[Sciencealert.com] Researchers Just Demonstrated Nuclear Fusion in a Device Small Enough to Keep at Home - Overclock.net - An Overclocking Community
post #1 of 32 (permalink) Old 04-17-2019, 09:14 AM - Thread Starter
Indentified! On the Way!!
LancerVI's Avatar
Rep: 153 (Unique: 114)
When it comes to the kinds of technology needed to contain a sun, there are currently just two horses in the race. Neither is what you'd call 'petite'.
An earlier form of fusion technology that barely made it out of the starting blocks has just overcome a serious hurdle. It's got a long way to catch up, but given its potential cost and versatility, a table-sized fusion device like this is worth watching out for.
While many have long given up on an early form of plasma confinement called the Z-pinch as a feasible way to generate power, researchers at the University of Washington in the US have continued to look for a way to overcome its shortcomings.
A relatively small device known as a zeta or 'Z'-pinch uses the specific orientation of a plasma's internal magnetic field to apply what's known as the Lorentz force to the flow of particles, effectively forcing its particles together through a bottleneck.
In some sense, the device isn't unlike a miniature version of its tokamak big brother. As such, it also suffers from similar stability issues that can cause its plasma to jump from the magnetic tracks and crash into the sides of its container.
In fact, iterations of the Z-pinch led to the chunky tokamak technology that superseded it. Given this major limitation, the Z-pinch has all but become a relic of history.
Now, researchers from the University of Washington have found an alternative approach to stabilizing the plasma in a Z-pinch not only works, but it can be used to generate a burst of fusion.
To prevent the distortions in the plasma that cause it to escape the confines of its magnetic cage, the team manages the flow of the particles by applying a bit of fluid dynamics.
Introducing what is known as sheared axial flow to a short column of plasma has previously been studied as a potential way to improve stability in a Z-pinch, to rather limited effect.
https://www.sciencealert.com/a-break...ower-your-home
I don't pretend to really know what's going on here, but I still find it fascinating. Fusion reactor for every home? Sounds awesome. What are we??? 100 years away?
LancerVI is offline
post #2 of 32 (permalink) Old 04-17-2019, 09:24 AM
Graphics Junkie
UltraMega's Avatar
Rep: 30 (Unique: 26)
We're only talking 5 microseconds worth of neutrons here, so don't clear space in your basement for your Z-Pinch 3000 Home Fusion Box quite yet. But the stability was 5,000 times longer than you'd expect without such a method being used, showing the principle is ripe for further study.
Still a ways to go.
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #3 of 32 (permalink) Old 04-17-2019, 09:35 AM
Linux Evangelist
Jarhead's Avatar
Rep: 185 (Unique: 147)
Nuclear fusion has been about fifty years away for about fifty years, so yeah, don't worry about running your time machine off of a Mr.Fusion any time soon.
I calculated the odds of this succeeding versus the odds I was doing something incredibly stupid... and I went ahead anyway.
If it's not coming out for the PC, it's dead to me.
Jarhead is offline
post #4 of 32 (permalink) Old 04-17-2019, 09:44 AM
Otherworlder
epic1337's Avatar
Rep: 217 (Unique: 125)
"nuclear device to keep at home."
uhhh, i wonder if you'd have a bunch of swat forces surrounding your house if you do own one at home.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #5 of 32 (permalink) Old 04-17-2019, 11:03 AM
Original 16-bit Genesis®
Omega X's Avatar
Rep: 67 (Unique: 44)
Humans don't rapidly develop anything unless its life or death.
Omega X is offline
post #6 of 32 (permalink) Old 04-17-2019, 11:34 AM
professional curmudgeon
looniam's Avatar
Rep: 791 (Unique: 451)
a quick primer on nuclear energy:
fission bad, fusion good.
except for bombs.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is online now
post #7 of 32 (permalink) Old 04-17-2019, 02:40 PM
skupples's Avatar
Rep: 551 (Unique: 312)
why develop new stuff when you can just remove one component and add one new software feature each revolution?!
skupples is offline
post #8 of 32 (permalink) Old 04-17-2019, 03:15 PM
white owl's Avatar
Rep: 136 (Unique: 103)
Hopefully they figure it out soon...not for homes though. We've already got several global disasters worth of spent rods, some sitting on a fault line and on the shore of California with literally no plans of removal.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #9 of 32 (permalink) Old 04-17-2019, 07:08 PM
Kill Confirmed
speed_demon's Avatar
Rep: 78 (Unique: 65)
It's all well and good until you have one of those incredibly rapid exothermic events. AKA an explosion.
Also, sourcing enough smoke detectors has proven troublesome in my experience.
The famous Skunkworks had developed a fusion system a few years back that could be hauled around via flatbed trailer. IIRC it was a proof of concept feasible enough to catch the U.S. military's attention. That doesn't mean it works, it just means it was impressive to see.
Railguns are where the real fun is at. And where the greatest amount of new development a DIY'er can do on their own.
https://en.wikipedia.org/wiki/Nikola_Tesla
speed_demon is offline
post #10 of 32 (permalink) Old 04-17-2019, 08:45 PM
Omega X's Avatar
Omega X is offline
