How do multi rails in a power supply work in conjunction with a graphics card? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 35 (permalink) Old 09-27-2019, 05:28 AM
Rep: 12 (Unique: 11)
Quote: Originally Posted by computerdude92 View Post
I only use older computers from 5+ years ago, with no plans to get anything newer cause modern computers have built in backdoors and spying.
If you use older hardware because your concerned about back-doors and spying but you use modern programs (web-browsers, anti-virus, games, ETC) your still vulnerable because "back-doors" are a result of programs. Even older hardware has vulnerabilities, Specter and Meltdown affected generations of Intel chips. Hardware doesn't run without a program and firmware IS another type of program, one that is not stored in volatile memory like your web browser is or any program you run on your PC. If you install the updates for your system (BIOs, drivers, program updates) that "patch" vulnerabilities then before you installed the patch/update you were exposed to that threat.
The ONLY way to avoid backdoors and spying is to cut the cord and go off the grid completely. If you won't do that then keep your system up to date, use good AV, run a paid VPN (because free VPNs are junk), and protect your connection to the internet with something better than a 5+ year old off the shelf from Walmart router that is no longer supported, learn about network security and monitor your connection to the outside world.
Modern hardware is no more or less vulnerable than older hardware it is slower and more power demanding so all your accomplishing in using 5+-year-old hardware is limiting your productivity and contributing more to your electric companies profit margin with your higher power consumption.
Open Air Build
i9
ASUS ROG Strix Z390-H Gaming
MSI GEFORCE GTX1080 TI GAMING X 11G
Corsair Vengeance LPX DDR4 DRAM 3000MHz
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
All PrimoChill parts (Rad 360, Pumps D5, Fittings, and Acrylic Tubing), Byskey CPU&GPU Blocks
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Thermaltake Commander F6 Fan Controller
Other
DIY Sleeved Cables
smilinjohn is offline
post #12 of 35 (permalink) Old 09-27-2019, 05:45 AM
Senior OCN Member
shilka's Avatar
Rep: 2771 (Unique: 1641)
If Specter Meltdown and all the other problems have you so worried buy AMD instead
And like smilinjohn said it sounds like you have a fundamental misunderstanding of modern PC hardware and all you are doing is holding yourself back and paying more for no reason and you are not making yourself safer
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
EVGA SuperNova G2 750 Watt
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is online now
post #13 of 35 (permalink) Old 09-27-2019, 06:24 AM
Oh come on now don't put my example of Specter and Meltdown on the OP, I brought that up not them...
The brand doesn't matter, vulnerabilities exist. When MS patches a vulnerability it patches its OS, doesn't matter if that OS is running on AMD or Intel. Both are just as open to the threat because it is a matter of the programming running on the chip regardless of which you are a fan-boy of.
True some hardware has its unique vulnerabilities, but those are .01% of the threats out there. The other 99.99% comes from the programing running on all of our computers, AMD, Intel doesn't matter one iota.
Open Air Build
i9
Samsung 970 EVO
WD Blue
EVGA SuperNOVA
Praxis Wet Bench
Operating System
Windows 10 Pro
Asus Predrator
Other
Other
DIY Sleeved Cables
post #14 of 35 (permalink) Old 09-27-2019, 06:38 AM
skupples's Avatar
Rep: 624 (Unique: 342)
i uh... too early.
pi hole, and exactly while Smilin' said. You're just hurting yourself with zero net gain in safety or security. Not to mention all while using 3-5x the power.
big brother is big brother, you aren't outsmarting him. You might as well pack up & go live in the woods, as that's the only way you're gonna be "safe" from all this.
good luck, and pick up a book, or a guide every once in awhile. there are a few things you can do to create a more secure environment, if you're really that paranoid. Using antiquated hardware just isn't on any of those lists, unless we're playing games of thermonuclear war.
pi hole
vpn
up 2 date software/OS
proper password policy enactment.
pucker.
yeah AMD's new stuff is "more secure"... for now. It's brand new, that's kinda how it works. Core is nearing EOL, so it'll keep bleeding til it finally dies.
skupples is offline
post #15 of 35 (permalink) Old 09-28-2019, 12:23 AM - Thread Starter
Retro Computer Expert
computerdude92's Avatar
Rep: 3 (Unique: 3)
Regardless, I'm still safer using dated hardware. Not perfect, but better off.
I'd use anything online that's no newer than the Piledriver architecture for AMD chips. For Intel nothing newer than Pentium 4, Pentium M, maybe Core Solo/Core Duo, as those are the newest Intels that are safe to use cause they lack the Intel Management Engine. I understand that someday I may be left behind, as those that don't upgrade, but that is a consequence I am willing to accept. I'll retire from the internet.
I'm not really against the Spectre/Meltdown patches, but these are the last x86/x64 based computers i'll use. If anything i'll try some kind of safe open source hardware bundled with Linux someday.
Not all old computers are heat dumpers.
I see that Intel refused to patch some older chips, I don't know if they patched any earlier chips like the Pentium III or Pentium Pro, but I've heard nothing from AMD.
WINDOWS XP FOREVER
Custom AMD FX PC
(16 items)
AMD FX-8300
ASUS Crosshair V Formula-Z
XFX Radeon R5-220
8GB DDR3 1866 ECC
500GB Western Digital SATA II
Optical Drive
DVD-RW drive
Thermaltake TR2 500W
Set of 120MM case fans
Skythe CPU cooler with single 120MM fan
Cybertron case
Operating System
Windows 8.1 Standard
23" Samsung SyncMaster P2370HD
Keyboard
Vintage Hewlett Packard 5183-9980 Multimedia keyboard
Mouse
Vintage Beige and transparent red Logitech M-BD69 USB mouse
Mousepad
Custom made mousepad cut from an old antistatic mat
Audio
Onboard Realtek ALC888 HD audio
Opteron 6262 HE
Supermicro H8SGL
Nvidia Quadro K620
32GB DDR3L 1600 ECC
Hitachi 320GB Sata II
Optical Drive
Asus BD-R drive
600W Seasonic OEM
Dynatron A14
NZXT Adamas
Keyboard
Mouse
Mousepad
Audio
Creative Audigy SE PCI
computerdude92 is offline
post #16 of 35 (permalink) Old 09-28-2019, 01:08 AM - Thread Starter
Rep: 3 (Unique: 3)
Call me crazy, misinformed, or a loser, but I feel it's my duty to warn people of bad, unethical technology and all it's dangers. It's the right thing to do. You can read the "Hardware Compatibility" section of the link below to better understand where I'm coming from.
https://libreboot.org/faq.html
WINDOWS XP FOREVER
Custom AMD FX PC
(16 items)
AMD FX-8300
XFX Radeon R5-220
8GB DDR3 1866 ECC
Optical Drive
DVD-RW drive
Cybertron case
Operating System
Keyboard
Mouse
Mousepad
Audio
Opteron 6262 HE
Supermicro H8SGL
Nvidia Quadro K620
32GB DDR3L 1600 ECC
Optical Drive
Asus BD-R drive
600W Seasonic OEM
Dynatron A14
NZXT Adamas
Keyboard
Mouse
Mousepad
Audio
post #17 of 35 (permalink) Old 09-28-2019, 07:15 AM - Thread Starter
Rep: 3 (Unique: 3)
backdoors and spying what the.... have you ever heard of getting a VPN in that case
How is a VPN going to stop built-in hardware backdoors plus the spying coming from the operating system, like Windows 10? Also I wouldn't think that defeating the flaws of the Intel Management Engine would be that simple, no offense.
WINDOWS XP FOREVER
Custom AMD FX PC
(16 items)
AMD FX-8300
XFX Radeon R5-220
8GB DDR3 1866 ECC
Optical Drive
DVD-RW drive
Cybertron case
Operating System
Keyboard
Mouse
Mousepad
Audio
Opteron 6262 HE
Supermicro H8SGL
Nvidia Quadro K620
32GB DDR3L 1600 ECC
Optical Drive
Asus BD-R drive
600W Seasonic OEM
Dynatron A14
NZXT Adamas
Keyboard
Mouse
Mousepad
Audio
post #18 of 35 (permalink) Old 09-28-2019, 07:26 AM
skupples's Avatar
key phrase "more secure" not totally secure.
flawed is flawed.
and a computer is a computer
user's worried about hacky hacky? Time to move to the woods, only way to truly prevent all attacks
skupples is offline
post #19 of 35 (permalink) Old 09-28-2019, 07:35 AM - Thread Starter
Rep: 3 (Unique: 3)
Quote: Originally Posted by skupples View Post
pi hole
vpn
pucker.
I found the others on the list but not this thing you call "pucker"
I'm always on the lookout for new information. Though to tell you the truth, networking and advanced software is my weakness. I'm just the hardware guy who builds computers, installs the OS and plays around with it, and use basic programs and play games. I go with what's familiar to me, as I remember the good old days. I don't know what VPN's are trustworthy. Some will trick you.
WINDOWS XP FOREVER
Custom AMD FX PC
(16 items)
AMD FX-8300
XFX Radeon R5-220
8GB DDR3 1866 ECC
Optical Drive
DVD-RW drive
Cybertron case
Operating System
Keyboard
Mouse
Mousepad
Audio
Opteron 6262 HE
Supermicro H8SGL
Nvidia Quadro K620
32GB DDR3L 1600 ECC
Optical Drive
Asus BD-R drive
600W Seasonic OEM
Dynatron A14
NZXT Adamas
Keyboard
Mouse
Mousepad
Audio
post #20 of 35 (permalink) Old 09-28-2019, 07:38 AM - Thread Starter
Rep: 3 (Unique: 3)
Boy.. if only computers weren't so damn fun. :-D
WINDOWS XP FOREVER
Custom AMD FX PC
(16 items)
AMD FX-8300
XFX Radeon R5-220
8GB DDR3 1866 ECC
Optical Drive
DVD-RW drive
Cybertron case
Operating System
Keyboard
Mouse
Mousepad
Audio
Opteron 6262 HE
Supermicro H8SGL
Nvidia Quadro K620
32GB DDR3L 1600 ECC
Optical Drive
Asus BD-R drive
600W Seasonic OEM
Dynatron A14
NZXT Adamas
Keyboard
Mouse
Mousepad
Audio
