[Hexus] JetCool CPU Waterblocks 10x Better at Heat Transfer - Page 3 - Overclock.net - An Overclocking Community
post #21 of 43 (permalink) Old 07-12-2019, 05:06 AM
Insan1tyOne's Avatar
Rep: 137 (Unique: 110)
So will this technology get picked up by the pick PC water-cooling manufacturers or is this patented by JetCool and will only be sold for commercial applications?
Insan1tyOne is offline
post #22 of 43 (permalink) Old 07-12-2019, 05:09 AM
Rep: 347 (Unique: 263)
IBM did direct die but milled microchannels in die to improve surface area (mandatory for high power density/ie high watts low surface area), and decided it wasnt cost efficient at low watts and not feasible at higher power density.
Others have done direct die on xtremesystems using jet nozzles hitting die, always ended up with much worse temps vs normal water block with channels to allow enough surface area where water with its very poor heat conductance can transmit heat. You would need to make micropins or channel into die for surface area. But really what you need is liquid metal being pumped to do direct die. Water at 0.6 w/mk isnt going to cut it without massive surface area unless it is very low power density. liquid metal at 40 w/mk would work with direct die and high power density (its been done before as well just not commercially feasible)
opt33 is offline
post #23 of 43 (permalink) Old 07-12-2019, 05:16 AM
StAndrew's Avatar
Rep: 1 (Unique: 1)
So basically back to the original Swiftech Storm.
Asus Prime Z370, Intel 8700k @5.0Ghz, Nvidia GTX 1080 Ti, 16GB @3400 CL14, Watercooling: x2 MCP355 pumps, x1 280 on front of case, x1 360 on top of case, x1 140 on back of case, x1 240 on bottom of case
StAndrew is offline
post #24 of 43 (permalink) Old 07-12-2019, 06:59 AM
Apotropaic's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by DNMock View Post
Isn't heat transfer coefficient usually expressed in Kelvin?
It doesn't matter in this case. Since they are dividing by temperature, and Kelvin and Celsius have the same magnitude. (i.e. 27 deg C = 300 K, 47 deg C = 320 K; both are 20 units apart.)
Apotropaic is offline
post #25 of 43 (permalink) Old 07-12-2019, 02:11 PM
The 6502 Still Rocks
Master Chicken's Avatar
Rep: 30 (Unique: 28)
Usually in Watts per Meter-Kelvin or W/mK.
Master Chicken is offline
post #26 of 43 (permalink) Old 07-12-2019, 04:16 PM
Drewminus's Avatar
Rep: 1 (Unique: 1)
The more I think about this, the less sold on the concept I am. Sure direct die's better, whatever, but I can't figure out how this "jet cooling" will be any better. To achieve higer flow velocity in their water block they must be restricting the flow, so I just cannot imagine how higher flow rates vs slower but more liquid produces significanty better results. I'm also pretty suss on water achieving a transfer coefficient of 500,000 w/m2 K. It's been a while since I've done physics so I'm not going to math it out, but nothings really adding up for me here.
Drewminus is offline
post #27 of 43 (permalink) Old 07-12-2019, 04:24 PM
Original 16-bit Genesis®
Omega X's Avatar
Rep: 67 (Unique: 44)
Too risky for regular folk. A bad seal will cause...trouble.
Omega X is offline
post #28 of 43 (permalink) Old 07-12-2019, 04:47 PM
AmericanLoco's Avatar
Rep: 112 (Unique: 70)
Now that's a name I haven't heard in a long time. Remember the Storm G5 made out of silver - or the original pre-swiftech "Cathar" Storm blocks. How about all of the custom builds using Laing DDCs and the giant Eheim pumps. Those were the days!
AmericanLoco is offline
post #29 of 43 (permalink) Old 07-12-2019, 05:08 PM
Shawnb99's Avatar
Rep: 23 (Unique: 15)
Cathar!! That was the name of those blocks. I was racking my brain trying to remember what they were called. The old days when a single person made the best waterblock by far. I sure don’t miss the limited production runs and shipping from Australia. I wish I kept my old block.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #30 of 43 (permalink) Old 07-13-2019, 07:42 AM
DNMock's Avatar
Rep: 171 (Unique: 125)
Sure it can... if your unit of time is per week or something...
DNMock is offline
