Is running a single high end GPU off of daisy chained PCIe connectors ok? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 05-30-2019, 03:13 PM - Thread Starter
TheRacker's Avatar
Rep: 7 (Unique: 7)
I just upgraded from a 7 year old Corsair TX550m to a Seasonic Prime Ultra Platinum 750w, and it's powering an overclocked RTX 2080. The PCIe cables on the Prime are the kind where the second 6+2 is daisy chained off of the first, so all power to the card is running through just one set of wires instead of two. Now obviously I don't think the Prime Ultra is going to have trouble powering a single 2080, but it still feels wrong having all the current run through just one cable and PSU side connection. Should I use both PCIe cables and just have the daisy chained connectors hang loose?
Yes I know 750w is overkill, was originally going to get another 550w or 650w, but I'm planning on keeping this psu at least as long as my old one and have no idea what kind of future hardware I'm going to have, the price difference wasn't that big, and now I never have to worry even if I go with an overclocked 12 core cpu and radeon VII level card in the future.
TheRacker is offline
post #2 of 6 (permalink) Old 05-30-2019, 03:15 PM
Programmer
BradleyW's Avatar
Rep: 1561 (Unique: 1019)
Can cause a burnout if the system is heavily overclocked. Happened twice to me. Using separate cables fixed the issue. Not cheap PSU's either! Corsair and SeaSonic. Had both RMA tested. Reports concluded the same outcome..., PCI-E cables to blame, causing the system to draw power from other areas to compensate. In my case, it draw from the EPS, causing a burnout. Each report recommended using separate PCI-E cables. Have done for years ever since, never had a burn out since!
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
Nvidia MSI Trio-X RTX 2080 Super
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO PLUS NVM.e 500GB
SeaSonic 1250W Gold
Tt Core-X71 + Custom Loop.
BradleyW is offline
post #3 of 6 (permalink) Old 05-30-2019, 03:16 PM
Graphics Junkie
UltraMega's Avatar
Rep: 49 (Unique: 44)
No there is no problem at all with using both plugs from the same cable, at least not that I've ever heard of. Maybe on older PSUs or low quality PSUs it could be, but definitely not on the PSU you have now.
Quote: Originally Posted by BradleyW View Post
It is OK for some, but it has caused a burn out for me in the past. Twice in fact. I run separate cables, always.
It's when I had a 290X. I overclocked it and the cables couldn't handle it, so the motherboard tried to draw power from the EPS cable, causing a burnout.
As stated, happened twice. First PSU was Corsair, the other was SeaSonic. Not cheap components.
Interesting. I used to work at a gaming PC manufacturer and we always built the PCs with as few cables showing as possible. It was never an issues as far as RMAs.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #4 of 6 (permalink) Old 05-31-2019, 12:23 AM
Senior OCN Member
shilka's Avatar
Rep: 2802 (Unique: 1655)
Its very rare but not unheard of for PSU cables to melt when using only a single cable on extremely high powered cards have seen it happen with Seasonic PSU´s before but as i said its very rare
Its probably fine to use a single cable but if you have two cables in the box and have room in the case for both cables i would both just in case
If you had a RTX 2080 Ti i would say definitely use two cables
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is online now
post #5 of 6 (permalink) Old 05-31-2019, 01:15 AM - Thread Starter
TheRacker's Avatar
Rep: 7 (Unique: 7)
Thank you all for the input. Sounds like it's probably advisable to add the second cable and sacrifice some cable management cleanliness.
Why do manufacturers do the daisy chain connector method? I can't imagine adding another 50cm of cable for a whole separate connector would add any appreciable amount to the cost to build, but it does guarantee a much more robust power deliver path. Especially on a high end unit like the Prime Ultra.
post #6 of 6 (permalink) Old 05-31-2019, 01:20 AM
Senior OCN Member
shilka's Avatar
A card like an RTX 2070 would have no problem using a single cable so its only really a problem with the high end card and there are more people buying mid range cards then there are people buying high end cards so its not a problem for most people
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
