Bought a powersupply from newegg, comes with Non USA plug - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 05-18-2020, 08:18 PM - Thread Starter
andyroo89's Avatar
Rep: 80 (Unique: 67)
This is the first time I encountered something like this. So, I ordered corsaie hx 1200 psu here. https://www.newegg.com/corsair-hx-se...82E16817139205
The plug seems to be Type F, and I have extra AC power plug I can use, but I am not sure if it will be okay, or if I need to return it, I double checked and the product code has "NA" at the end on newegg. I waited all last week and this weekend to receive this only for this to happen.
I don't want to risk smoke or anything when I plug it in.
edit; it says 100-240v 47-63hz, so that means it should be okay right?
If you come across cute ginger girls and have pics pm me them :3
<In my avatar, IDK but TheODDone gave me this one <33
andyroo89 is offline
post #2 of 11 (permalink) Old 05-18-2020, 08:52 PM
Rep: 961 (Unique: 706)
look for the amps on the cord most cords have amp rating wrote on them then compare it to the one you got from newegg website is showing 7.5-15amps so you might need a better cord if yours cant handle 15amps.
Input Current 15 - 7.5 A
Midnight Madness
(17 items)
AMD RYZEN 9 3900X
ASUS AMD AM4 ROG Strix X570-E
EVGA GTX 1080 FTW Hydro Copper
G.SKILL TridentZ Series
Samsung EVO 850 500
SeaSonic M12D SS-850 850W
EK-SBAY Dual DDC 3.2 PWM Serial
Alphacool NexXxoS ST30 Full Copper Radiator 360
Hardware Labs Black Ice SR2 Multiport Black Carbon Radiator - 360mm
EKWB EK-Velocity Strike CPU
EK-CoolStream RAD XTC 420
Thermaltake core x71
Operating System
Windows 10 Pro
ASUS VW246H Black 24" 2ms
Keyboard
Rosewill NEON K75 V2 BR
Mouse
CM Storm Sentinel Advance II
Audio
Corsair Void
Bal3Wolf is online now
post #3 of 11 (permalink) Old 05-19-2020, 02:39 AM
Senioritis Member
Lady Fitzgerald's Avatar
Rep: 531 (Unique: 333)
Did you contact Newegg about it?
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is offline
post #4 of 11 (permalink) Old 05-19-2020, 02:44 AM
Rep: 312 (Unique: 259)
All modern PSUs with active PFC should be fine to run in either the US or EU specs for mains voltage. Just plug in a standard power cord and you should be good to go.
"Being wrong is erroneously associated with failure, when in fact to be proven wrong should be celebrated. For it is elevating someone to a new level of understanding, furthering awareness."
"Always question the recieved reality, the consensus reality is often intentionally misleading"
"No trees were killed to send this message, but a large number of electrons were terribly inconvenienced."
Thermal Compound Application Instructions:
Click Here for Guide
Mattb2e is offline
post #5 of 11 (permalink) Old 05-19-2020, 07:09 AM - Thread Starter
andyroo89's Avatar
I called them, unfortunately theyre out of stock, and I submitted a ticket with corsair about it.
Even though my extra power supply cords are only rated for 10 amps, why input current is 7.5-15 Amps? Hmm maybe it will be fine if im just running one gpu for now.
post #6 of 11 (permalink) Old 05-19-2020, 06:26 PM
A 10 amp cable is good for 1150 watts from the wall. You'll be fine.
Mattb2e is offline
post #7 of 11 (permalink) Old 05-19-2020, 06:35 PM
If for some reason Corsair doesn't help, which I find very unlikely, you can always check out your local goodwill for a power cable, or you can get something like this off of Amazon https://www.amazon.com/dp/B0027JRMD0..._gJiXEbNB66JKH
Mattb2e is offline
post #8 of 11 (permalink) Old 05-19-2020, 06:37 PM
Food Editor
skupples's Avatar
Rep: 719 (Unique: 378)
this. should be fine.
most of my AC cables are easily 5-10 years old. I prefer the older ones as they flex better.
Hell, I'm pretty sure my 100 foot rubberized extension cord is as old as I am, and its basically the same thing.
so, assuming R0ach doesn't show up, the OP is fine
Add me on Steam, same name
Best R0ach Quote of all time : TLDR: Haswell might be the last legit gaming platform unless mice get their own non-USB interface on some newer architecture.
skupples is offline
post #9 of 11 (permalink) Old 05-19-2020, 07:04 PM
ლ(╹ε╹ლ)
Rep: 179 (Unique: 140)
haven't read a better fact in quite a while on OCN.
Duality92 is offline
post #10 of 11 (permalink) Old 05-19-2020, 07:20 PM
Overclocker in training
ThrashZone's Avatar
Rep: 169 (Unique: 102)
Hi,
Should be fine just flip the switch to multi-rail instead of single and good for 15 amp input.
Should be on a backup battery with gfi ground anyway.
i9-9940x With Optimus Foundation copper-plexi and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
Other
5.0/https://valid.x86.fr/ez2ifr
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
Audio
10900k
Samsung 970 evo 500gb
EVGA 1000P2
Corsair 450D
Operating System
ThrashZone is online now
