2 PSUs 1 Mobo? - Overclock.net - An Overclocking Community
2 PSUs 1 Mobo?
post #1 of 8 (permalink) Old 06-06-2019, 06:58 PM - Thread Starter
I Can Change This???
tmontney's Avatar
Rep: 13 (Unique: 12)
2 PSUs 1 Mobo?
Bit of a crosspost, I'm building a folding rig. Since I want to be as efficient as possible, I figured I'd build it like a mining rig: https://www.amazon.com/Hydra-Server-.../dp/B07B4QHDPJ
It has support for 2 PSUs, but I'm not sure how that works. A quick Google search shows advice against it. I assume you'd use a splitter or a board that supports 2? Personally, my setup would do fine with a 1500w PSU. However, I already have a PSU and it'd be nice to just add on to it.
Looking to sell your GPU? I'm always looking to add more to my folding collection. PM me.
tmontney is offline
post #2 of 8 (permalink) Old 06-07-2019, 08:02 AM
sok0's Avatar
Rep: 6 (Unique: 6)
If you want to use 2 PSUs, one PSU would be plugged into the motherboard , the PSU that is not plugged into the motherboard has to have a jumper connector that will start the PSU without a motherboard installed. The extra PSU will power only the GPU's that cant be put on the main PSU .
https://www.amazon.com/PSU-Supply-24...0ff748639ac80b
sok0 is offline
post #3 of 8 (permalink) Old 06-07-2019, 08:25 AM
Vermin Supreme 2020
skupples's Avatar
Rep: 737 (Unique: 388)
Add2PSU
I had to do this back while running X79 & 3x vanilla titans, volt unlocked.
I had the GPUs on a 1500W, and everything else on an 850W, worked gloriously with the Add2PSU.
Do NOT just use a jumper. Spend the extra $5 on the board. The onboard hardware makes it an actually safe product & concept.
https://www.amazon.com/s?k=add2psu&ref=nb_sb_noss_2
Add me on Steam, same name
skupples is offline
post #4 of 8 (permalink) Old 06-07-2019, 01:58 PM - Thread Starter
tmontney's Avatar
Yeah, that makes a lot of sense. It only needs to be tied in to be turned on and off by the switch. The power itself would just be to the GPUs.
tmontney is offline
post #5 of 8 (permalink) Old 06-07-2019, 01:58 PM - Thread Starter
tmontney's Avatar
Quote: Originally Posted by skupples View Post
Add2PSU
Yeah, I agree. $5 is nothing in compared to the eventual thousands I'll be spending on this.
tmontney is offline
post #6 of 8 (permalink) Old 06-07-2019, 02:24 PM
Vermin Supreme 2020
skupples's Avatar
specially when that $5 will save you from potentially frying thousands of dollars of GPUs.
I believe the ones with SATA even daisy chain.
skupples is offline
post #7 of 8 (permalink) Old 06-07-2019, 03:47 PM
Shawnb99's Avatar
Rep: 66 (Unique: 47)
Yep I can testify the Add2PSU works beautifully. I've been using one in my media server for years.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is online now
post #8 of 8 (permalink) Old 06-10-2019, 02:53 PM
NewUser16's Avatar
Rep: 56 (Unique: 37)
If you haven't figure out yet, this might help:
NewUser16 is offline
