PSU Fan Replacement (enermax pro82+ 525w) - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 02-21-2019, 07:54 PM - Thread Starter
Rep: 0
I want to change PSU Fan (enermax pro82+ 525w).
Enermax fan has 4 cables (red, white, black, yellow) connected to the PSU PCB via JST PH 4-pin connector. So i bought a be quiet PURE WINGS 2 PWM. I cut off the PWM connector and crimped my JST Terminals carefully. So bad connection cannot be the problem.
Next i watched the arrangement of the original fan. PURE WINGS cables are all black unfortunately, but you can watch inside, at the Fan PCB an see the soldering joints attached to the cables. They say "-" "+" "F" and "P".
Therefore i connected the PURE WINGS cables to a new JST PH 4-pin connector:
"-" to black
"+" to red
"F" to white
"P" to yellow
I connected the new one but it didn’t work. So i swapped white and yellow, and again no luck.
Other swaps of cabled does not make sense imo, because it would be ridiculous if enermax would not use black and red as ground and phase.#
Am i missing something?
Please help me
Name:	inside pure wings.jpg
embuh456 is offline
post #2 of 15 (permalink) Old 02-21-2019, 08:28 PM
Linux Gamer
Almost Heathen's Avatar
Rep: 58 (Unique: 40)
I have no idea as to your question, but must tell you that (in case you are unaware) you would be wise to be very careful. I've gotten zapped trying to replace a PSU fan, even after trying to discharge it beforehand. AFAIK one could even die of electrocution working with a PSU.
NAS / HTPC
(19 items)
Workstation
(10 items)
Intel Xeon W3680 @ 3.9GHz
Dell 0x501h (BIOS A16, not EFI capable)
EVGA GTX 1060 Gaming 6GB 06G-P4-6161-KR @ stock
30GB @ 1066MHz CL7 (3x8GB 2Rx8 1600MHz ECC UDIMMs, 3x2GB 2Rx8 1333MHz non-ECC)
ZFS mirror (media), ZFS JBOD (gaming etc.), ZFS OS
Seasonic SS-850HT
Scythe Ninja 4
Sunbeam Rheostat Extreme Fan Controller rev2
4 x San Ace 140mm, 2 x Delta AFB 120mm (VRM fans)
CaseLabs Bullet BH8 (white)
Operating System
Antergos XFCE (Antergos repos removed)
Panasonic Viera X3 TV
Keyboard
CM Storm Quickfire Pro (Cherry Reds)
Mouse
Logitech M310
Mouse
Itac mouse-trak Industrial Trackball
Mousepad
Cloth
Audio
Creative Sound BlasterX H5 Tournament Edition Headset
Audio
Creative Sound BlasterX G1 USB Sound Card
Audio
Philips HTS3555 5.1 1000w Home Theater
AMD Athlon II X4 640 @ stock
(Foxconn 2AB1) N-Alvorix-RS880-uATX (latest BIOS, not EFI capable)
Radeon 5250 @ Stock
4 x 2GB 1066MHz CL7
Hitatchi 40gb (ZFS)
OEM 250w?
OEM
OEM
Operating System
HP vp17
Almost Heathen is offline
post #3 of 15 (permalink) Old 02-21-2019, 09:03 PM - Thread Starter
Rep: 0
i unplug it of course
embuh456 is offline
post #4 of 15 (permalink) Old 02-21-2019, 09:44 PM - Thread Starter
Rep: 0
you are right, better double check if plugged or not
embuh456 is offline
post #5 of 15 (permalink) Old 02-21-2019, 10:07 PM
white owl's Avatar
Rep: 136 (Unique: 103)
Seriously?
The caps hold charge (possibly for years) after you unplug a PSU, some of those caps are pretty potent to a human.
FYI not all fans will work with any PSU, if the fan's ohm load is off too far there's good chance it will either not work or work differently than intended. Perhaps the PSU's fan has a lower starting voltage than the replacement? Or that plus the fan having a higher ohm load making the situation worse.
Does the PSU fan run all the time or does it turn off?
EDIT: Just looked up the PSU and apparently it was a very quiet unit so it wouldn't surprise me if the PSU simply doesn't meet the minimum voltage requirement for that fan.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #6 of 15 (permalink) Old 02-21-2019, 10:19 PM
Linux Gamer
As white owl stated, the capacitors etc hold a charge long after it's unplugged. I had tried to discharge the PSU for a minute (by shorting the 24pin connector, as if to power it on) before I worked on it, and still got zapped.
Maybe replacing the fan is still worth it for you, but I would have felt negligent not to warn you. Personally I'd sell it and buy a different PSU if not happy with the fan noise, not worth the risk to me. If I were to do it again, I'd short the pins at least overnight (probably more like a ****ing week) and see about protective gloves.
NAS / HTPC
(19 items)
Workstation
(10 items)
Seasonic SS-850HT
Scythe Ninja 4
Operating System
Keyboard
Mouse
Logitech M310
Mouse
Mousepad
Cloth
Audio
Audio
Audio
Radeon 5250 @ Stock
4 x 2GB 1066MHz CL7
Hitatchi 40gb (ZFS)
OEM 250w?
OEM
OEM
Operating System
HP vp17
post #7 of 15 (permalink) Old 02-22-2019, 12:54 AM
Senior OCN Member
shilka's Avatar
Rep: 2749 (Unique: 1629)
Its an 11 year old PSU so dont bother replacing the fan throw it out and buy a new unit
Ripple suppression is not very good either so thats another excuse for throwing it out
As for the fan replacement if you dont know what you are doing and you are not careful enough you can win yourself a darwin award
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is online now
post #8 of 15 (permalink) Old 02-22-2019, 01:21 AM - Thread Starter
Rep: 0
the original fan is capable if 1500rpm like the new one. In my case the psu fan never goes to zero rpm. But it is regulated by power consumption i guess. Maybe it can be 0 rpm but my rigs drain is to high.
i don’t mind to buy a new as long it works. I will inform about to safely work with open psu.
I will ask enermax about my problem.
Thank you for your answers.
Darwin Award would be nice btw.
embuh456 is offline
post #9 of 15 (permalink) Old 02-22-2019, 01:25 AM
deepor's Avatar
Rep: 474 (Unique: 320)
Maybe the old fan is actually fine and the problem is instead something else about the PSU? Maybe the fan header in the PSU isn't working.
deepor is online now
post #10 of 15 (permalink) Old 02-22-2019, 01:40 AM - Thread Starter
Rep: 0
The original fan works pretty well. But it is actually the loudest part of my system while idling.
It does not work perfectly. There is some kind of excessive noise, the noise is not very loud but imo worth for a change.
If there is no way to change the fan, i will keep the psu until it dies. Because that is my way to use things. Let it work and repair it until there is no way to fix it or it is technically outdated.
embuh456 is offline
Tags
fan replacement , jst , Psu
