Stuck between 2 PSU's - Overclock.net - An Overclocking Community
post #1 of 26 (permalink) Old 09-09-2010, 12:11 PM - Thread Starter
Retired Staff
kcuestag's Avatar
Rep: 334 (Unique: 210)
Hello!
I sold some stuff and I was able to get 135€.
I just saw a Antec True Power New 750W Modular f or 109€, but then I realized that it was not fully modular.
Then I saw this OCZ fatal1ty: http://www.caseking.de/shop/catalog/...tt::14995.html
But I see it has only 18A on each +12v rail.
Now my question is, should that be enough for an OC'ed Hd5970 considering I already have a Corsiar TX650 ? Or should I go for the Antec? Which one would you choose? Personally I prefer the OCZ because of the red led and its cheaper, and more modular cables! But I am not sure the OCZ will be enough'
Edit:
I also saw this one: http://www.caseking.de/shop/catalog/...tt::14465.html
Which one would you choose for my PC?
Thanks.
The "NoMoreUpgradesUntilXmasPC" Build Log
GPU's: HD5850 > HD5970 > 2x HD6970 > 2x GTX580 > 3x GTX580 >
> 2x GTX680 > 2x HD7970 > R9 290X > 2x R9 290 > GTX970 > 2x R9 290X >
> GTX980Ti > 2x GTX980Ti > 2x GTX1080 > 2x GTX 1080 Ti
kcuestag is offline
post #2 of 26 (permalink) Old 09-09-2010, 12:14 PM
Confessed's Avatar
Rep: 156 (Unique: 139)
The TruePower New without question. The OCZ is Sirtec made junk, mediocre maybe. You don't want a precious rig like yours to have a low quality PSU.
Why are you upgrading though? The TX650 is still a good PSU.
Confessed is offline
post #3 of 26 (permalink) Old 09-09-2010, 12:16 PM - Thread Starter
Retired Staff
kcuestag's Avatar
Because my TX650 is almost on the limit and it does make some noise while both gpu and cpu are on load, so I wanna sell and get rid of it, and go for a more wattage one so I can be Ok, also I might buy a WC loop soon so that's even more power for the 650.. thats why.
So over those 3 you would choose the Antec True Power 750W?
kcuestag is offline
post #4 of 26 (permalink) Old 09-09-2010, 12:22 PM
Rep: 266 (Unique: 196)
Get the Antec, no question about it. It is much better quality than the OCZ.
HobieCat is offline
post #5 of 26 (permalink) Old 09-09-2010, 12:22 PM
Rep: 473 (Unique: 380)
Forget about the OCZ. Your decision should be between the Antec TP-750 and the ThermalTake ToughPowerXT 875. Both are good units, it just depends how much wattage you need/want. For what you have in mind though, 750W would be more than enough, so my vote goes to the Antec unit as well.
Shub is offline
post #6 of 26 (permalink) Old 09-09-2010, 12:22 PM
Dreamlane's Avatar
Rep: 10 (Unique: 10)
I've got that Antec truepower 750W, and I have had 0 complaints with it.
Keep in mind I am only running 1 260gtx right now with an old dual core, but I purchased it recently with intentions of upgrading to a dual card liquid cooled set-up, and I am confident it will run what I need without issue.
EDIT: It's only partially modular by the way...
Dreamlane is offline
post #7 of 26 (permalink) Old 09-09-2010, 12:24 PM - Thread Starter
Retired Staff
kcuestag's Avatar
So you guys think it should be fine with my rig the Antec 750W and a WC Loop in the future?
Thanks again.
kcuestag is offline
post #8 of 26 (permalink) Old 09-09-2010, 12:25 PM
Confessed's Avatar
This is what you should really get.
http://www.caseking.de/shop/catalog/...ar::15031.html
If you haven't heard about the XFX PSU hype, here's a review.
http://www.jonnyguru.com/modules.php...tory5&reid=184
post #9 of 26 (permalink) Old 09-09-2010, 12:28 PM
( ━☞´◔‿ゝ◔`)━ ☞
Kokin's Avatar
Rep: 425 (Unique: 364)
I've got the Antec TP-750 as well, but with the blue LEDs on it and I recommend it. The only problem is you wouldn't be able to do quadfire with 2 5970's if you ever decide to go that path with only a 750W PSU. Otherwise, you should be good with everything OC'ed plus a WC system install.
Black Heart
(21 items)
Intel i5 3570K [Delid]
Asrock Z77E-ITX
EVGA GeForce GTX 1080Ti FTW3
HyperX Fury 16GB 1866 DDR3 HX318C10FBK2/16
Crucial M4 256GB
Crucial MX500 2TB
Western Digital Blue Scorpio 1TB
Seagate Constellation 2 1TB
Seasonic Prime 600W Titanium Fanless
XSPC RX240+EX240 [Painted White]
5x 2150RPM Gentle Typhoons PWM [Painted Black+White]
EK Supremacy EVO RGB + EK FC1080Ti FTW3 blocks
Phanteks Glacier R160 + MCP35X
Case Labs Mercury S3
Operating System
Windows 10
Alienware AW3418DW 34" Ultrawide 3440x1440 120Hz G-Sync
Qnix QX2710 1440p 120Hz
Keyboard
WASD CODE 87-Key [MX Clear + /dev/tty Keycaps]
Mouse
Logitech G502
Audio
Sennheiser HD 6XX
Audio
Micca OriGen G2
Kokin is offline
post #10 of 26 (permalink) Old 09-09-2010, 12:29 PM - Thread Starter
Retired Staff
kcuestag's Avatar
WoW, that XFX looks sick, im deffinitely buying it, if you confirm me it is efficient like the antec?
I don't plan on buying another 5970 ever, if I ever changed, I would sell 5970 and get a single-gpu from 6000 series, nothing stronger
kcuestag is offline
