Differences Between Seasonic FP+ and Prime? - Overclock.net - An Overclocking Community
post #1 of 40 (permalink) Old 01-30-2019, 12:59 PM - Thread Starter
Shardnax Level 1
Shardnax's Avatar
I'm looking to replace my aging Corsair HX650 (80+ gold version) with the 650W Focus Plus or Prime Platinum.
Are there any noteworthy differences other than the warranty and efficiency rating?
Shardnax is offline
post #2 of 40 (permalink) Old 01-30-2019, 01:26 PM
Not New to Overclock.net
pulverizor Level 1
pulverizor's Avatar
the Prime series (including their latest state of the art fanless 600W titanium) have a design flaw they have bad transient response (which in some cases can even trigger a protection shutdown)
conversely the Focus series has *relatively* good transient response (minor rails still problematic but nowhere near as bad as the 12V rail on the Prime series, also minor rails are minor importance)
the Focus still has - like the Prime - great voltage regulation & ripple suppression BUT unlike the Primes it suffers from dangerously high inrush current (at least on 220V) and - for some reason - dangerously high thresholds for overpower and/or overcurrent protection (bad design choice go figure)
overall Focus is still better cause transient response is important especially on the big 12V rail
ps. and if you wondering about Corsair: while modern high end Corsair don't have the above mentioned flaws of the Prime & Focus seasonics, they do have one YUGE flaw: they overheat so you better avoid those at least the RM & HX models
pulverizor is offline
post #3 of 40 (permalink) Old 01-30-2019, 01:40 PM
Senior OCN Member
shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about shilka has a spectacular aura about
shilka's Avatar
The Focus is the one with all the problems is it not? sure its the Prime and not the Foucs?
As for Corsair the newest RMx is not bad but i do agree that they are too focused on being quiet and they therefore get hot
The EVGA G3 has a noise problem when used in eco mode so pick your poison
https://www.overclock.net/forum/31-p...e-problem.html
Seravee
(31 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
EVGA GTX 1080 FTW2
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Seagate Ironwolf Pro 8 TB
Seagate Ironwolf 12 TB
Seagate Ironwolf Pro 10 TB
Seagate Ironwolf Pro 12 TB
Optical Drive
LG CH12NS30
EVGA SuperNova G2 750 watt
x5 Noctua NF-A14 FLX
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 49UH750V 4K LED TV
Keyboard
Corsair Gaming Strafe RGB
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod E series PSU cable set
Other
CableMod LED Strips
shilka is offline
post #4 of 40 (permalink) Old 01-30-2019, 01:53 PM
pulverizor Level 1
pulverizor's Avatar
Focus has more minor problems but Prime has 1 yuge problem (bad transient response on 12V rail)
if it HAS to be Corsair then at least a RMi model cause it has a fan test button (and fan can be controlled by software) - and put it in a case where the PSU is at the bottom not top of case
EVGA makes comparable quality & performance PSU's it's basically the 3rd big competitor (though Antec made a comeback recently cause they had their PSU's manufactured by Seasonic)
but problem with EVGA is false publicity: they claim the PSU's are 100% japanese caps but sometimes that's a lie & there are non-japanese caps (even chinese ones) so till they fix that they should be boycotted
post #5 of 40 (permalink) Old 01-30-2019, 01:56 PM - Thread Starter
Shardnax Level 1
Shardnax's Avatar
I've been running two Focus Plus units in other machines without any issue for several months now. Is the design really as problematic as it sounds?
It'll be another year before my HX650 runs out of warranty (Nov. 2020) so I guess I'll wait it out a while longer.
Shardnax is offline
post #6 of 40 (permalink) Old 01-30-2019, 02:00 PM
pulverizor Level 1
pulverizor's Avatar
(that said both are still good overall)
post #7 of 40 (permalink) Old 01-30-2019, 02:07 PM
⤷ αC
AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about AlphaC has a spectacular aura about
AlphaC's Avatar
Do you have a testing source for these claims?
► Recommended GPU Projects: [email protected] , [email protected] (FP64) (AMD moreso) ► Other notable GPU projects: [email protected] (Nvidia), GPUGrid (Nvidia) ► Project list
AlphaC is offline
post #8 of 40 (permalink) Old 01-30-2019, 02:11 PM
pulverizor Level 1
pulverizor's Avatar
web reviews
eg. tom's hardware or jonnyguru
post #9 of 40 (permalink) Old 01-30-2019, 02:26 PM
Senior OCN Member
shilka's Avatar
The Foucs had problems with the Asus GTX 970 Strix and the Vega 56 and 64 cards thats all i have heard and seen
Have not seen or heard anything about the Prime so a source for that data would be nice
Seravee
(31 items)
Intel Core I7 6850K
EVGA GTX 1080 FTW2
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
Keyboard
Mouse
Roccat Kone EMP
Mouse
Roccat Sense Metor
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
Other
CableMod LED Strips
shilka is offline
post #10 of 40 (permalink) Old 01-30-2019, 02:40 PM
pulverizor Level 1
pulverizor's Avatar
tough luck jonnyguru website is down :/
one of the reviewers there had a good test for the prime ultra especially for transient response
this is the link check it out when site's back online
http://www.jonnyguru.com/modules.php...tory4&reid=544
you'll notice the nasty spike on the 12V tests (but at least there the PSU didn't shutdown)
and that's the best Prime of all time
