PSU issue? PC dropping dead randomly. - Overclock.net - An Overclocking Community
post #1 of 10 (permalink) Old 09-19-2019, 01:12 PM - Thread Starter
jamsomito's Avatar
Rep: 1 (Unique: 1)
Built a new 3900x system with a Gigabyte x570 Aorus Master, 16GB TeamGroup RAM (2x8), and a Zotac 1080ti. I reused my 500GB Sandisk Extreme Pro SATA SSD, and my 6-year old Seasonic x650 650W PSU that had been between 25-50% loaded when occasionally in use for those 6 years. Ran fine for a bit, but I had to RMA the mobo due to a defective debug code LED. Now I'm having a sporatic and annoying issue.
The computer will instantly drop dead, seemingly totally randomly. Everything stops including case fans and RGB headers on the mobo, EXCEPT the mobo RGB lights remain on as if the computer was on. No debug code, and the on-board power switch is red like the PC is off. Case power LED remains on. If I push the power button, the PC starts like normal.
I have tried:
one power cable to the 1080ti with split ends
two seperate power cables to the 1080ti
one 8-pin to CPU power
the other 8-pin to CPU power with a different cable
two 8-pins to CPU power with seperate cables
relaxing my RAM overclock to XMP profile
I changed BIOS
I tried a different wall outlet
I tried a different wall outlet on another house circuit
I have my CPU and GPU on water, and temps are between 50-60F on the GPU and 70-85C on the CPU. I have a number of case fans providing flow over the motherboard. Temps I'd say are fine.
This has ONLY happened in games. The first time I was playing Wildlands for about 2 hours. Later I was playing Borderlands 3 for about 12 hours when it happened, then again after a reboot about 10 minutes later. At this point I tried the 2nd CPU 8-pin power cable and it was fine for another 12 hour session. I played for 10 minutes a few days later and it happened again so I disconnected the first 8-pin CPU power cable. I nearly lost my save file, had to use the backup. Happened after a reboot again another 10 minutes later.
The issue has NOT happened during 48-hour memtest, 4-hour furmark and occt stress tests, any number of benchmarks like cinebench, passmark, or 3d mark. None of these threw any errors either. It has not happened after a few hours of youtube or photo editing in adobe lightroom.
After all this I can only think of a few more things it could be: faulty PSU, faulty mobo, faulty CPU. Before I start throwing money at the problem I thought I'd ask to see what you all thought here. What gives?
jamsomito is offline
post #2 of 10 (permalink) Old 09-19-2019, 01:20 PM
Senior OCN Member
shilka's Avatar
Rep: 2808 (Unique: 1658)
Sounds like the PSU is the problem but not in the way you think and i am not 100% sure on this but from what i recall despite the fact that the X is marketed and labed as a single rail PSU its actually a multi rail PSU
So it sounds like what is happening is you are overloading one of the 12v rails during gaming
Why it does not happend during benchmarking could be because you are seeing a constant power draw where gaming will have spikes of high power draw
Either that or the PSU is just broken
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #3 of 10 (permalink) Old 09-19-2019, 01:46 PM
Destrto's Avatar
Rep: 81 (Unique: 64)
I had a similar issue when adding a 2nd gpu to my old setup. Even with an 850W PSU, it was still being overloaded. It is most likely your PSU not being strong enough.
EK Club XCrossXFire ClubX
-OCN Water Cooling Club-
Destrto
AMD FX-8370
MSI 990FXA-Gaming
AMD PowerColor RX 580
G.Skill - Ripjaws X Series 16Gb
G.Skill - Ripjaws X Series 16 GB
Samsung 850 500Gb
Seagate 3 Tb
Raidmax Vampire 800 Watt
EK-Suprema​cy MX CPU ​Block
XSPC 240mm​ Radiator
EK-XRES 140 DDC 3.2 PWM Elite
HBT Gravity6
Destrto is offline
post #4 of 10 (permalink) Old 09-19-2019, 01:51 PM
Senior OCN Member
shilka's Avatar
A working 650 watt should be more than enough for the system in the OP unless everything in the system is overclocked to high heaven
Speaking about PSU´s the one you have in your rig under your sig is not very good
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #5 of 10 (permalink) Old 09-19-2019, 02:42 PM - Thread Starter
jamsomito's Avatar
Rep: 1 (Unique: 1)
Yeah, I had a Kill-a-Watt attached to it for a while and I was never drawing more than 380W or so for the whole system. My CPU and GPU are never loaded 100% together though. Even if I did, it should be well within the 650W rating of the PSU. Yes, I understand efficiency curves and it's not recommended to run at higher loads frequently... but 50-70% shouldn't be a problem.
Which PSU are you talking about? I can't find anything in my signature. Is it the OCZ Fatal1ty one? Haha, if so that thing is OLD and CHEAP. It started in this case with my old build, but I quickly replaced it with this Seasonic that got great reviews 6 years ago.
post #6 of 10 (permalink) Old 09-19-2019, 02:46 PM
Senior OCN Member
shilka's Avatar
Not your sig its not even visible i was talking to Destrto
And as i said i am pretty sure the Seasonic X are multi rail and that why its shutting off
Edit: did a little digging around and yes i can confirm that at least some of the Seasonic X models are actually multi rail despite all evidence saying they are single but they ARE multi rail
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #7 of 10 (permalink) Old 09-19-2019, 03:02 PM - Thread Starter
jamsomito's Avatar
Rep: 1 (Unique: 1)
Hmm... Could I put the GPU on one rail and everything else on the other? How would I know which ports are which? I'm doing a search right now, will post if I find something.
post #8 of 10 (permalink) Old 09-19-2019, 03:05 PM
Senior OCN Member
shilka's Avatar
Dont how which port goes to which rail but maybe there is info in the manual
The 560 watt model seems to have two rails from what another owner could find out but he never found out how they where split up
There could be 30 amps on one rail and 24 on the other or it could be split 27/27 who knows
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #9 of 10 (permalink) Old 09-20-2019, 08:43 AM - Thread Starter
jamsomito's Avatar
Rep: 1 (Unique: 1)
Well everything I could find about the x650 was that it was indeed a single rail unit. I find it surprising that after 6-years of about a half load that it would be going bad, or that my new configuration is exceeding it's capacity. But, it is not outside the realm of reason so I'm going to try a new PSU.
I went with another Seasonic, the PRIME 750W Platinum: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I like the 12 year warranty but I'll probably just forget about it. The extra 100W might help settle any capacity issues, and the new unit will rule-out if mine's failing or not. Crossing my fingers this does the trick.
Thanks for the help everyone.
post #10 of 10 (permalink) Old 09-20-2019, 11:21 AM
Senior OCN Member
shilka's Avatar
Its not a single rail unit its multi rail its just been hidden behind marketing so you wont find that info outside of the jonnyguru forums and a few other places so like i told you before everything pretty says its a single rail but its not and this is not the first time this has come up
There is probably nothing wrong with your Seasonic X like i said its multi rail and thats why you are having problems
Anyway you bought a better and newer PSU which should be single rail
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
