0 3GB
12 GB Samsung DDR3L @ 2100Mhz
Samsung 840 Pro 256gb Raid0 On LSI 9207
Samsung 840 Pro 512gb
PSN across 10Gb Fiber
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
DTek Fuzion V2 CPU Block w/ Quad Insert
Laing D5 pump {2MT}
2 x Black Ice Pro 240 Radiators {2MT}
EK Full Cover RIIIE Nickel/Acetal Block
Lian Li PC-A10B
Operating System
Windows 8.1 Enterprise X64
Monoprice 27in WQHD IPS
Keyboard
Das Keyboard Model S
Audio
Creative X-Fi Fatal1ty Platinum
Other
LSI 9207-8i SAS6G Raid Controller
Other
Intel XF SR 10Gb Fiber Adapter
Pentium G3258 @ 4.5GHZ
MSI PC Mate Z97
EVGA GTX 970 SC ACX2.0 4GB
8GB Mushkin Blackline DDR3 2133
256 GB Plextor M6 SSD
WD Black 640GB Raid0
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Windows 10 Enterprise x64
Changhong 42in 1080p TV
Keyboard
HP Wireless Keyboard & Thumb tracker
Mouse
Audio
Creative Sound Blaster X-Fi Fatality
Intel Xeon x5687 @ 3.6GHZ
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
24GB Hynix DDR3 1333 2R-X4 ECC
Samsung 850 Evo 500GB
Seasonic S12II 620W
Intel LGA1366 HDX Cooler for Extreme Edition CPU
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #3 of 16 (permalink) Old 12-31-2018, 03:30 PM - Thread Starter
pulverizor's Avatar
Rep: 0
that's the offline UPS you're talking about (aka. standby UPS) not line-interactive
there's 3 types of UPS:
- offline (the low end cheapest)
- line-in
- online (most expensive)
we already know that batteries of both online & line-interactive UPS last longer than those of offline UPS
same for the line-interactive ones they too can regulate voltage without using the battery
hence my question: do batteries from online UPS also last longer than those of line-interactive (not offline) UPS?
and if so why?
post #4 of 16 (permalink) Old 12-31-2018, 04:17 PM
AllenG's Avatar
Online UPS's do constant inversion, they bring in the AC, convert it to DC through the battery circuit, then dump back out to AC. Effectively the online ups batteries are in constant use at their topped off point. The line interactive clicks in just like an offline does but doesn't always switch to full battery, it does not do the AC-DC-AC conversion so it is not constantly using the batteries. The batteries are topped, and sit, with periodic cycling and re-topping. Batteries don't like to sit, ones that are constantly used but kept within their top 75% of charge will exhibit longer life cycles... why the online lasts longer. The real battery life in a full power out situation is about the same for all of them though. If you have a generator system that switches in and maybe cant quite keep the load voltage at 120, the online is also awesome as it will make up the difference down to ~70V, but not kill the UPS. Allowing you to keep more voltage sensitive equipment like servers online with barely or not enough power available. Most line interactive and offline at ~90V drops the ac line and switches to full battery.
As far as i'm concerned personally, the line-interactive systems don't exist. I'd go straight to Online if these were needs for my situation. Otherwise, the offline will do just fine and expect to replace the batteries. It's cheaper in the long run.
i7 990x @ 4.69GHz
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
Laing D5 pump {2MT}
Lian Li PC-A10B
Operating System
Keyboard
Audio
Other
Other
MSI PC Mate Z97
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Keyboard
Mouse
Audio
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
Seasonic S12II 620W
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #5 of 16 (permalink) Old 12-31-2018, 10:09 PM - Thread Starter
pulverizor's Avatar
Rep: 0
k thx for the info I didn't know that batteries dont like to "rest" at full (I always thought the opposite)
a few more questions then ^^
1) wouldn't a simple solution be for the line-in UPS to stop the charging when the battery's at 80% or something? the effective capacity & autonomy would be lower in case of power outage but the battery would last longer
2) for the online this means the battery's being charged & discharged at the same time? I didn't know that was possible for a battery (so this means online UPS batteries are special & can't be used in a line-in UPS or vice-versa?)
3) what about brown-outs don't line-in UPS protect the PC better then offline UPS against brown-outs?
4) also battery output ain't it (usually) better quality in line-in UPS? at least higher end ones (high end line-in UPS => true sine wave but any offline UPS only spits out stepped sine wave which iirc can be dangerous for some PSU's)
and finally...5) if a UPS is of the online type does it by definition automatically imply that it outputs sinewave? or can there be such a thing as an online UPS with only stepped sine wave (eg. iif the manufacturer wanna save costs)
post #6 of 16 (permalink) Old 01-01-2019, 02:37 PM
AllenG's Avatar
1. That is not quite the same as constantly working within that upper 25%, as you said it would just be worse for its main use case and still wouldn't change the battery life.
2. This is true, you will see most of the offline and line-interactive use the same battery packs. Their systems for attaching to the line are basically the same between those two. Online ups's have different batteries that are quite a bit more expensive, and work on a different line attachment system.
3. The line interactive will hold the voltage up to a steady 120V the whole time. In reality though, most of our stuff will function perfectly fine down to about 92V. This is what makes me not bother with line interactive and go straight for the offline or online ups's. In a situation where the voltage drops out of range, the line interactive and the offline are equal. Let the AC supply line run down to out of range voltage before even bothering with my offline ups (i set mine ~98v switchover), the line interactive will be draining itself before that point already.
4. I'll say the quality of battery is directly linked to mfg specifications. A good offline will use the same batteries as the line interactive, it will also generate a sinewave that is perfectly usable (over-hyped issue). If your PSU blows or has a problem with either of these issues (sinewave within range, or voltage sensitivity within spec range) then chances are the PSU deserved it and was well below specification ranges. The only thing that could be sensitive to this is some older analog equipment... which is why we required Online UPS systems back in the day in older data, switching, signal, and audio centers. In this case, the line-interactive MAY buy you some extra use, but that's already a use case where if you are looking at anything other than Online you are wasting your time anyways.
5. By nature of their design, most online type try their hardest to emulate a purer sinewave as their main job is to make everything see literally no difference between line power. That isn't to say that buying a cheap no name "Online" UPS might possibly net you a line-interactive masquerading as "Online". Rule of thumb, stick with companies that are dedicated to power backup systems.
i7 990x @ 4.69GHz
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
Laing D5 pump {2MT}
Lian Li PC-A10B
Operating System
Keyboard
Audio
Other
Other
MSI PC Mate Z97
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Keyboard
Mouse
Audio
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
Seasonic S12II 620W
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #7 of 16 (permalink) Old 01-01-2019, 02:58 PM
High Clocker
bmgjet's Avatar
Rep: 188 (Unique: 162)
I use a online UPS with 2 pairs of 6 batterys in series as a poor mans power wall. Had the batterys going for 2 years now and no issue.
I mainly got a online UPS tho so I could tie my solar pannels into the battery pack since its always charging and then inverting the power back to AC.
So the charger turns its self off for a few hours when there is a good ammount of sun and the UPS is wired up to 80% of the house so all the important stuff still works when there is a power cut which is common where I live.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #8 of 16 (permalink) Old 01-01-2019, 03:09 PM
AllenG's Avatar
Cool and smart little setup you got there bmg!
i7 990x @ 4.69GHz
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
Laing D5 pump {2MT}
Lian Li PC-A10B
Operating System
Keyboard
Audio
Other
Other
MSI PC Mate Z97
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Keyboard
Mouse
Audio
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
Seasonic S12II 620W
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
post #9 of 16 (permalink) Old 01-01-2019, 05:18 PM - Thread Starter
pulverizor's Avatar
Rep: 0
thx² for the info
1- so basically a battery has to *work* to last longer?!? (that's counter intuitive that's like a car wearing down faster if kept in the garage) how is that possible??
5- but can a true online UPS still have a false/stepped sinewave output (theoretically)?
post #10 of 16 (permalink) Old 01-01-2019, 06:04 PM
High Clocker
bmgjet's Avatar
A car does wear down faster if its not used vs one thats used daily but maintained.
Sticking with using car as a example. Sitting in the garage the oil doesnt get pumped around, all the bearings sit still and things start to rust up.
Where if you use it daily you dont get that rust building up.
Batterys are the same they need use, That cycling is part of the maintance.
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
