[The Guardian] Twisted fibre optic light breakthrough could make the Internet 100 times faster - Page 2 - Overclock.net - An Overclocking Community
post #11 of 30 (permalink) Old 10-25-2018, 07:41 PM
Hueristic's Avatar
Rep: 433 (Unique: 289)
Quote: Originally Posted by Tadaen Sylvermane View Post
Fixed it for you.
Rotfl.
READ this thread before starting your first build!!!
ALWAYS power up a Mobo Before installing it! Consider Less than helpful posts as Free Bumps.
devil-smiley-019.gif¡¡¡ʍʇɟ qn1ɔ uoıʇɐıɔǝɹddɐ 939 ʇǝʞɔos ǝɥʇthumbsupsmiley.pngsozo.gifRetro Rulezsozo.gif
1.
If you can't afford to lose it don't mod or OC it.
2.
At least read the ENTIRE OP before commenting.
Semper Fi
Hueristic is offline
post #12 of 30 (permalink) Old 10-25-2018, 10:49 PM
drewafx's Avatar
Rep: 5 (Unique: 5)
If the repeaters don't need to be replaced, I'm guessing that the current infrastructure can be upgradable at the end points...
100x without having to dig out fiber lines? Just what we need for 10 Gigabit internet.
drewafx is offline
post #13 of 30 (permalink) Old 10-25-2018, 11:06 PM
Iconoclast
Blameless's Avatar
Rep: 3135 (Unique: 1869)
Quote: Originally Posted by EniGma1987 View Post
More bandwidth. Light cannot go any faster so no way to improve latency there.
Light typically travels about 30% slower through a fiber optic cable than through a vacuum, so there is considerable room for improvement even in this regard.
https://www.wired.com/2013/03/intern...peed-of-light/
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #14 of 30 (permalink) Old 10-26-2018, 01:07 AM
It Just Works
TFL Replica's Avatar
TFL Replica is offline
post #15 of 30 (permalink) Old 10-26-2018, 07:33 AM
Frog Blast The Vent Core
Rep: 371 (Unique: 184)
....No, there is not considerable room for improvement in latency. Sure, there is work being done, but it's in the very early stages and doing it without loss or signal degradation is very hard.
Yes, lower latency would be good - but not if you have to compensate for it in other areas of your network design.
No, you absolutely would have to upgrade the entire link. Transmitters, modulators, multiplexing switches, the fiber itself, the mid-span amplifiers and dispersion compensation, demultiplexing switches, and receivers all have to change. Otherwise, you'd be splicing on this special stuff to the normal stuff, and the angular momentum information wouldn't handle the transition well.
Mand12 is offline
post #16 of 30 (permalink) Old 10-26-2018, 08:25 AM
Iconoclast
Blameless's Avatar
Increasing the speed of light through the fiber optic medium used would decrease latency proportionally. The speed of light through a fiber optic cable is significantly below the speed of light through a vacuum. It is also possible to significantly close this gap. Therefore, there is considerable room for improvement in latency.
The difficulty or the timetable for this is neither here nor there.
I was simply pointing out that the speed of light is not fixed.
post #17 of 30 (permalink) Old 10-26-2018, 08:36 AM
Pointing out that the speed of light in media is not fixed is not the same as claiming it can be "significantly closed" in the specific case of telecommunications fiber. The former is true, the latter is much less likely to be true. I started to go into the details of why, details you promptly ignored. If you want, I can go into more detail on it as optical engineering is my profession, but you seem to just want to poke holes while knowing little about the details.
Mand12 is offline
post #18 of 30 (permalink) Old 10-26-2018, 10:57 AM
Hueristic's Avatar
Light is calculated with the refractive index. It bounces inside the cable.
I think the only constant thing in this reality is that there are no constants./\
https://www.livescience.com/29111-sp...-constant.html
You just can't count on anything! :rant:
Hey, this is a great read, I did not know they have found photons that are not defined by Planck's constant. I have always believed that was an immutable constant.
https://www.sciencealert.com/physici...-form-of-light
I'm still a bit confused on whether it is possible to slow a photon down now or they are just finding new types of photons.
Just got interrupted in the middle of this read right now.
1.
2.
Semper Fi
post #19 of 30 (permalink) Old 10-26-2018, 01:38 PM
Panzerjäger Tiger Ausf. B
jagdtigger's Avatar
Rep: 47 (Unique: 29)
Hold your horses, most ISP's didnt even ditch dial up, let alone the other forms of internet over copper....
Dark Repulser
(21 items)
Intel I5 4670K
MSI Z87-G55 (MS-7821)
Sapphire R9 290X
2xCORSAIR 8GB Vengeance DDR3 1600MHz CL9 CML8GX3M1A1600C9
Samsung SSD 850 Pro
XFX Pro 650W Modular Edition
2x Laing DDC-Pumpe 12V DDC-1Plus with aquacover dual ddc top
Aquacomputer aquaero 6 XT
2x alphacool nexxxos xt45 360
Koolance VID-AR290X Water Block
Aquacomputer cuplex kryos PRO
Phobya reservoir
Fractal Design Define S
Operating System
Windows 7 HP
Operating System
Kubuntu
LG IPS277L
LG W2486L
LG 27MU67-B
Keyboard
SpeedLink DarkSky black
Mouse
Logitech M705
Audio
Integrated devices
jagdtigger is offline
post #20 of 30 (permalink) Old 10-26-2018, 02:17 PM
Laptop Enthusiast
Imglidinhere's Avatar
Rep: 447 (Unique: 333)
Honestly speaking, these "breakthroughs" are cool but they have almost zero practical application in the real world. We aren't even tapping into the maximum capability of what a coaxial cable can handle, much less actual fiber connections, so why are people trying to progress beyond that for the general public, or even enterprise, for that matter?
You can push gigabit speeds through coaxial connections, easily. Why aren't they doing it? Money.
SKYNET Mobile v3.0
(12 items)
Inspiring Greatness
i7-8750H @ 3.9GHz
Intel HM370
6GB GTX 1060
32GB DDR4 2666
256GB SSD
500GB Samsung 840 Pro
180w Power Adapter
Tongfang GK5CN6Z
Operating System
Windows 10 Home
1920x1080 144hz IPS Display
Mouse
Logitech G502 Proteus
Mousepad
Xtrac Ripper
Intel Core i5-6300HQ
Dell Proprietary
4GB Nvidia GTX 960M
Samsung 12GB (1x8GB 1x4GB) DDR3L 1600 MHz
256GB SanDisk M.2 SSD
1TB HGST 7.2k HDD
130w PSU
Custom Cooling by Dell Solutions
Operating System
Windows 10 Home 64-Bit
15.6" 1920x1080 IPS Screen
Keyboard
Dell
Mouse
Logitech G602 Wireless
Mouse
Xtrac 'Ripper' Mouse Pad
Imglidinhere is offline
