Can changing modes be due to my PS? - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 03-23-2020, 12:45 AM - Thread Starter
Overdrive
hdtvnut's Avatar
Rep: 0
I have a Seasonic Prime Titanium 850w PS I have used with two Asus MB's, M10 Hero and M11 Apex, with different CPU's, 8700K and 9900KS. In both setups, the system mode will switch from "hi Performance" or "Balanced" to "Power Saver" after 30 to 100 minutes of on time. Then after a few more minutes from "Sleep: never" to "Sleep: after 1 minute". The systems are at idle, and no warning in HWM or HWMonitor when it's going to happen. ????
Z390: CPU 9900KS; MB Asus Maximus XI Apex; GPU Asus RTX2080ti OC; RAM Tridentz 2x8 4266 C19;
Drive Sam 970 EVO 500GB; PS Sea 850w Titanium; Cooling Opt Sig V2, EK 100/D5, EK PE 360
X299: CPU 7980XE; MB Asrock OC Formula; GPU EVGA GTX1080ti FTW3; RAM LPX 4x16 3200 C16;
Drives Sam 970 EVO 500GB, WD 4TB; PS Sea 1kw Platinum; Cooling Wc HK IV, EK 140/D5, HL 360GTX
hdtvnut is offline
post #2 of 9 (permalink) Old 03-23-2020, 01:49 AM
Meep
Gilles3000's Avatar
Rep: 330 (Unique: 234)
Sounds more like a wacky windows 10 issue to me.
Not sure this could be the issue, but are you logged into windows with an account, or just local?
Gilles3000 is offline
post #3 of 9 (permalink) Old 03-24-2020, 05:14 AM - Thread Starter
Overdrive
hdtvnut's Avatar
Rep: 0
On an account with automatic updates.
hdtvnut is offline
post #4 of 9 (permalink) Old 03-24-2020, 05:20 AM
Meep
Gilles3000's Avatar
Its possible that there's an issue with a setting tied to your account, I'd try installing W10 again, but with internet disconnected and select a local account instead.
Updates should be fine tho, you can just connect to the internet after the install is finished, and do all the updates required.
post #5 of 9 (permalink) Old 03-24-2020, 03:09 PM - Thread Starter
Overdrive
hdtvnut's Avatar
Rep: 0
How about I disconnect from the internet and see if the down-mode still occurs? If it doesn't, then it would have to be an account problem.
hdtvnut is offline
post #6 of 9 (permalink) Old 03-25-2020, 08:07 AM
Meep
Gilles3000's Avatar
wouldn't change a thing, as its the configuration done by logging into your account that the issue. Disconnecting from the internet does nut undo any settings.
A clean windows install with a local account and as much of the telemetry tuff denied is the best way to install it anyway.
post #7 of 9 (permalink) Old 03-29-2020, 04:02 PM
Overclocker
JackCY's Avatar
Rep: 358 (Unique: 255)
Use local accounts. Remove infections. This is not a PSU issue XD
PSU can't magically start changing your OS settings.
You should be using ultimate performance plan anyway.
JackCY is offline
post #8 of 9 (permalink) Old 03-29-2020, 04:33 PM
Food Editor
skupples's Avatar
Rep: 720 (Unique: 378)
this is software, if you're referring to windows power settings.
is it an OEM install?
sounds like a synced windows account pulling policies from somewhere. did you log into your work office 365 recently, and mistakenly click yes on the management screen?
re-install with Win10s Enterprise LTSC or server grade
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #9 of 9 (permalink) Old 04-01-2020, 02:41 AM - Thread Starter
Overdrive
hdtvnut's Avatar
Rep: 0
Thanks guys - I'll re-install with local when I get a chance. Don't remember where this install is from. Don't know much about Win10; what does "ultimate performance" mean?
hdtvnut is offline
