Will Silverstone Strider 8pin PCIE cables work with Corsair type 3 pcie pin outs? - Overclock.net - An Overclocking Community
post #1 of 13 (permalink) Old 02-12-2019, 12:20 AM - Thread Starter
Smug, Jaded, Enervated.
GHADthc's Avatar
Rep: 94
As the title suggests, just wondering if I can use the spare silverstone strider 8 pin pcie cables for a friends build, he's lost his original cables for his Corsair HX1000, and needs two 8 pin connectors for a new GPU.
According to what I can find the pinouts are very similar, except the Strider cables have one extra ground (3x 12v and 5x ground), compared to the Corsair cables that have 4x 12v and 4x ground, other than that, the 12v pins are in the same spots as one another.
Will this cause an issue? Will it damage his hardware? Or simply just not provide the power required and not work?
Some advice on this matter would be greatly appreciated.
Forever a WIP.
(15 items)
2700X (XFR2/PBO @ 4.25Ghz ).
Asus CH7 Wifi.
GTX 1080Ti w/ Raijintek Morpheus.
G.Skill Flare-X 16GB 3200C14 (Running @ 3466Mhz C15).
Samsung 970 Evo 250GB (OS), Seagate Ironwolf Pro 6TB (250GB SSD partition+2GB Ram StoreMI setup), Kingston UV400 500GB SSD (half partitioned).
Silverstone Strider Gold 850W ST85F-GS.
Stock cooling....(Custom loop build in progress).
Silverstone TJ11 (Custom loop project)..currently in Lian Li V2000 Plus.
Operating System
Windows 10 Pro N.
Catleap Yamakasi Q270B @ 110Hz.
Keyboard
Steelseries 6Gv2.
Mouse
Zowie EC2-A.
Mousepad
Puretrak Talent.
Audio
Burson Play, Monoprice Monolith M1060C, Rode NTA1 (With Rode arm), Behringer PS400.
Other
2060mm of radiators stuffed inside/outside a TJ11 in the works + 2x D5 strong, Koolance RP-452X2, Koolance CTR-CD1224, blocks, fittings etc etc...
GHADthc is offline
post #2 of 13 (permalink) Old 02-12-2019, 12:39 AM
white owl's Avatar
Rep: 114
They should have the same pins on the output side, it's the pin out on the connection between the cable and the PSU that's subject to change. What I'm trying to say is that the part that plugs into the card should always be the same, otherwise nothing would work without the right PSU.
If you don't have the 8 pin from the Corsair PSU to compare it to and you don't have a DMM to test it, I wouldn't risk it unless you just really don't care about the GPU lol If you're feeling ballsy you can try to match it up to a photo but that's more risky than having the cable in hand to trace the wires.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #3 of 13 (permalink) Old 02-12-2019, 01:06 AM - Thread Starter
GHADthc's Avatar
Rep: 94
Their layout matches pin for pin on gpu side, and almost on the psu side, other than one ground wire instead of 12v on the silvestone cable, where the corsair cable psu side has 4x 12v wires.
This is how it looks on the silverstone psu side: [g][g][g][g] g=ground ...this is how it looks on the corsair cable: [g][g][g][g]
______________________________________[g][v][v][v] v=12v_____________________________________[v][v][v][v]
I'm assuming it'll either not provide enough voltage to the card, and not power it on, or it'll not care about the lack of one extra 12v and power on, as the 12v wires go to where they have to go on the gpu side of the connector for both silverstone and corsair cables.
I'm hoping I'm correct in this assumption, if anyone can chime in and tell me otherwise, that'd be great.
Forever a WIP.
(15 items)
Asus CH7 Wifi.
Operating System
Windows 10 Pro N.
Keyboard
Steelseries 6Gv2.
Mouse
Zowie EC2-A.
Mousepad
Puretrak Talent.
Audio
Other
GHADthc is offline
post #4 of 13 (permalink) Old 02-12-2019, 01:27 AM
Otherworlder
epic1337's Avatar
Rep: 213
wait, that pin layout would short it on the GPU side because the strider cable is routed 1:1, i don't recommend doing it.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #5 of 13 (permalink) Old 02-12-2019, 01:30 AM - Thread Starter
GHADthc's Avatar
Rep: 94
So because the Silverstone cable has a ground wire in place of a 12v wire that the Corsair one has, it will short? My thought was it'll either just not work due to grounding, or it'll be fine as the other 3 12v wires match up.
You think this could potentially hurt his GPU?
Forever a WIP.
(15 items)
Asus CH7 Wifi.
Operating System
Windows 10 Pro N.
Keyboard
Steelseries 6Gv2.
Mouse
Zowie EC2-A.
Mousepad
Puretrak Talent.
Audio
Other
GHADthc is offline
post #6 of 13 (permalink) Old 02-12-2019, 01:37 AM
Otherworlder
epic1337's Avatar
Rep: 213
i'm double checking, the 4th pin which should be ground is a sense-pin.
the sense-pin is supposed to be pulled down (grounded) to notify the card that it has an 8-pin power connected.
so either it doesn't see it as an 8-pin and revert to 6-pin power mode, or the sense-pin fries from getting pulled up (+12V).
the corsair cables have the two additional pin on 6+2pin tapped to ground wires, so it doesn't have this issue.
as for why corsair have 4 +12V on the PSU receptacle, its because they power two 8-pin plugs with one cable, splitting two +12V to each 8-pin plug.
or otherwise the 4th +12V pin isn't used.
epic1337 is offline
post #7 of 13 (permalink) Old 02-12-2019, 01:47 AM - Thread Starter
GHADthc's Avatar
Rep: 94
https://www.modders-inc.com/power-su...-repository/8/
https://www.modders-inc.com/power-su...-repository/9/
The PSU is an original HX1000, it doesn't have dual 8 pin cables, so I am assuming the 4th 12v power pin wont even be used, and all the other wires match from psu to gpu end between the two brands.
Forever a WIP.
(15 items)
Asus CH7 Wifi.
Operating System
Windows 10 Pro N.
Keyboard
Steelseries 6Gv2.
Mouse
Zowie EC2-A.
Mousepad
Puretrak Talent.
Audio
Other
GHADthc is offline
post #8 of 13 (permalink) Old 02-12-2019, 01:51 AM
Otherworlder
epic1337's Avatar
Rep: 213
yeah but the silverstone strider cable is wired 1:1, you'd need to mod it by cutting off the 4th +12V and tap the 4th pin to ground instead.
epic1337 is offline
post #9 of 13 (permalink) Old 02-12-2019, 02:38 AM - Thread Starter
GHADthc's Avatar
Rep: 94
I think its better to ere on the side of caution and not muck around with this, he can just wait till hes gotten himself some replacement cables, which is looking like its not going to be so easy for an original HX-1000 psu, as local stores only seem to sell type 4 cablemod cables, and looking at the corsair compatibility list, they don't seem to work with the old HX series of PSU's.
*sigh* would of been good if he hadn't of lost his spare power cables...
Forever a WIP.
(15 items)
Asus CH7 Wifi.
Operating System
Windows 10 Pro N.
Keyboard
Steelseries 6Gv2.
Mouse
Zowie EC2-A.
Mousepad
Puretrak Talent.
Audio
Other
GHADthc is offline
post #10 of 13 (permalink) Old 02-12-2019, 02:45 AM
RGB Rainbow Vomit!
Ricwin's Avatar
Rep: 31
Just buy replacement cables. Dont risk killing the PSU and/or GPU all for, at most, $30 worth of cables.
Crystal
(10 items)
O M E N
(9 items)
The Movie Box
(10 items)
Ryzen 2600
Asus TUF B450M
EVGA 1070 Ti SC Black Edition
Corsair Vengeance LPX 16Gb 2933MHz
Samsung 960 Evo 250Gb
Kingston HyperX Fury 480Gb
EVGA 750GQ
BeQuiet! Pure Rock Slim
Corsair Crystal 280X White
Operating System
Windows 10 Pro x64
Intel i7 6700HQ
Nvidia GTX 965m 4Gb
Ballistix Sport LT 16Gb 2400Mhz
HyperX Fury 480Gb
OMEN 15 by HP
Operating System
Windows 10 Home x64
Mouse
SteelSeries Rival 700
Audio
Creative Play!3 & M-Audio AV30.
AMD A8 7600 APU
MSI A88XI AC v2
AMD A8 7600 APU
8Gb Corsair DDR3 1600MHz
120Gb KingDian S280 SSD
CIT 500w SFX PSU
Arctic Alpine 64plus
Silverstone ML05b
Operating System
Windows 10 Pro x64
42" 1080p HD TV
Ricwin is offline
