PSU cables with inline capacitors: what happens if a cable cap goes KO? - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 01-30-2019, 01:06 PM - Thread Starter
Not New to Overclock.net
pulverizor's Avatar
Rep: 0
question's in the title
both Corsair & Seasonic have nasty habit as of late of putting caps in their cables even if pro reviewers all think it's useless
and since those caps are not japanese ("100% jap cap" only applies to what's inside the PSU) my question is what happens if such a cap blows up? can it damage a component of the PC?
question #2: if a graphics card is powered via TWO cables (both with inline caps) what happens if only ONE of the cables has the cap go boom? does it create a dangerous "imbalance" of sorts?
pulverizor is offline
post #2 of 14 (permalink) Old 01-30-2019, 01:24 PM
Senior OCN Member
shilka's Avatar
Rep: 2739 (Unique: 1626)
The Seasonic Prime Ultra series have those caps removed where the older Prime had them
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is offline
post #3 of 14 (permalink) Old 01-30-2019, 01:27 PM
Watercooled
lexer's Avatar
Rep: 47 (Unique: 33)
Is very unlikely that those capacitor will blow up since that don't receive a lot of heat and the "heavy" filtering is do it in the secondary side of the PSU. In my opinion aren't not useless, helps to reduce coil-whine in some cases and noise and ripple by a small margin. I think jonnyguru tested that. Usually have a small value. Because capacitors of high values only can filter in low frequency so by adding a small value capacitor in the PCI-E cable helps creating a wide range of filtering.
I manage to reduce the coil whine in system with low-end psu by adding a 100uF capacitor + 100 nF MKP right in the PCI-E connector
https://i.stack.imgur.com/zpsTQ.png
I7 8700K@4.7Ghz / Z370-A / 2X8GB 3200Mhz ADATA Spectrix D40 / 1TB Intel 600P / EVO 850 250GB / 4TB WD Gold / RTX 2080 GAMING OC / NZXT Noctis 450 ROG / EVGA G2 850W@ECO
Heatkiller REV 3.0 / XSPC EX360 / DDC 3.25 + EK-XRES / 3x Venturi HF-12 PWM
lexer is offline
post #4 of 14 (permalink) Old 01-30-2019, 01:36 PM - Thread Starter
pulverizor's Avatar
Rep: 0
so 1- what happens if a cable cap goes KO is just removed?
and 2- if a graphics card is powered via TWO cables (both with inline caps) what happens if only ONE of the cables has the cap go boom is removed ? does it create a dangerous "imbalance" of sorts?
post #5 of 14 (permalink) Old 01-30-2019, 01:41 PM
Watercooled
lexer's Avatar
If you remove the caps just increase a little bit the noise and ripple. Usually when you design the filtering side of the PSU you don't use a capacitor of a single value and type of capacitor, you use various values and type of capacitors to create a wide effective filtering
Here you have a good explanation :
lexer is offline
post #6 of 14 (permalink) Old 01-30-2019, 01:44 PM - Thread Starter
pulverizor's Avatar
Rep: 0
ok
what about scenario 2 (where only ONE of the 2 cables feeding the GPU, has its capacitor removed) is that potentially dangerous if only one of the 2 cables has a current that's "less clean" than the other cable? can this "imbalance" damage the card?
post #7 of 14 (permalink) Old 01-30-2019, 01:49 PM
Watercooled
lexer's Avatar
ok
Not even remotely. As a said before those capacitor are like "final" filtering don't do the "heavy work". Can be problematic if some of the capacitor inside of the PSU blow up that happens on low-end psu and kill components. I seen it happen dozen of times in my work
lexer is offline
post #8 of 14 (permalink) Old 01-30-2019, 02:01 PM - Thread Starter
pulverizor's Avatar
Rep: 0
so even if the 2 cables feeding the graphics card are "different" (one with missing cap & more ripple then the other) it's no biggie?
post #9 of 14 (permalink) Old 01-30-2019, 02:18 PM
RTX ON FPS OFF
anticommon's Avatar
Rep: 29 (Unique: 26)
I have an EVGA Supernova G2 1000w and a 2080Ti which produces a significant amount of coil whine under load. Is it possible to get an adapter with capacitors that would sit between the normal VGA cables and the PSU itself? (male->capacitor->female)
Also what is the point of adding two different capacitors? one regular and one MKP (which I am assuming is an metallized polypropylene film capacitors)
I would also wonder if there are issues with a heavy (400w+) gpu load as that places like 150w+ on each 8pin and by association each individual set of capacitors.
KRAKEN
9900k
Gigabyte Z370 Gaming 7
EVGA RTX 2080 Ti XC ULTRA
Kingston HyperX Predator RGB
ADATA XPG SX8200
EVGA SUPERNOVA G2
EK Velocity Nickel-Plexi, EK Vector RTX Nickel-Plexi, EK EX360, Koolance 360mm, Enermax Neochanger
Thermaltake A500
Operating System
W10 Premium
Alienware AW3418DW
Keyboard
Corsair LUX
Mouse
Logitech G502 Spectrum
Audio
Audiotechnica ATH-900X, SBX G5, MODMIC
anticommon is offline
post #10 of 14 (permalink) Old 01-30-2019, 03:11 PM
Watercooled
lexer's Avatar
I doesn't matter because the connectors are in parallel, most PSU today have only a single rail. Even in multi-rail PSU the output are "artificially" divided with shunt resistors that monitor the output of each rail but in reality is one
MKP capacitor has lower impedance at higher frequencies than a electrolytic capacitor, so basically you create a more effective filtering than using only a one capacitor. Your PSU have a super b ripple suppression like 10-15mV at full load. I'm not sure that will help but you can give it a try, place a capacitor right in the PCI-E connector and see if helps. You can try different values. BE SPECIALLY CAREFUL WITH THE POLARITY because if you put the capacitor backward it will blowup, MKT capacitors don't have polarity
lexer is offline
