How to adjust PSU fan speed? - Overclock.net - An Overclocking Community
Closed Thread
post #1 of 19 (permalink) Old 02-19-2011, 01:39 PM - Thread Starter
Rep: 0
Hey guys I recently built a rig and everything runs smooth, except the fan for my power supply runs full speed all the time. My mobo is a Biostar A880G+ and I'm wondering if there's any way to adjust its speed in the bios.
Overdrivex2 is offline
post #2 of 19 (permalink) Old 02-19-2011, 01:42 PM
Senior Moderators
pioneerisloud's Avatar
No. If the fan is running all the time, that means your PSU is running hot usually. Or its a really cheap PSU. Either way, sounds like you need a different PSU.
What unit is it exactly?
DisposalAreav4.0
(15 items)
BayMax
(10 items)
FanzGoBrrr
(10 items)
Intel Core i7 2600k @ 4.65GHz, 1.45v (105.68x44)
Gigabyte Z68MA-D2H-B3
Asus RX580 8GB @ 1425 / 2150
Kingston HyperX (4x4GB) @ DDR3-1690, 9-9-9-24-1T, 1.66v
Crucial MX100 256GB + Sandisk Ultra 240GB RAID0 (400GB)
Toshiba 3TB 3.5"
Seasonic M12II Evo 520w
CoolerMaster 240mm
DIY PC Cuboid Blue mATX
Operating System
Windows 10 Pro x64
Hanns G 23" 1080p / 60Hz
Keyboard
Redragon 10 keyless
Mouse
Logitech Optical Mouse USB
Mousepad
Generic Onn Black
Audio
Diamond Edison 2.0
Intel Xeon E5-2608L v3 x2
SuperMicro X10DRL-I
Onboard
16GB (4x4GB) DDR4 ECC / Registered
Crucial BX500 120GB
40TB FreeNAS Array
CoolerMaster MasterWatt 750w
Arctic Cooling 92mm Tower x2
P Link USA 20 Hotswap Bay 4u Chassis
Operating System
FreeNAS
Intel Xeon E5-2683 v4 16 core x2
SuperMicro X10DRL-I
120GB Crucial BX500
1TB Crucial BX500
Toshiba 3TB 7200RPM x2 (RAID 1)
CoolerMaster Masterwatt 750w
P Link USA EATX Locking Front 4u Chassis
Operating System
Windows 10 + VMWare
pioneerisloud is offline
post #3 of 19 (permalink) Old 02-19-2011, 01:42 PM
Turd Burglar
Kratthew D. Kraids's Avatar
Rep: 104 (Unique: 97)
I don't think so, I never saw any options like that in my Biostar BIOS.
ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ ಠ_ಠ
Kratthew D. Kraids is offline
post #4 of 19 (permalink) Old 02-19-2011, 01:44 PM - Thread Starter
Rep: 0
Hmm, the power supply is like 5 years old, its a 300w and my setup is barely taking 250w. So i'm unsure as to why it would be running hot.
post #5 of 19 (permalink) Old 02-19-2011, 01:47 PM
Senior Moderators
1) Power supplies age over time, and put out less power.
2) You never stated WHAT 300w unit you have. Is it junk or a good unit?
3) You also haven't listed what your GPU is.
Either its a cheap unit that doesn't have automated fan control, or it DOES have automated fan control, and it actually needs that fan at full speed. Either way, you need a new PSU.
DisposalAreav4.0
(15 items)
BayMax
(10 items)
FanzGoBrrr
(10 items)
Toshiba 3TB 3.5"
CoolerMaster 240mm
Operating System
Windows 10 Pro x64
Keyboard
Redragon 10 keyless
Mouse
Mousepad
Generic Onn Black
Audio
Diamond Edison 2.0
SuperMicro X10DRL-I
Onboard
Crucial BX500 120GB
40TB FreeNAS Array
Operating System
FreeNAS
SuperMicro X10DRL-I
120GB Crucial BX500
1TB Crucial BX500
Operating System
Windows 10 + VMWare
post #6 of 19 (permalink) Old 02-19-2011, 01:48 PM
Rep: 59 (Unique: 55)
Unless it's branded, liklihood is it wasn't a good PSU to begin with, and if it's running hot at idle (I assume it as - hence "all the time"), then you'd probably do well to get a new (and better quality, branded) one.
Also, point to note: Since the PSU only plugs into the motherboard via power leads, it shouldn't have a way to control the fan externally.
Si hoc legere scis nimium eruditionis habes.
Korlus is offline
post #7 of 19 (permalink) Old 02-19-2011, 01:49 PM
Rep: 64 (Unique: 59)
most PSU speeds cant be adjusted by means of software, but there are more difficult options of opening up the psu and installing a voltage capacitor on the fan... or of course you could put in a new fan of the same size and mod the wires to connect to your psu voltage output. And fan of the same size should work fine, so if you find one that has a good mix between high air flow _ low DBA you should be gold smile.gif
Im a furry artist!
If interested PM me for my gallery
~*~*OCN FURRY FAN CLUB*~*~
AlaskaFox is offline
post #8 of 19 (permalink) Old 02-19-2011, 01:51 PM
Retired Staff
Phaedrus2129's Avatar
Rep: 1730 (Unique: 1138)
Software cannot influence anything to do with the power supply. At all. Period.
Burning books is like burning bras; after the adrenaline rush of the symbolic moment wears off all you're left with is a pile of ashes and unsupported boobs.
Phaedrus2129 is offline
post #9 of 19 (permalink) Old 02-19-2011, 01:56 PM
Turd Burglar
Sounds like someone needs a new PSU, 5 years old, 300w, and full speed fan. It's on it's last leg, Time to upgrade biggrin.gif
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371007
post #10 of 19 (permalink) Old 02-19-2011, 01:58 PM - Thread Starter
Rep: 0
The power supply is from my sony vaio pcv-rs 420, before this setup it never ran full speed, I have no GPU installed, I'm using integrated.
Closed Thread
