Connect PSU cables directly to PSU pins? (bypass plastic connector) - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 04-05-2019, 10:00 AM - Thread Starter
Rep: 0
PSU = Power Supply Unit
In my custom case, there is no room between the plastic connector , protruding out from the power supply, and the case cover.
So, is it possible to connect the power supply cables directly to the pins on the power supply? Are there any kind of 90 degree crimp-on connectors or methods to do this that you Overclocker.net'ers found to work well?
TheMeatHead1 is offline
post #2 of 11 (permalink) Old 04-05-2019, 10:20 AM
Filthy Casual
bajer29's Avatar
Rep: 108 (Unique: 93)
Your best bet is to order a custom length 12V rail cable from a cable vendor or make your own cable.
https://www.moddiy.com/products/2.54...Connector.html
https://mod-one.com/24-pin-pc-cable-extension/
Xeno Storm V 1.2
(17 items)
i7 4790K (delidded)
GIGABYTE|GA-Z87X-D3H
EVGA 1080TI FTW3
4x4GB GSKILL @ 2133MHz
WD 1002FAEX
KINGSTON V300 120GB
SanDisk Ultra Plus 128GB
Samsung 850 EVO 500GB
WD Green WD5000AADS
Corsair AX850
Cryorig R1 Ultimate
Phanteks Enthoo Pro M SE
Operating System
Windows 10 Enterprise
Acer XB270HU Predator
Keyboard
E-Element Z-88 RGB
Mouse
Corsair M65
Audio
Logitech X230 2.1
bajer29 is offline
post #3 of 11 (permalink) Old 04-05-2019, 10:27 AM
doritos93's Avatar
Rep: 119 (Unique: 84)
Solder the wire directly onto the pin
That will look great
doritos93 is offline
post #4 of 11 (permalink) Old 04-05-2019, 12:28 PM - Thread Starter
Rep: 0
I'm open to doing this, but I cannot fit my soldering iron tip and wire into each of the power supply's plastic connector holes. How can I do this? Or, is there a way you recommend cutting the plastic modular connector that has the metal pins inside it?
Also bajer29, thanks for those links. When I looked inside the power supply connector, it's a MALE metal pin inside, so I don't think that 90 degree "Right Angle Motherboard Header Connector" you linked to would work...unless you had a method?
post #5 of 11 (permalink) Old 04-05-2019, 12:39 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
What brand and model is your PSU if its really old or mediocre you are better off buying a smaller PSU instead
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #6 of 11 (permalink) Old 04-05-2019, 12:59 PM - Thread Starter
Rep: 0
Enermax MaxRevo 1500EWT (EMR1500EWT). I bought it because it was the shortest length I could find in this power and efficiency rating (80 Plus Gold).
Do you know of any shorter psu's that can match or surpass the above specs?
post #7 of 11 (permalink) Old 04-05-2019, 01:13 PM
professional curmudgeon
looniam's Avatar
Rep: 830 (Unique: 465)
that sorta begs the question; do you NEED 1500 watts? HEDT/TR platform w/multi GPUs?
but thats another can of worms . . there are 90 degree molex housings you can replace the straight connectors on the PSU. bajer29 posted that first link and digging around there will show for 24 pin, 8 pin (EPS) 8/6 pin PCI-E connectors. you can look there and on digikey for the terminals. just mind the pitch (distance between the pins) on the housing and the amperage rating (11amps is best) on the terminals.
however i am neglecting some links since i really think modding the case panel would/might be much easier.
got a dremel?
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #8 of 11 (permalink) Old 04-05-2019, 01:20 PM
stickg1's Avatar
Rep: 148 (Unique: 104)
What all are you powering with that bad boy? Also what chassis are you using? Any way to modify it?
stickg1 is offline
post #9 of 11 (permalink) Old 04-05-2019, 01:36 PM
Senior OCN Member
shilka's Avatar
The MaxRevo is 8 years old and the voltage regulation on the 12v rail was never all that great
Unless you have a 3 or 4 way GPU setup you dont need that much power so rather than modifying an old PSU replace it and buy a smaller one
The Corsair SFX600 is pretty good and its much smaller than your old Maxrevo
https://www.corsair.com/eu/en/Catego.../CP-9020105-EU
https://www.corsair.com/us/en/Catego.../CP-9020182-NA
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #10 of 11 (permalink) Old 04-05-2019, 02:25 PM - Thread Starter
Rep: 0
Yes I have a dremel and yes this is a fully water cooled system of 4 GPU's + 1 CPU.
Case = Raijintek Styx (modified to fit bigger radiators)
The power supply is venting out the side of the case opposite of the picture. I've been trying to avoid cutting this side of the case because I enjoy the clean brushed aluminum panel look. If there was a way to solder a wire onto each pin of the power supply connectors (that will be used), I could fit it all in the case!
Tags
power supply sleeve , power supply sleeving , psu sleeve , psu sleeving
