So I've replaced my old PSU with Corsair RM650i - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 11-04-2019, 04:48 PM - Thread Starter
Rep: 58 (Unique: 39)
Old PSU: Silverstone SST-ST85F-G Strider Gold 850W (2010 model)
Thoughts:
-I am getting like 5-7 degrees lower temps for my GPU under load.
- Annoying grinding sound from Silverstone's cheap China fan is gone. Could not stand it which is why I bought this specific model.
- Corsair PSU is COMPLETELY SILENT while gaming. Fan doesn't even work under load (but it does work when I press the fan test key).
- Corsair PSU temp under load is 39.5 Celsius.
- Removing all old cables and installing the new ones was so annoying that I wish I knew some kid that could do the job for like $50. I felt really stupid because I did all the work myself.
- Cable management is annoying like hell, I just wanted to get it over with asap.
- Corsair PSU felt and handled like a premium unit.
- Old PSU works just fine still after like 6+ years.
- Corsair Link is cool. Could have saved like $10 if I went for the non i version but I said to myself just "naaaaaahhhhh". I hope that God will never get me to the point I'd really need to clip $10 from my rig's PSU like some other folks, heh.
- Gave Seasonic a thought. Had a look at the equivalent model to Corsair's 650i and it had a switch on that disabled the fan if one wanted silent operation. Then I mentally saw myself getting up and then diving behind the case every day to switch the freaking fan on and off. Once again I said "Naaaaaahhhhhh". The fan curve on the 650i is programmable through Corsair Link at few clicks of a mouse button. So convenient.
- The fact that this is perhaps one of the most silent PSU's in the market today was the only reason why I bought it. Corsair Link and programmable fan curve was the other.
ANANDTECH Evangelist
Arxontas is offline
post #2 of 6 (permalink) Old 11-04-2019, 04:56 PM
Graphics Junkie
UltraMega's Avatar
Rep: 49 (Unique: 44)
make sure you use the same program to check GPU temps that you used before.
Also note, not sure where you live but its gotten a lot colder where I am recently. It's possible your ambient temps are also lower.
A lot of people on here will hate on corsair PSU's but I think they are pretty solid for a medium quality PSU aimed at gaming configs.
Also, not really sure what corsair link does with a PSU. I have it but I use it to control the fans on my corsair heatsink.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #3 of 6 (permalink) Old 11-04-2019, 05:05 PM
Lurking Veteran
Sealz's Avatar
Rep: 4 (Unique: 4)
I've used corsair in multiple builds for multiple different purposes. Home server, data storage, and gaming. Never had a single problem. Ever. Not sure where the bad rep comes from.
Sealz is offline
post #4 of 6 (permalink) Old 11-04-2019, 05:11 PM - Thread Starter
Using Real Temp both before and after. Ambient was more or less the same today and yesterday so I am positive the readings are right on.
Old Silverstone unit was 1.5 times larger than Corsair unit and it ran hot, so hot that the fan was always on and running even at low loads (sub 100W).
I am guessing that old Silverstone unit was causing the air above it to get hotter which was then taken in by the GPU's fans to cool the GPU thus resulting into higher temps.
Further, the Corsair PSU can power 1 GPU fully with just 1 cable because there's both an 8pin and 6 pin plug on the very same cable whereas the Silverstone PSU required
two cables, 1 8 pin and 1 6 pin to power the same GPU.
I guess 1 PCIE cable less should also bring the GPU temperature down somewhat.
Arxontas is offline
post #5 of 6 (permalink) Old 11-05-2019, 09:18 AM
Senior OCN Member
shilka's Avatar
Rep: 2802 (Unique: 1655)
You seems to have misundersood how the hybrid fan mode works
If you turn it on the fan will be off untill you hit a high enough load and/or temp
Turn the hybrid mode off leaves the fan on all the time
Corsair units dont give you the option to have it on or off its always on with no switch which is one reason not to buy one if you want the option to have it on or off
The RMi is not better than the Seasonic Focus or the Fractal Design Ion+ but it cost a lot more so you pretty much picked the most overpriced of the 3
Edit: actually looking at the Ion+ its better its cheaper its more quiet it has higher efficiency and there is an on/off switch for the hybrid fan mode
You paid more for something that is in almost every way worse
Dreissen
(27 items)
Seravee
(18 items)
Ryzen 3700x
Asrock x570 Taichi
MSI RTX 2070 Super Gaming X Trio
G Skill TridentZ
Corsair Force MP510 1,92 TB
Seagate IronWolf Pro ST14000NE0008
Seagate Ironwolf ST12000VN0007
Seagate IronWolf Pro ST12000NE0007
WD Ultrastar DC HC530 14 TB
Seagate IronWolf Pro ST16000NE000
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-U12S Chromax
Phanteks Luxe 2
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mousepad
HyperX Fury S XL
Audio
Onkyo TX NR646
Audio
RHA L1 Dacamp
Audio
Sennheiser HD 599
Audio
Dali E 12 F
Audio
2x Dali Opticon 1
Audio
2x Dali Opticon 2
Audio
Dali Opticon Vokal
Other
Vegas MBA 60cm LED Strip
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
GTX 1060 3 GB wth blower style cooler
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Samsung 860 Evo 1 TB
Optical Drive
LG CH12NS30
Seasonic Focus GX 650 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
AOC 24G2U
Keyboard
Corsair Gaming STRAFE RGB Mechanical
Mouse
Roccat Kone EMP
Mousepad
Roccat Sense Metor
Audio
Sennheiser HD 598
Other
CableMod 30 CM Magnetic Red LED strip
LG 24MP59G-P
Mouse
Logitech MX518 Hero
Other
Delock PCI-E to M.2 NVME Adaptor Card
shilka is offline
post #6 of 6 (permalink) Old 11-06-2019, 02:40 PM - Thread Starter
"I seems to have misunderstood" and "I picked the most overpriced"
Hahaha.
I think I'll live past through it man. I guess I won't offload so much to hookers and blow for a week or two to make up for the "overpriced" Corsair unit.
The "overpriced" corsair unit doesn't even cost half of what the bungee bars of my Harley_Davidson motorcycle do.
Arxontas is offline
