[Official] Corsair HX/AX Series Owners Club - Overclock.net - An Overclocking Community
post #1 of 798 (permalink) Old 02-14-2011, 04:53 PM - Thread Starter
jameyscott's Avatar
Rep: 242 (Unique: 182)
The Corsair HX and AX Series power supplies are a great choice to make your rig look cleaner and run more efficiently. Excellent Quality backed by a 5 to 7 year warranty makes choosing a power supply for your rig much easier.
We are going to start out with the biggest and baddest power supply currently on the market. (Yes I know there are higher wattage units, but this is the only one that can feasibly be run on a normal circuit 15 amp in America)
Yes boys and girls, this is the AX1500i. It is 80+ Titanium rated which means at it's peak effeciency, it runs at 94%. However, you aren't always going to be pulling 750 watts, so what it's efficiency across the board? A whopping 90% at any load . (According to jonnyguru.com)
Needless to say, this is an absolutely impressive PSU.
More details can be found at jonnyguru.com
Warning: AX1500i Information and Specifications (Click to show)
Warranty Seven Years
MTBF 100,000 hours
80 PLUS Certification Level Titanium
Power 1500 Watts
Zero RPM Fan Mode Yes
Fan Bearing Technology Fluid Dynamic Bearing
Fan size 140mm
Corsair Link Support Yes
Continuous Output Rated Temperature (°C) 50°C
Dimensions 150mm x 86mm x 225mm
Modular Fully
Cable Type Low-Profile, All Black
ATX Connector 1
EPS Connector 2
Floppy Connector 2
4-Pin Peripheral Connector 12
PCI-E Connector 10
SATA Connector 20
Corsair AX1500i Digital ATX Power Supply
AC Input Rating DC Output Rating
AC Input: 100V - 240V DC Output +3.3V +5V +12V -12V +5Vsb
Current: 15A Max Load 30A 30A 125A 0.8A 3.5A
Frequency: 50Hz - 60Hz Maximum Combined Wattage 180W 1500W 9.6W 17.5W
Total Power: 1500W
Next up in the AX series we have the AX1200i.
This PSU has been on the market for quite some time now. Back when a 1200w PSU only could dream of being Platinum rated. It has stood the test of time and is still a choice for a lot of enthusiasts. It has receieved numerous awards including. "Must Have" from Kitguru.net, "Best Hardware" from Guru3D, "EDitor's Choice from Vortez.net, "Editor's Choice" from TechPowerUp, "Wish List" from Hexus.net, and the ever so important, jonnyguru.com recommended
Lastly from the AX series we have the little brothers to the AX1200i. The AX860i, AX760i, AX860, and AX760. All five of these are the updated versions of the now Discontinued AX 80+ Gold rated series. The AX860i has received just as high accommodations as the AX1200i. It stays true to the AX name and it delivers what you would expect from Corsair' top tier PSUs.
Warning: AX1200i Information and Specifications (Click to show)
Warranty Seven years
Model AX1200i
Weight 10.5
MTBF 100,000 hours
80 PLUS Certification Level Platinum
Power 1200 Watts
Fan Bearing Technology Dual Ball Bearing
Fan size 140mm
Dimensions 150mm x 86mm x 200mm
Modular Fully
ATX Connector 1
EPS Connector 2
Floppy Connector 2
PCI-E Connector 8
SATA Connector 16
Corsair AX1200i Digital ATX Power Supply
Current: 15A Max Load 30A 30A 100.4A 0.8A 3.5A
Frequency: 50Hz - 60Hz Maximum Combined Wattage 180W 1204.8W 9.6W 17.5W
Total Power: 1204.8W
AX760i
Warning: AX760i Information and Specifications (Click to show)
Weight 7.25
MTBF 100,000 hours
Power 760 Watts
Fan size 120mm
Dimensions 150mm x 86mm x 160mm
Modular Fully
ATX Connector 1
EPS Connector 2
Floppy Connector 2
4-Pin Peripheral Connector 8
PCI-E Connector 6
SATA Connector 12
Corsair 760i Digital ATX Power Supply
Current: 10-5A Max Load 25A 25A 63.3A 0.8A 3.0A
Frequency: 50Hz - 60Hz Maximum Combined Wattage 125W 759.6W 9.6W 15.0W
Total Power: 760W
AX860i
Warning: AX860i Information and Specifications (Click to show)
Model CP-9020037-NA
Weight 7.25
MTBF 100,000 hours
Power 860 Watts
Fan size 120mm
Modular Fully
ATX Connector 1
EPS Connector 2
Floppy Connector 2
PCI-E Connector 6
SATA Connector 12
Corsair AX860i Digital ATX Power Supply
Current: 12-6A Max Load 25A 25A 71.6A 0.8A 3.0A
Frequency: 50Hz - 60Hz 125W 859.2W 9.6W 15.0W
Total Power: 860W
AX860
Warning: Spoiler! (Click to show)
Model CP-9020044-NA
Weight 7.25
MTBF 100,000 hours
Power 860 Watts
Fan size 120mm
Corsair Link Support No
Modular Fully
ATX Connector 1
EPS Connector 2
Floppy Connector 2
PCI-E Connector 6
SATA Connector 12
Corsair AX860 Digital ATX Power Supply
Current: 11-5.5A Max Load 25A 25A 71A 0.5A 3.0A
Frequency: 50Hz - 60Hz Maximum Combined Wattage 125W 8528W 6W 15W
Total Power: 860W
AX760
Warning: AX760 Information and Specifications (Click to show)
Weight 7.25
MTBF 100,000 hours
Power 760 Watts
Fan size 120mm
Modular Fully
ATX Connector 1
EPS Connector 2
Floppy Connector 2
PCI-E Connector 6
SATA Connector 12
Corsair AX760 Digital ATX Power Supply
Current: 9.5 - 4.5A Max Load 25A 25A 63A 0.5A 3.0A
Frequency: 50Hz - 60Hz Maximum Combined Wattage 125W 756W 6W 15W
Total Power: 760W
The HXi series is on its way and is set to be released in August 2014. (Will update this when it actually releases) For now, here are some pictures of what we are going to be getting.
Warning: HXi Information and Specifications (Click to show)
80 PLUS Platinum efficiency
Fully modular DC cable set
100% Japanese electrolytic capacitors rated at 105°c
Zero-RPM fan mode for virtually silent operation at low and medium loads
Corsair Link support for monitoring efficiency, voltages, power output, temperature, and fan speed plus user customizable setting of rail modes and fan speed.
Fluid dynamic bearing fan
Continuous power rated at 50° Celsius
Models and MSRP USD pricing
HX750i 750 watt: $169.99
HX850i 850 watt: $189.99
HX1000i 1000 watt: $229.99
Welcome to the HX Series!
These bad boys are Gold rated and are well received and reviewed units in this community and others.
HX1050
HX850
My first PSU that I bought in late 2013 was the HX850. Why did I buy that? Go to Newegg. It has some of the best reviews (above PSUs that have less than 50 reviews, why newegg insists to have it set up to where if it has one five start review it will be in the top of the "best rated" section... I will never know) and has been tried and tested by many reviewers. It has performed admirably for me, and still does!
HX750
HX650
Warning: EOL Units (Click to show)
HX Series
HX450
Specs:
Dimension: 150mm(W) x 86mm(H) x 150mm(L)
Power: 450 Watts
80 Plus: Bronze
ATX 24-pin & 20-pin: 1
EPS/ATX12V 8-pin/4-pin: 1
PCI-E Connector 8-pin/6-pin: 2
4 Pin Peripheral Connector: 8
SATA Connector: 6
Floppy Connector: 2
MTBF: 100,000 Hours
HX520
Specs:
Power: 520 Watts
80 Plus: Certified
4 Pin Peripheral Connector: 10
SATA Connector: 4
Floppy Connector: 2
MTBF: 100,000 Hours
HX620
Specs:
Dimension: 150mm(w) x 86mm(h) x 150mm(l)
power: 620 watts
80 plus: Certified
atx 24-pin & 20-pin: 1
eps/atx12v 8-pin/4-pin: 1
pci-e connector 8-pin/6-pin: 2
4 pin peripheral connector: 10
sata connector: 8
floppy connector: 2
mtbf: 100,000 hours
HX650
Specs:
Power: 650 Watts
80 Plus: Bronze
ATX Connector: 1
EPS Connector: 1
PCI-E Connector: 4
SATA Connector: 9
Floppy Connector: 2
MTBF: 100,000 hours
HX750
Specs:
Dimension: 150mm(W) x 86mm(H) x 180mm(L)
Power: 750 Watts
80 Plus: Silver
ATX Connector: 1
EPS Connector: 1
PCI-E Connector: 4
SATA Connector: 12
Floppy Connector: 2
MTBF: 100,000 hours
HX850
Specs:
Power: 850 Watts
80 Plus: Silver
ATX Connector: 1
EPS Connector: 1
PCI-E Connector: 6
4 Pin Peripheral Connector: 12
SATA Connector: 12
Floppy Connector: 2
MTBF: 100,000 hours
HX1000
Specs:
Dimension: 150mm(W) x 86mm(H) x 200mm(L)
Power: 1000 Watts
80 Plus: Certified
ATX Connector: 1
EPS Connector: 2
PCI-E Connector: 6
SATA Connector: 12
Floppy Connector: 2
MTBF: 100,000 hours
AX Series
AX750
Specs:
Dimension 150mm(W) x 86mm(H) x 160mm(L)
Power: 750 Watts
80 Plus: Gold
ATX Connector: 1
EPS Connector: 2
PCI-E Connector: 4
SATA Connector: 12
Floppy Connector: 2
MTBF: 100,000 hours
AX850
Specs:
Power: 850 Watts
80 Plus: Gold
ATX Connector: 1
EPS Connector: 2
PCI-E Connector: 4
SATA Connector: 12
Floppy Connector: 2
MTBF: 100,000 hours
AX1200
Specs:
Dimension 150mm(W) x 86mm(H) x 200mm(L)
Power: 1200 Watts
80 Plus: Gold
ATX Connector: 1
EPS Connector: 2
PCI-E Connector: 6
SATA Connector: 16
Floppy Connector: 2
MTBF: 100,000 hours
[php] [/php]
Corsair HX Owner's
  1. Alfa_R HX750
  2. Arkheios HX1000
  3. blackalphabet HX650
  4. Bonka HX850
  5. Cee HX850
  6. Ceej HX750
  7. Chunky_Chimp HX850
  8. CloudCR HX750
  9. CrazzyRussian HX850
  10. Deano12345 HX850
  11. denydog HX850
  12. drka0tic HX850
  13. Eaglake HX750
  14. Enigma8750 HX1000
  15. ErBall HX850
  16. Freelancer852 HX1000
  17. GameBoy HX450
  18. GMcDougal HX850
  19. lifeskills HX850
  20. ice_n_fyre HX1000
  21. IcedEarth HX520
  22. jntarheels HX850
  23. k0rnh0li0 HX1000
  24. Lee Stevens HX850
  25. MacNcheese HX750
  26. Munkypoo7 HX750
  27. Neokolzia HX850
  28. P_dog89gt HX850
  29. QuackPot HX850
  30. reaper~
  31. HX1000
  32. RussianJ HX650
  33. scottath HX620
  34. sdla4ever HX650
  35. ski-bum HX1000
  36. Snowman1989 HX650
  37. S_V™ HX850
  38. Theory HX750
  39. Tig Ol Bitties HX650
  40. TitaniumClocker HX1000
  41. tpi2007 HX450
  42. tryagainplss HX450
  43. Ultimatium HX1000
  44. v1ral HX850
  45. vincewchan HX1000
  46. Wired-HoH HX1000
  47. XX55XX HX650
  48. Yellowbeard HX520
  49. scottath HX620
  50. Ultimatium HX1000
  51. drka0tic HX850
  52. denydog HX850
  53. MacNcheese HX750
  54. jntarheels HX850
  55. Munkypoo7 HX750
  56. sdla4ever HX650
  57. Quackpot HX850W
  58. Bonka HX850
  59. Alfa_R HX750
  60. CrazzyRussian HX650w
  61. Neokolzia HX850
  62. Levesque HX1000
  63. Arkheios HX1000
  64. tpi2007 HX450w
  65. blackalphabet HX650w
  66. TitaniumClocker HX1000
  67. Lee Stevens HX850
  68. k0rnh0li0 HX1000
  69. vincewchan HX1000
  70. Ceek HX750
  71. Jaromir HX650
  72. FinalFrontier HX850w
  73. Dannyb0y HX750
  74. Buska013
  75. XSCounter HX650
  76. EvilTekno HX750
  77. The_Seabigbear HX100w
  78. cmurda25 HX850
  79. dave1991 HX750
  80. Majin SSJ Eric HX750
  81. Lindyrig HX850
  82. HandOFAnubis HX750
  83. Ghilly HX750
  84. Arizonian HX1050
  85. xd_1771 HX520
  86. UnexplodedCow HX1000
  87. Timechange01 HX1050
  88. solsamurai HX650
  89. Phenom_955 HX520W
  90. Airrick10 HX650w
  91. blackbalt89 HX750 HX850
  92. yanks8981 HX850
  93. covert ash HX750
  94. Coolio831 HX850w
  95. Xeth HX1000
  96. MGX1016 HX620
  97. OCeaN HX750
  98. Kyronn94 HX650
  99. Mad Pistol HX750
  100. OrangeBunnies HX850
  101. shadoweyeone HX1050
  102. legend999 HX620
  103. mothow HX850w
  104. tarpon31 HX650
  105. kaiju HX650w
  106. OverClocker55
  107. Makron666 HX650
  108. John ' HX620
  109. Doc_Gonzo HX850
  110. Pentium4 531 overclocker
  111. CreeperK1d HX650
  112. solsamurai
  113. MA573R0FWAR HX650W
  114. AusNorman HX750W
  115. Essenbe HX750
  116. rhinitis HX850
  117. jpdaballa HX1050W
  118. Solstice11 HX1050
  119. Dhirrac+ HX620
  120. CaselanB HX75
  121. TheAntiMartyr HX750
  122. rc dude HX750
  123. PimpSkyline HX850
  124. Lshuman HX750W
  125. Cores HX650
  126. Norse HX850
  127. Trexx HX1050
  128. trapjaw72 HX650
  129. Norse HX1050
  130. MrfingerIII HX1050
  131. wolf9466
  132. error0909 HX450
  133. erorr0909 HX1000
  134. Lady Fitzgerald HX750 x2
  135. danilon65 HX750
jameyscott is offline
post #2 of 798 (permalink) Old 02-14-2011, 04:59 PM
GameBoy's Avatar
Rep: 201 (Unique: 173)
Ryzen 1700x w/ Wraith Prism
MSI B450M Mortar 7B89v11 BIOS
G.Skill TridentZ 2x8GB 3200C14 @ 3466C14 1.5T
Gigabyte 7970 @ stock
Samsung 830 128GB
EVGA G2 650
Antec P180 Mini
GameBoy is offline
post #3 of 798 (permalink) Old 02-14-2011, 05:03 PM
Theory's Avatar
Rep: 48 (Unique: 48)
Originally Posted by gameboy;12387909
hx450?
OH WOW didn't even know that existed, will add soon
EDIT: Looked into it, It was renamed the VX450.
Quotes (Click to show)Warning: Spoiler! (Click to show)
"Sir, we think Chin-Lee may not be performing up to standards.""Well then, I wouldn't be surprised if he committed suicide within the next couple of hours."
"Yes sir, I'll get right on it."
OCN is basically the only place where discussion about transistors turns into a discussion about flying poptart cats.
Theory is offline
post #4 of 798 (permalink) Old 02-14-2011, 05:05 PM
Rep: 208 (Unique: 185)
I'm down with a modded hx850.
ErBall is offline
post #5 of 798 (permalink) Old 02-14-2011, 05:17 PM
Theory's Avatar
Theory is offline
post #6 of 798 (permalink) Old 02-14-2011, 06:14 PM
Rep: 174 (Unique: 152)
Yay...I'm first to say I have an HX650
Tig Ol Bitties is offline
post #7 of 798 (permalink) Old 02-14-2011, 07:17 PM
Theory's Avatar
We need more members, tell your friends!
Theory is offline
post #8 of 798 (permalink) Old 02-14-2011, 07:18 PM
Theory's Avatar
Both added
Theory is offline
post #9 of 798 (permalink) Old 02-14-2011, 07:20 PM
Citra's Avatar
Rep: 144 (Unique: 129)
Why not just make a Corsair PSU Club?
(8:23:27 PM) zodac: Everyone sucks.
(8:23:30 PM) zodac: OCN just sucks less. - (8:23:31 PM) zodac: Go OCN!
Citra is offline
post #10 of 798 (permalink) Old 02-14-2011, 07:21 PM
Nice, I'm down.
tsm106 is offline
