[Hexus] JetCool CPU Waterblocks 10x Better at Heat Transfer - Page 2 - Overclock.net - An Overclocking Community
post #11 of 43 (permalink) Old 07-11-2019, 02:30 PM
Robotic Chemist
Asmodian's Avatar
Rep: 193 (Unique: 130)
I remember a GamersNexus video from a few months ago talking about someone in the UK making direct die water cooling blocks, with an o-ring that seals against the top of the CPU's PCB. They were for the high speed trading industry and their overclocked servers that are in the same room as the trading servers. I cannot find it now though.
I really want one!
Asmodian is offline
post #12 of 43 (permalink) Old 07-11-2019, 03:03 PM
DNMock's Avatar
Rep: 174 (Unique: 128)
Isn't heat transfer coefficient usually expressed in Kelvin?
DNMock is offline
post #13 of 43 (permalink) Old 07-11-2019, 03:12 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1324 (Unique: 703)
I really want one!
Don't think I saw that video. LTT did a video about a direct die water block but they didn't really do much with it (being LTT).
only dropped 2c going direct die (granted with thermal paste) over delided and re-lidded with liquid metal though.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (Blues)
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
CoolerMaster MasterKeys Pro S (Browns)
Mouse
Logitech M512
The Pook is online now
post #14 of 43 (permalink) Old 07-11-2019, 03:17 PM
Robotic Chemist
Asmodian's Avatar
Direct die with a water block is very different from direct water on the die though, it would be very interesting to see how much better it can get in practice.
Asmodian is offline
post #15 of 43 (permalink) Old 07-11-2019, 03:23 PM
Imouto's Avatar
Rep: 232 (Unique: 109)
I just had a stupid idea.
#EnthusiastLivesMatter
Imouto is offline
post #16 of 43 (permalink) Old 07-11-2019, 03:34 PM
FX-5000
ShrimpBrime's Avatar
Rep: 67 (Unique: 48)
Quote: Originally Posted by GHADthc View Post
I just want to see a direct die block for Zen 2...
It won't make that big of a difference using "direct die" cooling. I've been doing this for years now..... since sA (462 pin) processors.... oh wait those didn't have IHS plates on them.
This here is nothing new to me personally, but for most of you.... that could be different.
So first we have to understand WHY they use heat spreaders. This is a must to understand it's cause and then removal effects.
OK so you have a plate. it's X size in mass. It absorbs X amount of heat until dissipated by a cooling block or fan.... or maybe even passively if say using a 15W chip like a NB chipset for example. Which.... are direct die cooled.
Now you remove that plate, you decrease the amount of Mass that retains X heat.
The more copper you have, the longer it takes to heat up and also the longer it takes to dissipate that heat.... And that's where the removal of that plate idea comes into play.
__Create heat faster... remove heat faster. That is the name of the game with direct die cooling.
Intel chips, remove plate, replace stock TIM with something better, put plate back on and drop significant temps. Remove the plate, which will hold and retain heat, helps to dissipate to the cooler faster. But from this, it takes less time to achieve X heat load temps.
That was the quick run through there.
BUT WAIT!!!!!
So many of you have been direct die cooling for years and years and didn't even know it. Every motherboard uses direct die cooling. All chipsets are "direct die" cooling.
5-15w chips direct die cooling and passive in most cases.
IMO - which really may not matter to most people, is this "new cooler" or "new cooling type" is nothing special. This type of cooling won't matter with AMD Ryzen processors (any). Your gains will be minimal at best.
The A.I overclocking is generally more efficient than manual (static) overclocking. So doing all this "direct die" cooling, isn't really going to make end results good enough to spend the time and moneys on this adventure. Phenom II, FX chips actually benefit pretty well from this type of cooling however. Ryzen chips, at least what I've experienced Direct die cooling (on several chips) made absolutely no difference to have wasted my time doing so.
ShrimpBrime~
1331 Lid-less PGA 2700X - On a stock air cooler.
4.1Ghz 1.212-1.225v (extreme Digi-VRM) static overclock = best efficiency.
ShrimpBrime is offline
post #17 of 43 (permalink) Old 07-11-2019, 06:55 PM
Professional Proletariat
magnek's Avatar
Rep: 478 (Unique: 192)
I almost wonder if their claimed cooling advantages is largely due to this instead of some fancy water spraying. As it is, we don't have any "water immersion blocks" on the market to test this theory.
- 4930K @ 4.5 GHz | Asus X79-Deluxe
- MSi 980 Ti Gaming @ 1500/8000
- 4x4 GB Dominator Platinum 2400 MHz
- 2x 850 Pro 2TB
- Seasonic PRIME Titanium 850W
- Phanteks Enthoo Primo
- Custom watercooling (420+360+240)
- XB270HU 27" 1440p 144Hz IPS
magnek is offline
post #18 of 43 (permalink) Old 07-11-2019, 07:58 PM
ٴٴٴ╲⎝⧹˙͜>˙⧸⎠╱
TK421's Avatar
Rep: 163 (Unique: 127)
not much improvement when swapping the solder with LM
so around 5-8c max improvement on direct die waterblock, maybe
nͫٴiͤٴcͫٴeͤ੮Һ૯ ცɿ૭ ૭คעٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴٴ ٴٴ
TK421 is offline
post #19 of 43 (permalink) Old 07-11-2019, 09:48 PM
PC Enthusiast
Ashura's Avatar
Rep: 48 (Unique: 36)
Quote: Originally Posted by looniam View Post
look at the thermal resistance legends on the sides:
typical set up:
die|package(tim/solder)|IHS(cu)|tim|heatsink|fluid
their solution/concept:
die|fluid
it looks to "squirt" cooling fluid directly on the die.
(incoming squirting jokes YO!)
this, from what i see in the article and that image, is for system integrators. since dies are not all the same sizes its going to be "one use/product" cases.
Looking at your avatar, you had the idea before them
PolaRyz
(15 items)
Venomous FX
(14 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 3000Mhz 32gb
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mouse
Steelseries Qck Mass
AMD FX 8350
MSI 990FXA Gaming
XFX R9 290 DD
G.Skill RipjawsX 16GB [4x4GB] 1600MHz CL9 @1.5v
Seagate ST1000DM003
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
Dell ST2420L
AOC e2243Fwk 21.5"
Mouse
Razer Deathadder Chroma
Mouse
SteelSeries QcK Mass
Ashura is offline
post #20 of 43 (permalink) Old 07-11-2019, 11:31 PM
Overclocker
JackCY's Avatar
Rep: 351 (Unique: 249)
https://www.youtube.com/watch?v=n4O_Dq3xRJA
Every block is direct die if you're crafty enough.
JackCY is online now
