16AWG cables into 18AWG cable extensions? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 06-28-2019, 06:58 AM - Thread Starter
YaLu's Avatar
Rep: 0
Hi, I bought a Corsair SF 750, and after that I ordered my custom cable extensions (30cm) of 18AWG I discovered that Corsair stock cables are 16AWG.
So... Will be a problem connecting 16AWG cables to 18AWG extension cables?
Amnok
(16 items)
Intel Core i7 3930K
ASUS Rampage IV Black Edition
EVGA GeForce GTX 780 Ti CLASSIFIED Kingpin Edition
Corsair Dominator Platinum 16GB DDR3-2133
Samsung 840 Pro
EVGA SuperNOVA 1300 G2
Swiftech H320 X2 Prestige AIO
Corsair 900D
Operating System
Microsoft Windows 10 Pro
Eizo Foris FG2421
Keyboard
Ducky Shine 3 DK9008
Mouse
Logitech G502
Mousepad
QPAD HeatoN Pro XL
Mousepad
Artisian Hayate Soft
Audio
AKG K7XX Limited Edition
Audio
Nikko NA-540II
YaLu is offline
post #2 of 7 (permalink) Old 06-28-2019, 08:33 AM
*cough* Stock *cough*
Nukemaster's Avatar
Rep: 129 (Unique: 101)
This depends on how much power you are drawing.
Higher current requires larger cables.
Corsair picked 16 for a reason.
Gaming
(15 items)
Media Center
(17 items)
2600K @ 4.4
Maximus IV Gene-z
Asus Dual 1070 OC with Artic Mono Plus
G.SKILL F3-1866C9D-16GXM Ripjaws X 16GB
M4 256
MX 300
Optical Drive
Liteon Slot load
Corsair 850HX
H80i
Silverstone FT03
Operating System
Windows 7 HP 64 bit
BenQ XL2420Z
Keyboard
Logitech G810 Orion
Mouse
Logitech G502
Audio
X-fi Titanium Fatality
i5 750
h55n usb3
msi gtx 650 ti
Corsair XMS3 CMX8GX3M2A1600C9
WDC Red 3tb
M4 128
WDC scorpio Blue 2.5
Optical Drive
Sony AD-7690H-01
FSP SFX 300 watt
Geminii S
SG05
Operating System
Windows 7 HP 64 bit
SyncMaster 245t
Keyboard
Logitech Wave
Mouse
Logitech G9
Audio
Sound Blaster Omni
Other
HD PVR
Nukemaster is offline
post #3 of 7 (permalink) Old 06-28-2019, 08:50 AM - Thread Starter
YaLu's Avatar
Rep: 0
Yes this is what I thought. The stock pcie cable are 1 to 2 splitted 6+2 and in this way is easy to handle a sli o 2x6+2 for each gpu.
I will use just a single 2080 and separated 6+2, without using the splitter.
Amnok
(16 items)
Intel Core i7 3930K
Samsung 840 Pro
Corsair 900D
Operating System
Eizo Foris FG2421
Keyboard
Mouse
Logitech G502
Mousepad
QPAD HeatoN Pro XL
Mousepad
Audio
Audio
Nikko NA-540II
YaLu is offline
post #4 of 7 (permalink) Old 06-28-2019, 09:38 AM
Nukemaster's Avatar
If I trust this website. Others tend to agree as well.
https://www.powerstream.com/Wire_Size.htm
For chassis wiring, 16awg is good for 22A and 18awg is good for 16A. How much voltage loss depends greatly on cable length as well.
Normally you will have 3 x 12 volt wires coming to an 8 pin connector.
A 12 volt connector is good for 150 watts(video cards may draw more at peak).
150/12=12.5A
You should be more than OK with 3 wires to bring 12.5 amps total. The advantage of more wires or larger wires is less voltage loss.
Gaming
(15 items)
Media Center
(17 items)
2600K @ 4.4
Maximus IV Gene-z
M4 256
MX 300
Optical Drive
Liteon Slot load
Corsair 850HX
H80i
Silverstone FT03
Operating System
Windows 7 HP 64 bit
BenQ XL2420Z
Keyboard
Logitech G810 Orion
Mouse
Logitech G502
Audio
i5 750
h55n usb3
msi gtx 650 ti
WDC Red 3tb
M4 128
Optical Drive
Sony AD-7690H-01
FSP SFX 300 watt
Geminii S
SG05
Operating System
Windows 7 HP 64 bit
SyncMaster 245t
Keyboard
Logitech Wave
Mouse
Logitech G9
Audio
Sound Blaster Omni
Other
HD PVR
post #5 of 7 (permalink) Old 06-28-2019, 09:51 AM
NewUser16's Avatar
Rep: 43 (Unique: 29)
If you happen to run anything that takes even slightly more current and power, due to heat transfer your 18AWG might cause your more grief then it's worth. You might be OK but In my humble opinion I would stick with 16WAG, It's not worth the risk of melting your cables and taking other things with it.
NewUser16 is offline
post #6 of 7 (permalink) Old 06-28-2019, 10:34 AM
Rep: 0
16AWG is larger than 18AWG (just making sure peops realize that).
I have experience with Corsair's Premium PSU Cable Kit (in red and black - looks nice), and I had terrible experience with those. They look great and feel great but can't take the heat.
I have literally melted 4 sets of cables, and only found out that those were the culprit after troubleshooting everything else. I also had issues with some coloured extension cables on another PC - same overclock.
Now for context I Overclock an 18-core 7980XE and push it to near 400-500W (not really supposed to), and most of my headaches came from the GPU power cables while overclocking 4x ASUS Strix 1080Ti OC's to above 2050Mhz - those created problems within weeks. Screen jams, black screens, PC freezes, you name it ... found the "charred" (burned) cables and replaced them by some PRO CableMods and so far so good - CableMod pro cables are true 16AWG - I asked them if they would build me some 14AWG's and they refused saying it would be out of specs (understandable).
Makes me wonder how those LN2 overclockers get these processors up to 7.2Ghz and still push power through ??? Makes no sense to me yet. What cables do they use ??? Beats me.
And I held a few world records myself on 3dmark for ages - 10'th last i checked on timespy extreme hall of fame, right above Der8auer :-) (look up Excesseve).
My 2 cents.
excesseve is offline
post #7 of 7 (permalink) Old 06-28-2019, 10:42 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1071 (Unique: 629)
I recently went from a cheap set of Antec 18AWG extensions to a better looking 16AWG extension set.
Didn't have any issues with either, just the 18AWG set looked pretty bad since they didn't fit my cable combs correctly and were impossible to train.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
