power consumption TEST - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 10-10-2019, 01:38 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Rep: 37 (Unique: 29)
Did a test to see how much juice I could pull from the wall. Wanted to see how much PSU I "need" since my EVGA 1300G2 experienced a spectacular failure. I conducted this test using an older Silverstone 1200.
Test setup specs:
9900K @ 5.4, 1.50V no HT
(Cooled with 23c water, 360 radiator, 3x2200rpm fans, open air)
16gb (2x8) trident z 3200c14 @ 4133c16 1.50v
EVGA Z390 Dark mobo
Titan RTX @ 2085/8500, air cooled, no shunt mod
Samsung 970 evo plus 250gb nvme ssd
Measured at the wall using a kill-a-watt:
Idle Power: 135W
100% GPU load: 546W
100% CPU load: 374W
Both 100% load: 694W
For GPU load, I ran Unigine Heaven. The Titan RTX was at the power limit the whole time, and adjusted its clocks to match. For CPU load, I used prime95 smallFFT no AVX.
Unigine needs about 2 CPU cores to itself otherwise it will drop to, like, 2 fps and unload the GPU. So for the full load test, I set prime95 to run on 6 cores. In task manager, I assigned it specific cores. I then let Heaven run on the remaining 2. Oddly, if I set heaven's affinity in task manager to the 2 remaining cores, it would also slow down to 2 fps. So I let it figure out on its own and it loaded the GPU to 100%.
This is probably not a "real world" use case, as almost all games would use less power. Most games wouldn't load the CPU anywhere near as much as they tend to use different instruction sets than P95. And many games do not use 8 cores, or use all cores to 100%. But it is interesting to test a worst case scenario and view the results. I suspect I could probably pull more power with the CPU if I enabled HT and dropped clocks to 5.2-5.3. But again, can't imagine a game using 16 threads and 100% gpu simultaneously.
This tells me I would be okay with an 850W PSU. If I put a waterblock and shunt mod the Titan, and insulate everything to go subzero, my guess is I could add 100W to the GPU and 50W to the CPU. Maybe a 1000W would be better for such experimental purposes.
CHILLER DESTRUCTION
Build Log - White Voodoo
basic linux pc
(15 items)
Z390 Station
(11 items)
7980XE @ 4.3 GHz 1.10v
Asus Rampage VI Apex
2 x Aorus Waterforce WB 1080 Ti @ 2037/6318
Trident Z 16gb 3200c14 @ 3800c16 1.50V (the other two sticks were sacrificed)
960 Evo 1TB
EVGA 1600 T2
HWLabs GTR 420+280 Rads
7 x Noctua Industrial 140mm 3000 RPM Fans
EK D5 Pump/Res (with RGB!)
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Razer Blackwidow Chroma V2
Mouse
Logitech M510
Mousepad
anime tiddy mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
Trident Z 3200c14 @ 4600c20 1.5v
970 Evo Plus 250gb
silverstone 1200 from 2008 (other one exploded)
HWLabs GTX 360 Rad (in RED)
3x EK Vader 120mm 2200rpm Fans
Dimastech Test Bench
AOC Agon AG251FZ 240Hz
Audio
Built-in Monitor Speakers (3 watt)
Dual Intel Xeon L5520 2.26 GHz
48 GB Samsung DDR3-1066
120 GB Samsung 750 Evo SSD
2 TB Western Digital Green
2 TB Hitachi 7200 RPM
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
Hydroplane is offline
post #2 of 5 (permalink) Old 10-10-2019, 02:12 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1243 (Unique: 681)
Yep, people overestimate how much power they really need and most people never put a simultaneous 100% load on their CPU and GPU.
I tripped OCP with my 9900K @ 1.4v and the XOC BIOS on my 1080 Ti, but at my daily OCs on both my GPU and CPU I struggle to pull more than 600W doing anything and generally don't pull more than 400W.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 5 (permalink) Old 10-10-2019, 06:33 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
Probably the only thing that makes a huge difference would be a 2nd GPU (+300-400W). Maybe a big core count CPU like 7980XE or 2990WX (~+150W). With 1080 Ti SLI OC and a 7980XE @ 4.7, I managed to hit 1309W from the wall on the same test. Actually managed to justify buying a 1600W PSU. The lights would dim when I hit the "run" button in P95 lol
People could have hit even more back in the days of 3-4 way SLI. I used to run quad 4870x2 and would pull 750w just gaming
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
post #4 of 5 (permalink) Old 10-12-2019, 02:31 PM
wingman99's Avatar
Rep: 63 (Unique: 46)
My PC in my signature with gaming and prime95 small FFTs AVX disabled draws 353watts from the wall. My PSU is Seasonic GX 550w 90% efficiency, so the PC is really drawing 317 watts from the PSU.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #5 of 5 (permalink) Old 10-12-2019, 05:48 PM - Thread Starter
Hardware Princess
Hydroplane's Avatar
That sounds roughly correct depending on accessories, etc. Either that or the 2 extra cores only added 21 watts lol
CHILLER DESTRUCTION
basic linux pc
(15 items)
Z390 Station
(11 items)
960 Evo 1TB
EVGA 1600 T2
LD Cooling PC-V7
Operating System
Linux Mint 19.6
NEC PA271W
Keyboard
Mouse
Logitech M510
Mousepad
9900K @ 5.4 1.50v
EVGA Z390 Dark
Titan RTX 2085/8500
970 Evo Plus 250gb
Audio
650W Delta PSU
1U Rackmount
Operating System
Ubuntu Server 16.04
