[Hexus] JetCool CPU Waterblocks 10x Better at Heat Transfer - Overclock.net - An Overclocking Community
post #1 of 43 (permalink) Old 07-11-2019, 09:39 AM - Thread Starter
Newb to Overclock.net
mouacyk's Avatar
Rep: 173 (Unique: 128)
Source: https://hexus.net/tech/news/cooling/...er-processors/
As dies get smaller, the heat density and intensity increases, but flow rate of water loops don't (and can't) keep up with the needed heat transfer in common micro-fin/channel designs. But what if you focus a high flow rate at just the impingement zone, in arrays of jets that are less than 1mm each? In effect, this increases the temperature difference potential significantly where it matters, because cool water is presented in a higher volume, and more heat is taken away in the same unit of time (heat transfer).
CPU: Q6600 X5470 2100T 1680V2 9900K
GPU: 8800GT 9800GTX+ 750Ti 1080Ti
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
MSI 1080TI GXEK 2100.5/12627
16GB Trident Z 4000C16
970 EVO 500GB
Seasonic X850 Gold
480mm Radiator Custom
Silverstone FT03
Operating System
Windows 7 Ultimate 64-bit
Operating System
Gentoo Linux 64 Multi-Lib
Acer Predator XB271UH 165Hz
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
X5470 4GHz (stock v)
GA-EP45-UD3P
EVGA 9800 GTX+ 512MB
8GB 4x2GB GSkill 1066MHz DDR2
XSPC Rasa, D5 + Res, 240mm Rad
Lian-Li PC7-HX
mouacyk is offline
post #2 of 43 (permalink) Old 07-11-2019, 10:23 AM
mfw
ToTheSun!'s Avatar
Rep: 521 (Unique: 240)
Intel wants to know your location.
Intel 6700K
Asus Z170i Pro Gaming
Gigabyte 2070 Super Windforce OC
G.skill Trident Z 3200CL14 8+8
Samsung 850 EVO 1TB
Crucial M4 256GB
Corsair SF600
Noctua NH C14S
Fractal Design Core 500
Operating System
Windows 10 Education
ViewSonic XG2703-GS
Keyboard
Vortex Race 3 RGB
Mouse
Glorious Model O Glossy White v2.0
Mousepad
SteelSeries QcK+
Audio
Fiio E17K v1.0 + Beyerdynamic DT 1990 PRO (Dekoni pads)
ToTheSun! is online now
post #3 of 43 (permalink) Old 07-11-2019, 10:32 AM
Smug, Jaded, Enervated.
GHADthc's Avatar
Rep: 102 (Unique: 67)
I just want to see a direct die block for Zen 2...
2700X (4.3GHz All-Core).
Asus Crosshair VII Hero Wifi.
Inno3D 1080ti X2 w/ Raijintech Morpheus 2100mhz/11200mhz.
G.Skill Flare X 16GB(2x8GB) 3200 mhz CL14 OC'ed to 3533Mhz CL14.
Samsung 970 Evo 240GB M.2 NVME (OS Drive), Kingston 500GB SSD, Seagate Ironwolf 6TB HDD (StoreMI, 250GB SSD Partition+2GB RAM fast cache).
Silverstone 850W Strider Plus.
Custom water-loop in the works.
Silverstone FT02.
Operating System
Windows 10 1903.
Catleap Yamakasi Q270B (Overclocked to 110Hz).
Keyboard
SteelSeries 6Gv2.
Mouse
Microsoft Intellimouse Pro w/ GT-5000 grip-tape, CeeSa paracord cable.
Mousepad
Artisan FX Shidenkai XL.
Audio
Burson Play, Monoprice M1060C (modded), Audio-Technica ATH-A900X, Rode NTA-1 w/ Rode arm, Behringer PS400.
GHADthc is offline
post #4 of 43 (permalink) Old 07-11-2019, 10:44 AM
Never Finished
airisom2's Avatar
Rep: 279 (Unique: 216)
Sounds very similar to 8pack's product showcase at computex 2019.
1680 V2 4.5GHz | Trident X 4x4GB 2400MHz | R4BE | Titan Xp + Morpheus II
Wasabi Mango UHD550 | Enthoo Pro II | TS140P | Azeron Classic | Zaunkoenig M1K
Logitech G600 | Skypad 2.0 | Tt Meka G-Unit MX Black+Double O-Rings
JBL LSR308s | Temblor T10 | Custom headphones | TEAC-UD501+Passive Preamp | Emotiva BasX A-100
OCZ Vertex 4 256GB | 51TB DAS | SS Prime Ultra Titanium 1KW
airisom2 is offline
post #5 of 43 (permalink) Old 07-11-2019, 01:29 PM
I <3 narcissists
bigjdubb's Avatar
Rep: 228 (Unique: 143)
Another key feature of JetCool cooling is that the cooling fluid isn't passed over a surface like a heatsink or cold plate but instead "aimed directly at the surface".
Surely they don't mean directly at the surface of an IHS. So directly at the surface of what? I can't imagine it being anything other than a cold plate if they intend for the water it's spraying to be contained.
I think I figured out the diagram. They are talking about the direction the fluid is traveling, perpendicular to the IHS instead of parallel. This seems like it would require considerable pumping power.
Gaming Rig
(12 items)
Couch Gaming Rig
(10 items)
Work rig
(11 items)
Ryzen 7 3700x
Gigabyte X570 Master
EVGA RTX 2080ti FTW3
G.Skill TridentZ RGB
HP EX920 m.2
Intel SSD6 m.2
Intel SSD6 m.2
EVGA G3
CORSAIR H150I PRO
LianLi PC-O11 Dynamic
Operating System
Win 10 Home
LG 32GK650G
Ryzen 5 3600
Asus x470i
Radeon VII
Samsung 970 evo
InWin A1
NZXT M22
InWin A1
Operating System
Win10 Home
Vizio 4k TV
AMD Ryzen 7 2700X
Asrock X470 Taichi Ultimate
GTX 750
Patriot Viper
HP EX920 M.2
EVGA G3
CORSAIR H150I PRO
NZXT Source 210
Operating System
Windows 10 Pro
BenQ PD3200Q
LG 32UD59
bigjdubb is offline
post #6 of 43 (permalink) Old 07-11-2019, 01:44 PM - Thread Starter
mouacyk's Avatar
Pretty sure it sounds like they are intending to do direct-die jetting (whole new meaning to direct-die cooling . There has to be a pressure level that can deliver the performance of 10x common passive techniques, but still safe enough to not chip at the die over continuous usage. If that is too dangerous and complicated with mating issues to the rest of the PCB, they can still apply a thin but robust shim/plate to the die to act as a buffer but still draw heat efficiently.
RAM: 2x8GBTZ
Gentoo64 in Water
(14 items)
LGA775 X5470
(6 items)
9900K 5GHz 1.224v
EVGA Z370 Micro
970 EVO 500GB
Seasonic X850 Gold
Silverstone FT03
Operating System
Operating System
Keyboard
Logitech G710+
Mouse
Logitech G502
Audio
Sound Blaster Z
GA-EP45-UD3P
Lian-Li PC7-HX
mouacyk is offline
post #7 of 43 (permalink) Old 07-11-2019, 01:47 PM
I <3 narcissists
bigjdubb's Avatar
That makes sense but I'm not sure anyone would consider something like that to be a consumer solution.
Gaming Rig
(12 items)
Couch Gaming Rig
(10 items)
Work rig
(11 items)
Ryzen 7 3700x
HP EX920 m.2
Intel SSD6 m.2
Intel SSD6 m.2
EVGA G3
CORSAIR H150I PRO
Operating System
Win 10 Home
LG 32GK650G
Ryzen 5 3600
Asus x470i
Radeon VII
Samsung 970 evo
InWin A1
NZXT M22
InWin A1
Operating System
Win10 Home
Vizio 4k TV
AMD Ryzen 7 2700X
GTX 750
Patriot Viper
HP EX920 M.2
EVGA G3
CORSAIR H150I PRO
NZXT Source 210
Operating System
Windows 10 Pro
BenQ PD3200Q
LG 32UD59
bigjdubb is offline
post #8 of 43 (permalink) Old 07-11-2019, 01:52 PM
EniGma1987's Avatar
Rep: 348 (Unique: 257)
Looks like they are showing their block with no bottom and mounted directly against the IHS as the bottom of the unit (the brown piece is the IHS?)?
Or is the IHS supposed to be the turquoise color piece and the bottom of this is the brown piece?
EniGma1987 is offline
post #9 of 43 (permalink) Old 07-11-2019, 02:03 PM
I <3 narcissists
bigjdubb's Avatar
Yeah, I couldn't figure out that part of it. I think the main point of the diagram (besides confusing people so they don't question it) is to show that "traditional" cooling moves the water across the cold plate instead of hitting it head on.
Gaming Rig
(12 items)
Couch Gaming Rig
(10 items)
Work rig
(11 items)
Ryzen 7 3700x
HP EX920 m.2
Intel SSD6 m.2
Intel SSD6 m.2
EVGA G3
CORSAIR H150I PRO
Operating System
Win 10 Home
LG 32GK650G
Ryzen 5 3600
Asus x470i
Radeon VII
Samsung 970 evo
InWin A1
NZXT M22
InWin A1
Operating System
Win10 Home
Vizio 4k TV
AMD Ryzen 7 2700X
GTX 750
Patriot Viper
HP EX920 M.2
EVGA G3
CORSAIR H150I PRO
NZXT Source 210
Operating System
Windows 10 Pro
BenQ PD3200Q
LG 32UD59
bigjdubb is offline
post #10 of 43 (permalink) Old 07-11-2019, 02:11 PM
professional curmudgeon
looniam's Avatar
Rep: 840 (Unique: 465)
Another key feature of JetCool cooling is that the cooling fluid isn't passed over a surface like a heatsink or cold plate but instead "aimed directly at the surface". Check out the diagram below to see the tech comparison between traditional and JetCool cooling.
look at the thermal resistance legends on the sides:
typical set up:
die|package(tim/solder)|IHS(cu)|tim|heatsink|fluid
their solution/concept:
die|fluid
it looks to "squirt" cooling fluid directly on the die.
(incoming squirting jokes YO!)
this, from what i see in the article and that image, is for system integrators. since dies are not all the same sizes its going to be "one use/product" cases.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
If you need help: Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is online now
