Dumb Upgrade Question? - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 01-02-2019, 11:30 PM - Thread Starter
SDBolts619's Avatar
Rep: 8 (Unique: 8)
I currently have a 3770k based system and am moving to a 9900k. In looking at the manual for the motherboard I ordered (Gigabyte Aorus Ultra), I see an additional 12v ATX 2x2 connector that my current board doesn't have.
My current PSU is a Silverstone Strider ST-1000P, which has been good to me and I was planning to reuse. There isn't a dedicated 12v 2x2 connector on the PSU. However, I have an unused EPS / ATX 4x2 port on the PSU. I presume I can utilize this port and make a new cable that has the 4x2 connector on one side and the 2x2 connector on the other side to use here? I have pinouts for the new motherboard and PSU, so getting this straight should be pretty easy unless I'm missing something.
Side note - I don't see an ATX4P connection on the new motherboard. I'm guessing that these are unnecessary with the newer motherboard being able to provide sufficient power to the PCIe slots?
Blue Raven
(19 items)
Core i9 9900k
Gigabyte Z390 Aorus Ultra
EVGA GTX 1080 Ti FTW3
Corsair Dominator Platinum
Samsung 970 PRO NVMe PCIe M.2 2280
Samsung 860 EVO
Samsung 850 EVO
WD Caviar Green
Optical Drive
Samsung Writemaster DVD/RW
Silverstone Strider PS-ST90F-Ti
Swiftech H220
Silverstone Raven RV02-EW
Operating System
Windows 10
Asus ROG PG348Q
Keyboard
Corsair K95 RGB
Mouse
Corsair M95
Mousepad
Corsair MM300
Audio
Steelseries Arctis 7
Other
Razer Orbweaver
SDBolts619 is offline
post #2 of 11 (permalink) Old 01-03-2019, 12:09 AM
Senior OCN Member
First off your old PSU is 8 years old so its long out of warranty and second its not very good anymore and its way overkill as well so dont re-use it get something new
The 12v rail on your PSU is not all that bad but the 5v and 3,3v are not all that good and the voltage regulation is around 3% and has around 40mv ripple at full load where ATX max is 50mv
A good 650 watt is more than enough power if you are not messing around with volt mods or have more than one GPU
And last the second EPS is only for extreme overclocking and by extreme i mean OC you use LN2 and liquid helium for so you dont need to use it
Edit: your PSU also has pretty low efficiency so buying a even a gold rated 650 watt would be cheaper in electricity
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #3 of 11 (permalink) Old 01-03-2019, 08:43 AM - Thread Starter
SDBolts619's Avatar
Rep: 8 (Unique: 8)
I did check out the efficiency calculators for PSU's and they showed that if I moved to a Platinum level PSU, I'd save about $20 per year. I'm not really inclined to spend $200 to save $20 per year since the recoup time on the investment is 10 years. As well, I made and sleeved all my own cables for my ST-1000-P, so going to a whole new PSU would likely mean making new cables, which is a time investment I'd rather avoid.
In regards to the EPS thing - the issue is that the new mobo has a 4x2 ATX 12v connection, which I have on my current system, but also has a 2x2 ATX 12v connection, which I don't currently use. I was planning to use the open EPS 12v 4x2 connection on the PSU to supply power to the 2x2 ATX 12v connection on the mobo.
AFAIK, 12v is 12v whether it's officially and ATX or EPS designated port, correct?
Blue Raven
(19 items)
Core i9 9900k
Samsung 860 EVO
Samsung 850 EVO
WD Caviar Green
Optical Drive
Swiftech H220
Operating System
Windows 10
Asus ROG PG348Q
Keyboard
Corsair K95 RGB
Mouse
Corsair M95
Mousepad
Corsair MM300
Audio
Other
Razer Orbweaver
post #4 of 11 (permalink) Old 01-03-2019, 08:54 AM
Packet Pusher
Renegade5399's Avatar
Rep: 230 (Unique: 145)
One of those 8 pin EPS connectors should come apart into (2) 4 pin connectors. To answer your question though: your extra connector will work. One set of 4 pins will plug into the mobo as they are keyed.
Whether or not you are using liquid helium, it's good practice to connect that. More pins to carry the current means less heat and less stress on the 8 pin. It's not like those pins are only drawn from in certain conditions or something.
Your current PSU, while older as mentioned above, will work just fine for what you need to do.
My Sauce Is Much 13373|2 Than Yours
What's in your hardware wallet?
[Gigabyte Aorus 1080 Ti Owner's Club]
Project Blackout
(24 items)
i9 7900X Delidded
ASUS TUF X299 Mark 1
EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING
G.SKILL Trident Z Royal Series 16GB - Samsung B-die DDR4 4000
G.SKILL TridentZ RGB Series 16GB - Samsung B-die DDR4 4000
4x 1TB Western Digital Black
2x 480GB Kingston HyperX Savage SSD
2x ADATA Ultimate SU800 1TB 3D NAND
Intel 660p Series M.2 2280 1TB PCI-Express 3.0 x4
INTEL® RAID ADAPTER RSP3DD080F
2x 2TB Western Digital Green
CORSAIR HX Series HX1000
Custom Water Cooling Setup
Bitspower MonoBlock ASX299TUF RGB-Nickel
Thermaltake Core X71 Tempered Glass Edition Black
Operating System
Winders 10 Pro 64bit
Pixio PX276h 27"
Acer GN276HL 27"
HP EliteDisplay E222 22"
Keyboard
Corsair K95 RGB PLATINUM - Cherry MX Speed - Gunmetal
Mouse
HP Omen Reactor
Mousepad
Corsair Gaming MM800 RGB Polaris
Audio
Sades SA926 Gaming Headset
Renegade5399 is offline
post #5 of 11 (permalink) Old 01-03-2019, 09:06 AM - Thread Starter
SDBolts619's Avatar
Rep: 8 (Unique: 8)
Thanks Renegade! I'll definitely make use of that open 12v port on the PSU then.
Update - Just to be 100% certain, I spoke to a really helpful guy at Silverstone - my plan to use that EPS port is no problem at all. As well, if I decide to upgrade to a newer Platinum level Strider series PSU, the cables used are all the same, so that removes any concerns about needing to do new cables.
Since I'm a little OCD on this stuff, I'll make a new cable from scratch to match the ones I made for the build initially:
Blue Raven
(19 items)
Core i9 9900k
Samsung 860 EVO
Samsung 850 EVO
WD Caviar Green
Optical Drive
Swiftech H220
Operating System
Windows 10
Asus ROG PG348Q
Keyboard
Corsair K95 RGB
Mouse
Corsair M95
Mousepad
Corsair MM300
Audio
Other
Razer Orbweaver
post #6 of 11 (permalink) Old 01-03-2019, 09:37 AM
ACleverName's Avatar
Rep: 12 (Unique: 11)
Sigh i look at your beautiful cable management and i think of my rats nets of cables
As for 500 watt range what would you guys recommend for a highly efficient power sup?
Just Roll With It
ACleverName is offline
post #7 of 11 (permalink) Old 01-03-2019, 09:44 AM
Packet Pusher
Not gonna lie, chubbed a little.
Project Blackout
(24 items)
i9 7900X Delidded
Operating System
Pixio PX276h 27"
Acer GN276HL 27"
Keyboard
Mouse
HP Omen Reactor
Mousepad
Audio
post #8 of 11 (permalink) Old 01-03-2019, 09:55 AM
Packet Pusher
This one actually has really, really good voltage regulation:
https://www.newegg.com/Product/Produ...-038-_-Product
Pricey for the size, but it can be relied on.
Project Blackout
(24 items)
i9 7900X Delidded
Operating System
Pixio PX276h 27"
Acer GN276HL 27"
Keyboard
Mouse
HP Omen Reactor
Mousepad
Audio
post #9 of 11 (permalink) Old 01-03-2019, 10:36 AM
Senior OCN Member
Most SilverStone units are mediocre at best and crap at worst and many of the newer units are just as bad if not worse then your old PSU
Yes you could re-use the cables but if a new PSU that can use the old cables is worse you are making a downgrade not an upgrade
The lower models of the Strider Titanium just to name one are some of the worst PSU´s money can buy today
The 1100 watt and 1500 watt models are okey but the lower ones are junk
To be honest you are much better off with a Seasonic Focus Plus or a Prime Ultra if you are going to buy a new PSU
You can have custom cables made for those if you want that
Edit: as for that NZXT its a modified Seasonic Foucs or Prime (cant recall) with some digtal gimmick added and its overpriced
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #10 of 11 (permalink) Old 01-03-2019, 11:35 AM
Newb to Overclock.net
mouacyk's Avatar
Rep: 167 (Unique: 124)
Wow, is that a functioning original H220 expandable liquid cooler? My pump gave up right after warranty period, but since then I've re-purposed its parts into a custom loop. I'd keep an eye on it, because the pump tends to get stuck when the block gets hot.
CPU: Q6600 X5470 2100T 1680V2 9900K
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is offline
