Seasonic SS-1000XP loud? - Overclock.net - An Overclocking Community
post #1 of 34 (permalink) Old 01-26-2019, 08:45 AM - Thread Starter
LTC
LTC's Avatar
Rep: 38 (Unique: 36)
So I have a 1000W Seasonic powering a Ryzen 2700x and a AMD 290, plus a couple of SSD's. Now, I just replaced all my fans, so I have two Noctua NF-A14's in the front, and two NF-A15's on my Noctua D15. My GPU is running fans at the lowest speed when idle, however my case still has an audible hum to it. I've found that it is my PSU that keeps spinning up the fan, even though it is set to hybrid, I thought it would be controlled by the power usage, so it would be running completely off when my system is idle? My case fans and CPU fans are running at their lowest speed as well. My case is a NZXT H500, in which I removed all the stock fans.
I am considering buying a fanless PSU if this is normal behavior for my PSU.
// Ryzen 2700X 4GHz // GSkill 16GB F4-3600 // 256GB 970 Evo NVME // Gigabyte 2080 Gaming OC White // NZXT H500i //
LTC is offline
post #2 of 34 (permalink) Old 01-26-2019, 08:51 AM
Senior OCN Member
shilka's Avatar
Rep: 2747 (Unique: 1629)
Its not normal and its defective
Why did you buy a 1000 watt PSU for a system that does not even draw half that?
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #3 of 34 (permalink) Old 01-26-2019, 09:08 AM
microchidism's Avatar
Rep: 6 (Unique: 6)
I did something like this too, did I mess up?
GPU History - 6 Nvidia, 3 AMD <--- need to get this number up
microchidism is offline
post #4 of 34 (permalink) Old 01-26-2019, 09:19 AM
Otherworlder
epic1337's Avatar
Rep: 217 (Unique: 125)
theres no problem with excessively high wattage PSUs so long as it's one of the good models, it just means you've overspent on something pointless.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #5 of 34 (permalink) Old 01-26-2019, 09:58 AM - Thread Starter
LTC
LTC's Avatar
Because I bought it back when running SLI Fermi and a dual Xeon setup? I've uploaded a video with the noise here:
LTC is offline
post #6 of 34 (permalink) Old 01-26-2019, 10:01 AM
Never Finished
airisom2's Avatar
Rep: 268 (Unique: 206)
On some models it also means the fan will almost never spin because it hasn't crossed a power threshold that requires the fan to move, and that could be worth the price bump for some. Then again, the P2 1200w I had was in eco mode it's whole life and it broke after 2 years...not using that mode again.
Here's what I got:
Check psu orientation. If you're on carpet, you could be choking the fan if it's facing down. Raising your case or flipping the unit around should help if that's what's happening.
Monitor voltages in bios/multimeter to see if everything's in spec (Usually +/- 5%, and you shouldn't see any rapid fluctuations).
Blow dust out, if any.
Run in normal mode and see what happens.
Monitor power usage with killawat.
When in hybrid mode, the fan should be off when utilizing less than 30% power capability. At 30-50%, it should be in silent mode which is 16dba, and above that it'll ramp up the fan to more audible levels as power consumption increases. In normal mode, instead of running passively at 0-30%, it'll run in silent mode (16dba), which shouldn't be audible unless you have a super low noise floor in your room or if you got noisy bearings.
1680 V2 4.5GHz 1.33v | G.Skill Trident X 4X4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Rosewill Rise | Thermalright LGM RT
Logitech G600 | G440 | Tt Meka G-Unit Cherry MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #7 of 34 (permalink) Old 01-26-2019, 10:12 AM
Senior OCN Member
shilka's Avatar
Just asking but you are sure you have it in hybrid mode right?
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
shilka is offline
post #8 of 34 (permalink) Old 01-26-2019, 10:13 AM - Thread Starter
LTC
LTC's Avatar
Here's what I got:
Killawatt
When in hybrid mode, the fan should be off when utilizing less than 30% power capability. At 30-50%, it should be in silent mode which is 16dba, and above that it'll ramp up the fan to more audible levels as power consumption increases. In normal mode, instead of running passively at 0-30%, it'll run in silent mode (16dba), which shouldn't be audible unless you have a super low noise floor in your room or if you got noisy bearings. If everything checks out, then your unit likely needs to be RMA'd.
Thanks! My PC is on a wooden floor, and is installed with the fan down, drawing air from the outside. I will try to run it in normal mode later, but that would only make it run louder I guess. If you see my video above you can hear it. I was recording with a good microphone so it isn't some static noise, but the actually noise coming from the PSU.
LTC is offline
post #9 of 34 (permalink) Old 01-26-2019, 10:14 AM - Thread Starter
LTC
LTC's Avatar
Yes I am. I will try to flip it to normal in a moment and report back.
LTC is offline
post #10 of 34 (permalink) Old 01-26-2019, 10:29 AM
Rep: 6 (Unique: 6)
For me I wanted the computer to be inaudible from 3 ft away regardless of what I was doing
When I had PSUs closer to my wattage they would get very loud during gaming (sometimes audible from 15+ feet away) so I felt the extra 100 or so was well worth it
