PSU cables with inline capacitors: what happens if a cable cap goes KO? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 01-30-2019, 03:22 PM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
Quote: Originally Posted by lexer View Post
I doesn't matter because the connectors are in parallel, most PSU today have only a single rail. Even in multi-rail PSU the output are "artificially" divided with shunt resistors that monitor the output of each rail but in reality is one
so in other words they didn't need to complicate things by making separate pci-e cables (and connectors on GPUs) they could've just had 1 single 8pin connector & 1 cable no matter how much the GPU needs??
pulverizor is offline
post #12 of 14 (permalink) Old 01-30-2019, 03:42 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
Nope having multiple cables reduce the total resistance and you have less voltage drop and less heat on the cables. That is the reason some manufacters recommend using two separate cables for high power GPU instead of the daisy chain. But you can imagine that works is like a "single cable"
I7 8700K@4.7Ghz / Z370-A / 2X8GB 3200Mhz ADATA Spectrix D40 / 1TB Intel 600P / EVO 850 250GB / 4TB WD Gold / RTX 2080 GAMING OC / NZXT Noctis 450 ROG / EVGA G2 850W@ECO
Heatkiller REV 3.0 / XSPC EX360 / DDC 3.25 + EK-XRES / 3x Venturi HF-12 PWM
lexer is offline
post #13 of 14 (permalink) Old 01-30-2019, 04:09 PM
Overclocker
JackCY's Avatar
Rep: 339 (Unique: 240)
The caps are useful, same as using multiple cables to GPUs instead of a single 8+6. The caps are not necessary and removing them doesn't cause any issues but may increase whine from GPU etc. If they go bad then you probably have way bigger problems than the caps LOL.
JackCY is offline
post #14 of 14 (permalink) Old 01-31-2019, 06:29 AM
RTX ON FPS OFF
anticommon's Avatar
Rep: 29 (Unique: 26)
So after looking at my existing cables I just realized that they must already have capacitors built in.
At this point I'm almost wondering if it's a faulty unit due to the whine, maybe trying another PSU of similar caliber could help me determine if it's something that can be fixed or just a symptom of waterblocking my card.
KRAKEN
9900k
Gigabyte Z370 Gaming 7
EVGA RTX 2080 Ti XC ULTRA
Kingston HyperX Predator RGB
ADATA XPG SX8200
EVGA SUPERNOVA G2
EK Velocity Nickel-Plexi, EK Vector RTX Nickel-Plexi, EK EX360, Koolance 360mm, Enermax Neochanger
Thermaltake A500
Operating System
W10 Premium
Alienware AW3418DW
Keyboard
Corsair LUX
Mouse
Logitech G502 Spectrum
Audio
Audiotechnica ATH-900X, SBX G5, MODMIC
anticommon is offline
