Low Watt PSU for 24/7 Build - Overclock.net - An Overclocking Community
post #1 of 17 (permalink) Old 01-06-2019, 01:54 PM - Thread Starter
JMattes's Avatar
Rep: 76 (Unique: 69)
Looking for a brand and model recommendation for a low end hdd server build.
It will run an i3 processor, 4-5 hdds and a few fans.. i dont think ill put a low end gpu in but having that option would be bad.
Need something solid that can run 24/7 and be efficent.
Thanks in advance!
Laundromatic - Feb 2012 TC Champs!
Laundromatic - July 2012 TC Champs!
JMattes is offline
post #2 of 17 (permalink) Old 01-06-2019, 02:15 PM
speed_demon's Avatar
Rep: 79 (Unique: 66)
Price range?
speed_demon is offline
post #3 of 17 (permalink) Old 01-06-2019, 03:52 PM - Thread Starter
JMattes's Avatar
Quote: Originally Posted by speed_demon View Post
Price range?
I was hoping on the cheaper side.. $50-100.. dont see a huge need to by a 350-550w platinun for $200..
Id love to spend $30 but i am sure thats a pos bronze.
Right? Lol
JMattes is offline
post #4 of 17 (permalink) Old 01-06-2019, 04:05 PM
Budget power supplies can vary from junk to decent quality. It depends on the particular product.
This EVGA 650 G3 power supply is quite a bit over powered for your needs, though it comes highly recommended https://www.amazon.com/EVGA-Supernov...eywords=650+g3
post #5 of 17 (permalink) Old 01-06-2019, 04:27 PM - Thread Starter
JMattes's Avatar
I think we're on the same page. Was going to ask if the EVGA SuperNOVA 550 G3 was ok. I can get it to MC for $80 and I got store credit so its a win win. For $10 more i can get the 650
Is the extra 100watts needed? I guess its future proofing incade i use it for something else..
JMattes is offline
post #6 of 17 (permalink) Old 01-06-2019, 04:39 PM
professional curmudgeon
looniam's Avatar
Rep: 792 (Unique: 451)
extra 100 watts? (only?)
that won't even use 100 watts under full load.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #7 of 17 (permalink) Old 01-06-2019, 05:41 PM
Expand Always in Always
reezin14's Avatar
Rep: 616 (Unique: 458)
I'd go the in-store credit route if it helps save $$. I personally have SeaSonic Focus 450FM running in my server, brought a molex sata extension to hook-up more drives. The EVGA 450 BT 450W(Bronze) can be had for $30 on NE right now. There's also the Corsair VS450W(80+) for not too much more. If you look around on the usual site's I'm sure you can find a good deal on a quality PSU.
I run 4 x 3TB IronWolf hdd's, x2 SSD's an i5 and 16gb's of ram on Win Server Essentials 16 and I doubt at any time I use more than 150 to 250 watts. Although I never measured it... I should, I have the equipment to do so.
EDIT: Just tested it out with the above components(Monitor included) startup was 72Watts down to 47 to 50Watts when idle. Streaming while sending a 3.2GB file + one VM running raised it up to 55Watts. So that should give you some indication of the power usage. BTW test was run with a KILL-A-WATT meter. Great call LOONIAM
BP v2
(17 items)
Ryzen 1700
Asus ROG Strix 350-F
Sapphire RX nitro 480 8GB
Crucial Ballistix sport 32GB
x2 Intel s3500 240GB
x2 Intel s3500 600GB
Intel s3500 300GB
SeaSonic Focus 650
Fractual Design S24
Anidees Crystal Cube Lite
Operating System
Win 10/Fedora 28 WS
LG 29UM68-P
LG 24in
Keyboard
Drevo Calibur 71 RGB wireless(Blacks)
Mouse
Logitech G703
Audio
Klipsch R-14/15PM - 10in Sub
Audio
ATH M40x/ Phillips SHP9500S
reezin14 is offline
post #8 of 17 (permalink) Old 01-07-2019, 12:22 AM
Senior OCN Member
shilka's Avatar
Rep: 2748 (Unique: 1629)
The EVGA BT450 is junk and you dont want one of those
https://www.overclock.net/forum/31-p...vga-bt450.html
The Corsair VS are not much better so none of those are quality units
As for the EVGA G3 nothing wrong with those other then they are loud when used in eco mode
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #9 of 17 (permalink) Old 01-07-2019, 03:17 AM - Thread Starter
JMattes's Avatar
I will stick with the G3.. either the 550w or 650w.. even if i throw a 1080ti in there I think the 550w is enough.. no sli for me
JMattes is offline
post #10 of 17 (permalink) Old 01-07-2019, 03:29 AM
Senior OCN Member
shilka's Avatar
The Seasonic Focus is cheaper than the G3 in most places
You can get the semi modular 550 watt for $60 on newegg with rebate and the fully modular 550 watt for $75 with rebate on newegg
The G3 is $80 on newegg with rebate
https://www.newegg.com/Product/Produ...-095-_-Product
https://www.newegg.com/Product/Produ...-203-_-Product
https://www.newegg.com/Product/Produ...-189-_-Product
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
