Corsair 24 pin power connector with another brand sleeved extension + question? - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 01-22-2020, 04:21 PM - Thread Starter
Emiliano85
Emil Debski's Avatar
Rep: 0
Hi guys.
I am literally minutes from finishing my first ever build (Ryzen 3950x + Asus RTX 2080Ti), but now i am getting confused in regards of the PHANTEKS SLEEVED EXTENSION CABLE COMBO i've bought for my rig:
http://www.phanteks.com/images/produ...BCMBO_BK-1.jpg
Specs:
Length: 19.68in (500mm)
Wire AWG: 18AWG, 2.1mm(Rohs)
Sleeve Tube: PP Material
Insulation Resistance: 20M ohm @ 200VDC
Short/Open Determinant: 20K ohm
My PSU is the Corsair RM850x, which (from the limited info i managed to obtain of the internet) also utilizes 18AWG wiring per this link off of TomsHardware:
https://www.tomshardware.com/reviews...-psu,5568.html
Specs:
ATX connector 20+4 pin (600mm) 18-20AWG
4+4 pin EPS12V (650mm) 18AWG
6+2 pin PCIe (600mm+150mm) 18AWG
SATA (500mm+110mm+110mm+110mm) 18AWG
SATA (520mm+110mm+110mm) 18AWG
Four-pin Molex (450mm+100mm+100mm+100mm) 18AWG
FDD Adapter (+100mm) 20AWG
AC Power Cord (1430mm) - C13 coupler 16AWG
Question #1: Would it be ok to use these extensions with my PSU in this case?
Another thing that got me confused was the fact that Corsair are using gen 3 on some of their PSU's and gen 4 on others, when it comes to cable connections. From my understanding it only affects the 24 pin main power connector. My PSU is gen 4. Here is the difference between gen 3 and 4:
Gen 3: https://i.gyazo.com/ce6426be693927e6...4a6d691fac.png
Gen 4: https://i.gyazo.com/d19b436d0e018ef1...364886478b.png
Question #2: The change only seems to affect the "PSU END" of the cable, which makes me believe that the "MOBO END" is the same on both, and should not affect which kind of extension i need to look after - the one above seems to be compatible regardless of gen 3 or gen 4 right?
And last but not least, the stock PCIe power connector cables coming with my Corsair PSU, are of this type (ONE 8-pin end at the "PSU END" splitting into TWO x 6+2pin cable ends at the "MOBO/GPU END"):
https://i.ebayimg.com/images/g/CmIAA...m1r/s-l300.jpg
Where as the sleeved PCIe extension cables coming with my Phanteks kit are TWO individual/seperate single cable extensions:
https://images-na.ssl-images-amazon....4L._SX425_.jpg
Maybe a dumb question (better to be save than sorry when having used nearly 5000$ on a new rig though):
Question #3: Do i just connect the TWO single PCIe cables coming with my sleeved kit to each of the two "MOBO/GPU ENDS" on my double headed stock PCIe cable from Corsair? I don't really see other ways to do it, as long as the 2 sleeved extensions are single ones, and not a Y-type 2 in 1 cable like the stock one. Unless i connect the sleeved extensions into two seperate slots on the back of my PSU (it has more than one PCIe slot). What i'm trying to say/ask is basically if it makes any difference if the two PCIe ends going into the GPU comes from a single cable splitting into 2 ( Y ) compared to coming from 2 seperate cables ( I I ).
Hope it all makes sense. Sorry for the lenghy thread to what i bet are dead simple questions for somebody with a little more experience in building than me.
Looking forward to hear from you guys.
Thanks!
Emil Debski is offline
post #2 of 3 (permalink) Old 01-24-2020, 05:09 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1261 (Unique: 688)
extensions are universal, you plug them into the cable. the end of the cable is standard, the end that plugs into the PSU are not (they're vendor and often model specific). if the ends were not standard then you'd have to match your PSU to specific components.
if you're plugging an extension into a PSU you're doing something wrong but you shouldn't be able to in the first place.
if your PSU is janky then run two separate PCI-E lines from the PSU to your GPU, but just run what looks the best or is the easiest to do. I only run one cable from my PSU to my 1080 Ti and even when I was playing with the XOC BIOS I didn't have any issues.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #3 of 3 (permalink) Old 01-24-2020, 05:18 PM
TheBDK's Avatar
Rep: 22 (Unique: 18)
As the other guy said, extensions are indeed universal. They'll work just fine.
Look at the back of your PSU .. CPU PCIE (both 8 pin) will work in either. 6 pins are for hdd/ssd/etc.
The only thing you need to worry about is the motherboard 18/24pin+10/4/8pin.
TheBDK is offline
