Powersupplies with least amount of AC ripple - Page 4 - Overclock.net - An Overclocking Community
post #31 of 43 (permalink) Old 04-30-2019, 05:30 PM
Notanymore's Avatar
Rep: 1 (Unique: 1)
"Corsair sounds not bad at all based on Johny Gurus reviews, but it's not silent, how loud it is."
My Cosair TX-650 is silent. I've had it for a year now. I heard it for the first time about a month ago for like 3 seconds. It was like hearing a baby say their first words the first time...LOL! I just smiled when I heard it. The fan does not even turn on unless absolutely needed.
Azza Inferno 310 Case|AMD Ryzen 7 1700X|Deepcool GAMMAXX GT RGB Cooler|AsRock X370 Taichi MOBO|GSkill Trident-Z RGB 16GB 3000MHz DDR4 CL-14|Samsung 970 EVO Pro NVMe M.2 512GB|Samsung 850 EVO 500GB|Tosihiba DT01ACA300 HDD 3TB|Seagate ST1000DX001 HDD 1TB|EVGA Geforce GTX 1070 Ti FTW2|Corsair TX-650 650W PSU|6 x Enermax T.B. RGB Fans
Notanymore is offline
post #32 of 43 (permalink) Old 04-30-2019, 05:57 PM
Gabe1's Avatar
Rep: 1 (Unique: 1)
I've been running a EVGA 750 G3 on a 5820K for over a year without an issue...
Gabe1 is offline
post #33 of 43 (permalink) Old 04-30-2019, 07:20 PM
Overclocker
JackCY's Avatar
Rep: 339 (Unique: 240)
Quote: Originally Posted by XLifted View Post
Do you know of such a PSU? Do you know the name?
A good switching PSU? As other posted many times, PSUs from EVGA G2/SuperFlower Leadex lineup etc., EVGA/Seasonic models and even other. Seasonic Prime and those cheaper gold ones (FOCUS) only these newer series to consider the old ones (G series, M12/S12 and what not) are pretty poor whine wise or outright outdated a lot.
A good linear PSU as I said I don't know of any for PC market. These are often either lab PSUs or audio equipment PSUs. They are inefficient but have low ripple.
Modern switching PSUs for PC are fairly good if you look into what to buy precisely, you won't have a problem with ripple. Whine noise... you can try and prevent it but never 100%. 100% of GPUs whine in some situation, etc. Sometimes a combination of components can make it whine somewhere.
JackCY is offline
post #34 of 43 (permalink) Old 04-30-2019, 08:15 PM
munternet's Avatar
Rep: 7 (Unique: 4)
Is the GPU whine something associated with 110v supplies?
I run a HX1200i and the fan never turns on that I've noticed so there's no fan noise and I've never heard a whine coming from the GPU/VRMs except once on a stress test (forget which one).
Parts in sig.
I didn't read all the posts so I apologize if this was already addressed
Battle PC
(15 items)
8700k @ 5.2ghZ
Maximus X Hero
EVGA 1080 Ti Superclock 2 Black
32GB 1xF4-4400C19D-16GTZSW & 1xF4-4400C19D-16GTZKK
Sansung M.2 1TB 970 EVO
Corsair HX1200i
EK 140D5 Pump, waterblocked CPU, Ram, GPU with 2x 360mm Radiators and Vardar Fans
ThermalTake V51
Operating System
Windows 10 Lite
Dell Computer DELL U3415W 34.1 inches 3440 x 1440 pixels @ 48-85 Hz
Keyboard
Corsair K95 RGB Platinum
Mouse
Asus Spatha Wireless Gaming
Mouse
Ligitech G602 wireless
Mousepad
1000mm x 500mm
Audio
Steelseries Siberia800 wireless Headset
munternet is offline
post #35 of 43 (permalink) Old 05-10-2019, 10:54 AM
Broken
nanotm's Avatar
Rep: 31 (Unique: 19)
well its been my personal opinion that since the sweet spot of efficiency is between 50%>80% load on the psu your best of determining what your peak power draw should be cpu+gfx +100w (average for ancillaries) (most often somewhere around 500>650w meaning you should be looking at between 850 and 1000w psu's to be within the peek efficiency curve for hte psu (this also means its not likely to get warm through use nor need more than around 30% fan speed even on the hottest days) this will also mean that providing your running from a stable supply its unlikely to make any noise
as to the op's question on page 1 by UPS I mean Uninterruptable Power Supply like this https://www.amazon.com/dp/B0083TXNMM...i-a=B0083TXNMM
I'm not in the US though I'm fairly certain you can get better deals than the ones listed on the amazon page, however you should be looking for something thats going to give you at a minimum 1500va for 30 mins (this also means you can run the tower +monitor +modem/router off of it and if you shut down the pc during a power cut your wifi will still work for several days due to the minimal power draw, I know this last part from personal experience, although best if you get one that lets you turn the alarms off becasue they tend to be loud and annoying)
oh found this https://www.amazon.com/dp/B0083TXNMM...i-a=B0083TXNMM
much better price but I didnt bother looking to far into it / probably still cheaper and better options from places like Walmart or bestbuy /
nanotm is online now
post #36 of 43 (permalink) Old 05-10-2019, 05:10 PM
News Fiend
ryan92084's Avatar
Most home users would be looking at something more like https://www.newegg.com/Product/Produ...82E16842102238
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #37 of 43 (permalink) Old 05-11-2019, 06:26 AM
Broken
nanotm's Avatar
would that be why the vast majority dont end up with what they need and end up annoyed that the device isnt up to the job ?
this is the actual device I purchased https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
I've had it for around 5 years, prior to that I purchased other junk like the item you listed and it was woefully inadequate and ended up purchasing several different ones over about 15 years, mostly because the sort of item I actually wanted was way outside of my price bracket until one day it wasn't...
and I can run my pc off the ups box for about an hour whilst under heavy load (at max power draw my old system was sucking in around 750w, my new rig barely pops over 500w but thats what happens 10 years on everything is more power efficient)
prior to getting the UPS and plugging an extension bar into it (for things like the phone wall wart and the psu's for the modem, external drives etc) I was replacing those things way too often (but the old UPS could barely keep the pc running never mind anything else) now I have had the same UPS router and multiple power bricks since 2014 and saved a bunch of money in the process....
I knew what I needed and when I finally found something that fit the price bracket I got it happily (certainly cheaper than rma'ing the psu that I had replaced twice due to problems caused by the incoming supply being erratic)
post #38 of 43 (permalink) Old 05-11-2019, 07:41 AM
News Fiend
ryan92084's Avatar
I wouldn't say yours is a typical home use case. Regardless we are well outside the topic now.
Meh '12
Ryzen 2600x
XFX Fury X
EKWB Fury X
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
Optical Drive
Some old thing
Custom water
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
post #39 of 43 (permalink) Old 05-12-2019, 09:22 PM
Not new to Overclock.net
TwoCables's Avatar
Rep: 6214 (Unique: 3521)
No, no, no, no. It doesn't work that way. Your understanding of it is not quite correct (but then MOST people don't understand it correctly). Yes, most PSUs should give their best efficiency when the power consumption is between 40% and 60% of its total output capacity, but there's more to understand than just that alone. You want your average power consumption to fall in that range, not your peak. Even then, this really doesn't apply to today's good PSUs like it did to PSUs from many years ago. Some good PSUs today give their best efficiency at almost any power draw. So this is really an obsolete concern and there's really nothing more to discuss.
However, if one were to insist that this is important for them, then again, they should figure out what their average power consumption will be day to day and then base their purchase on that.
So, ok, let's say your most demanding activity is gaming and let's say you only do that for a couple of hours every day and the rest of the time your system is either idling, or under VERY low loading conditions, or off completely. That's a VERY low average power draw. Let's say the power consumption while gaming is precisely 500W. With everything else being the same as I just described (resulting in the extremely low average power draw), you could power this just fine with a high-end 550W PSU if you had to and you'd be fine and your average efficiency would still be quite good and this PSU would give you years and years and years of excellent service.
Now, let's take this in the complete opposite direction and say that your system is at full load 24/7. Maybe it's Folding and mining at the same time 24/7. Let's assume it is, and let's assume the power consumption is 500W. For THIS particular system and loading scenario, the average power consumption is 500W. That's enormously different from the previous situation where the average loading condition was extremely low. For an average load of 500W, yeah, I would recommend nothing less than a high-end 850W PSU. I would be foolish to recommend anything less than that for a 500W average power draw.
So you see, you can't just say "well, my peak hits 500W, so therefore I want an 850W PSU or bigger".
I don't want to hear about keeping the PSU cool either. With today's good PSUs, if you choose to keep your average power consumption at 40-60% of the total output capacity (which would be at least 100-200W higher than the continuous wattage rating that's advertised), then you're looking at a life of over 10 years for that PSU. Easily. Probably far longer than 10 years.
Yes, the GOOD PSUs only advertise their continuous wattage rating, not their absolute peak. So that 550W PSU I mentioned might actually have a peak of 750W, especially if it's a very high-end unit. Think about that for a while! The continuous rating means exactly that: continuous. 24/7. Non-stop. Imagine how damn good the PSU has to be in order to deliver 550W continuously. Why worry about pulling 500W out of a PSU like this for a few hours every day?! Right?!?! Right.
Loneliness is a good thing to share with someone.
The virtuous spirit has no need for thankful approval, owning a certain conviction that what has been done is right.
i5-2500K @ 4.5GHz (1.368-1.384V fixed voltage)
ASUS P8P67 EVO B3 (UEFI ver. 1850)
MSI GTX 1070 Ti Gaming Titanium 8G
G.SKILL Ripjaws X 8GB (2 x 4GB) 1866MHz, CL9
250 GB Samsung 840 EVO (OS)
3 TB Toshiba P300 (D: drive)
Optical Drive
Samsung SH-S243N 24x DVD Burner
Optical Drive
Samsung SH-S203N 20X DVD Burner
Corsair RM550x
Thermaltake Frio
CM 690
Operating System
Windows 10 Home
AOC G2460PG (24" 1920 x 1080 144Hz G-SYNC)
Keyboard
Filco Majestouch 104-key Cherry MX Blues w/NKRO
Mouse
Intellimouse Optical (1.1A) 1000Hz polling rate
Mousepad
It's just a mousepad
Audio
X-Fi Titanium HD
Audio
Klipsch ProMedia 2.1 (with 16 AWG Monster Cable speaker wires)
TwoCables is offline
post #40 of 43 (permalink) Old 05-14-2019, 02:13 AM
Broken
nanotm's Avatar
sure but since my average use case was playing some game or other, maybe editing a few videos and my occasional use was reading a book or doing some word processing I based my average power draw on my peak power draw, which is why I said in my experience...
