Safe to asume my psu needs replacing? - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 10-22-2019, 10:10 AM - Thread Starter
roost610's Avatar
Rep: 0
Running a AX860 with a 4790k R9 290x. My goal is to oc the 290x but any time I up the voltage I get weird inconsistent results, screen flickering, black screen, ect, more voltage more issues. I also noticed GPU-Z reads 11.4v on the 12v rail under load. I know it's just a software reading but from the above mentioned is it safe to assume faulty psu? Thanks
I should also add my temps are good including vrm's, nothing above 70c
roost610 is offline
post #2 of 15 (permalink) Old 10-22-2019, 10:20 AM
Senior OCN Member
shilka's Avatar
Rep: 2773 (Unique: 1641)
Software readings are a not accurate way to read voltages so no you should not asume your PSU is faulty it might as well be your GPU
If you want accurate readings you need to use a digtal multi meter
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
EVGA SuperNova G2 750 Watt
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #3 of 15 (permalink) Old 10-22-2019, 10:32 AM - Thread Starter
roost610's Avatar
Rep: 0
Ok I'll do some testing later. Any ideas what point to probe?
Picture if that helps
roost610 is offline
post #4 of 15 (permalink) Old 10-22-2019, 10:48 AM
Senior OCN Member
shilka's Avatar
Start with end of the PSU cables you can find pictures on google showing you which pins are for what and what voltages they are supposed to have
Dumpster fire
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
G Skill TridentZ
Phanteks Luxe 2
Operating System
Asus PG279Q
LG 55C8
Keyboard
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
AOC 24G2U
Keyboard
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
shilka is offline
post #5 of 15 (permalink) Old 10-22-2019, 11:13 AM
wingman99's Avatar
Rep: 63 (Unique: 46)
You can ground the negative to the chassis, with DC voltage reading prob the points you have shown in the screenshot. The reading can be +-5% on 12v
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
ASUS VG279Q 27" 1920x1080p 144Hz IPS panel G-Sync compatible
wingman99 is offline
post #6 of 15 (permalink) Old 10-22-2019, 11:26 AM
The last VRM burner
Rep: 39 (Unique: 22)
Depending on a motherboard, the +12V reading where's a bunch of voltage readings will be bullbrownstuff. In the following column with VRM reading there should be another +12V reading and that one is correct. I had a case of 11.4V readings with a Corsair CS650M PSU, but I was not able to find such table on the entire motherboard, all multimeter readings were 11.9-11.96V - same as the aforementioned reading.
PC for all
(21 items)
i7 5775c @4.2GHz/3.8GHz
Gigabyte Z97X Gaming 5
Soon to be 2070 Super FE
Still looking for a decent kit because holy sheit, the prices
Corsair MP510
Samsung Evo 860
Seasonic Focus Plus 750W
Artcic Liquid Freezer II 360mm
Arctic P12 PWM x2
Arctic P14 x4
LianLi 330X
Operating System
Windows 10 64-bit Pro
Samsung C24FG73FQUX
Benq GL2250 80Hz
Keyboard
Corsair Strafe Red Silent + 1.6x6mm o-rings
Mouse
SteelSeries Rival 600
Mousepad
Artisan FX Raiden
Audio
Audio in Motion SC808 + MUSES8820 + 2x 2xLME49990
Audio
AKG M220
Other
NZXT Hue+
Other
Mayflash F300 Arcade Stick
BroadPwns is offline
post #7 of 15 (permalink) Old 10-22-2019, 06:03 PM - Thread Starter
roost610's Avatar
Rep: 0
Got time to test it with the meter. At idle it reads 11.98, under load 11.85. I just poked around till I found the lead that was effected by load, turned out to be #1 ground #2 positive in the pic.
So with the +-5% wingmman mentioned that should be alright correct? Appreciate the help.
roost610 is offline
post #8 of 15 (permalink) Old 10-22-2019, 06:16 PM
wingman99's Avatar
The 12v reading you acquired is well within tolerance. So the 12v voltage is fine. LINK: https://www.lifewire.com/power-suppl...rances-2624583
i5 8600K OC 5.0GHz
Noctua NH-U14S
post #9 of 15 (permalink) Old 10-22-2019, 06:32 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1237 (Unique: 679)
measuring the 12v rail of your PSU and saying it's good is the PC equivalent of kicking a car's tire and calling it mechanically sound because it's not flat lol.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #10 of 15 (permalink) Old 10-22-2019, 06:45 PM
wingman99's Avatar
Op a more accurate test would be to load the graphics card with a game then probe the reading on the 12v rail.
i5 8600K OC 5.0GHz
Noctua NH-U14S
