Converting a PSU to a testbench - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 01-07-2019, 11:52 PM - Thread Starter
PC Enthusiast
Norlig's Avatar
Rep: 118 (Unique: 108)
Hi,
I recently got a "broken" PSU out of an HP computer, from work.
The fan had stopped working, I will just replace the fan.
I tested the PSU and it does output the proper voltages.
However, I am wondering about one thing:
The PSU has 2x 12V 16A rails, which together can output a maximum of 240w.
Can I splice these 2 rails into one on the output side, or is that a bad idea?
Thanks
Main Rig: Asus Strix X299-A , Intel Core i7-7800x @ 4.8Ghz, 32GB Corsair Vengeance 3200Mhz CL16 , Asus Geforce GTX 1080ti FE, Corsair RM850i, Samsung 970 EVO Plus 1TB, 3x Samsung 850 Evo 250GB in Raid0, Custom Watercooling.
HTPC: Intel 3770k @4.2Ghz, 16GB ram, GTX 2070 (cpu bottlenecked )
Norlig is offline
post #2 of 2 (permalink) Old 01-30-2019, 12:18 PM
Kaltenbrunner's Avatar
Rep: 17 (Unique: 16)
If it really has 2 independent 12V rails, then no it's not a good idea because current would still flow between them any time they're not exactly matching each others voltage.
I have broken PSUs and spare controller chips. I'd like to see how much you can setup up the controller chip to output different voltages. But most of the output caps would need changing as they are only 10 and 16V rated. The output controller and all the feedback circuitry and over/under voltage and current protections, would have to be disabled or really really modified.
I don't really know how flexible the flyback transformers are in there operating frequency.
But since I have both types of controller chips I should strip down 1 PSU to the basics and use my own chips and controller/feedback circuits and see if these can run as a variable bench SPMS
Kaltenbrunner is offline
