Seasonic Focus GX 550 550w - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 09-24-2019, 06:15 PM - Thread Starter
wingman99's Avatar
Rep: 63 (Unique: 46)
I did some research and the Seasonic Focus GX is a new product and replaces Seasonic FOCUS PLUS Series.
Seasonic Focus GX LINK: https://seasonic.com/focus-gx
"Seasonic’s engineers have implemented a new design feature, where instead of cables; the back panel and the PCB (Printed Circuit Board) are connected by a copper plate. This breakthrough solution not only lowers the chance of production errors during manual insertion but it also improves output power quality."
"In 2019, Seasonic engineers have made improvements on the popular series, removing the inline capacitors on the supplied cables. Besides the small change in the series naming, the PSU housing and its packaging are also updated to be in line with the concept of the OneSeasonic Initiative."
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #12 of 16 (permalink) Old 09-24-2019, 06:31 PM
Otherworlder
epic1337's Avatar
Rep: 220 (Unique: 127)
"This breakthrough solution"
heh, as if busbars weren't a thing.
on a side note, SS-GX/SGX still has the issue of 3.3v going out of spec in heavy transient loads.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #13 of 16 (permalink) Old 10-24-2019, 01:22 AM
Rep: 7 (Unique: 7)
Quote: Originally Posted by shilka View Post
Buy a Fractal Design Ion+ instead its a better option
they cost more here.
kmetek is offline
post #14 of 16 (permalink) Old 10-24-2019, 03:58 PM
roost610's Avatar
Rep: 0
Quote: Originally Posted by BroadPwns View Post
Overloading is a fancy feature that no one should really care about, ripple differences and efficiency at 100% is completely gimmick. Pretty much PSUs above Gold is pure bourgeoisie that costs WAY more than it's worth and what it lets save.
Please provide some info to back up your clams.
roost610 is offline
post #15 of 16 (permalink) Old 10-24-2019, 05:27 PM
The last VRM burner
Rep: 39 (Unique: 22)
You can check negligible differences in voltage delivery between Gold and Platinum units in jonnygurus reviews. The difference he gets between gold and platinum units are laughable and the latter costs money. PC user also never loads his PSU to let it be close to reach 100% either. 3 percentage points difference between Gold and Platinum in a 750W unit is literally nothing. Economically, it's like this, calculations done for 'muricans:
Daily PC use: 10 hours
Average power consumption by PC components: 75% of 750W (let's say it's a strong PC) = 564W
Electricity cost: 0.1895 USD/kWh
Yearly usage, so 365 days
Gold unit (Corsair RMx):
Efficiency at 75%: 89.3%
Power inlet draw: 632W
Cost: 150USD
10*365*632*0.1895/1000=437 USD
Platinum unit (Corsair HX750):
Efficiency at 75%: 91%
Power inlet draw: 620W
Cost: 175USD
10*365*620*0.1895/1000=428 USD
Through a year you saved 9 USD, you need three years to make it pay for itself at constant typical load, you could spend that 25 dollars on a beefier motherboard, in example. Unless it's a difference of a quite a sum of devices - it's a wasted cash. Of course, as a society we should go for highest energy savings as possible and it's good that power supplies grow more efficient. Economically, it has little sense for a single household unless it goes for efficient devices from the very start. Now, PSU life expactancy highly depends on overall build quality and used electronic parts, and there's honestly barely any difference between ~750W top Gold units. Ripple has been brought to a level that no longer means anything. I'm avoiding the fact that very strong (1kW+) units are pretty much Platinium and Titaniums only on purpose, because their rating usually just goes along the way with power supply capability (well, higher quality PC PSUs at least do so)
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
Still looking for a decent kit because holy sheit, the prices
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #16 of 16 (permalink) Old 10-24-2019, 06:06 PM
roost610's Avatar
Rep: 0
Cost: 150USD
Cost: 175USD
Ok thanks for posting, makes sense. Ripple has my interest atm as im in the market for psu. From what I gather like you mentioned most quality units provide smooth power delivery. As long as it's in spec, filter caps on mb/cards take care of rest.
roost610 is offline
