Edifer 2.1 speakers.. which one of these ? - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 08-04-2011, 12:17 PM - Thread Starter
0razor1's Avatar
Rep: 31 (Unique: 26)
Price wise , 3060 So which one of these does anyone have had any experience with and/or recommend ?
Thanks!
P3060
Total RMS 30W
6.5 inch Subwoofer (14W)
Equipped with 3.5mm stereo and USB input port for thumb drive support
SRP RM179
P3080M
Total RMS 36W
6.5 inch Subwoofer (16W)
SRP RM239
P3080M Equipped with
1) 3.5mm stereo and USB input port for thumb drive support
2) Microphone input port allow for Karaoke and microphone capabilities with the volume and EQ control
M3200
Total power output: RMS 9W x 2 + 16W x 1
THD + N (testing level): 10%
Signal to noise ratio: ≥85dBA
Frequency response: Satellites: 145Hz - 20kHz | Subwoofer: 45Hz - 140kHz
Distortion: ≤0.5%
Input sensitivity: Satellites: 450mV ± 50mV (PC), 650mV ± 50mV (CD), 250 mV ± 50mV (AUX) | Subwoofer: 60mV ± 30mV
Input impedance: 10KΩ
AND lastly..
X600
Total power output: RMS 10W x 2 + 20W x 1
Frequency response: Satellites: 190Hz - 20KHz | Subwoofer: 20Hz - 170Hz
Distortion: ≤0.5%
Input sensitivity: Satellites: 420mV ± 50mV | Subwoofer: 60mV ± 10mV
This is all thats in stock with the retailer.
SO far, impressions :
the M3200 is good VFM , stylish too .. but not detailed /warm.
The x600 is raw power and detailed.. also , the bass extends into lower frequencies, but looks fugly , to begin with :/
Notice the ample spread over the spectrum!
I like the fact that the 30xxMs can be used with pen drives ^__^ but who really cares, right smile.gif
Th x600 has better audio I suppose , the 3060 is fragile while looking good smile.gif
the 3080 is the most expensive of the lot.. does it warrant a buy ??
I am 84% addicted to Counterstrike. What about you? HERE
Steam --> 0razor1
0razor1 is offline
post #2 of 6 (permalink) Old 08-04-2011, 07:23 PM - Thread Starter
0razor1's Avatar
BUMP!!
I have 3 hours before I buy this :/
Steam --> 0razor1
0razor1 is offline
post #3 of 6 (permalink) Old 08-04-2011, 07:28 PM
Senior Moderators
pioneerisloud's Avatar
None of them really reach below 100Hz very well anyway.
But based off the specs and the frequency response graph, the x600 looks to be the best one there. But even that has a SHARP cutoff at around 75Hz. But it already starts dropping off at around 100Hz.
DisposalAreav4.0
(15 items)
BayMax
(10 items)
FanzGoBrrr
(10 items)
Intel Core i7 2600k @ 4.65GHz, 1.45v (105.68x44)
Gigabyte Z68MA-D2H-B3
Asus RX580 8GB @ 1425 / 2150
Kingston HyperX (4x4GB) @ DDR3-1690, 9-9-9-24-1T, 1.66v
Crucial MX100 256GB + Sandisk Ultra 240GB RAID0 (400GB)
Toshiba 3TB 3.5"
Seasonic M12II Evo 520w
CoolerMaster 240mm
DIY PC Cuboid Blue mATX
Operating System
Windows 10 Pro x64
Hanns G 23" 1080p / 60Hz
Keyboard
Redragon 10 keyless
Mouse
Logitech Optical Mouse USB
Mousepad
Generic Onn Black
Audio
Diamond Edison 2.0
Intel Xeon E5-2608L v3 x2
SuperMicro X10DRL-I
Onboard
16GB (4x4GB) DDR4 ECC / Registered
Crucial BX500 120GB
40TB FreeNAS Array
CoolerMaster MasterWatt 750w
Arctic Cooling 92mm Tower x2
P Link USA 20 Hotswap Bay 4u Chassis
Operating System
FreeNAS
Intel Xeon E5-2683 v4 16 core x2
SuperMicro X10DRL-I
120GB Crucial BX500
1TB Crucial BX500
Toshiba 3TB 7200RPM x2 (RAID 1)
CoolerMaster Masterwatt 750w
P Link USA EATX Locking Front 4u Chassis
Operating System
Windows 10 + VMWare
pioneerisloud is offline
post #4 of 6 (permalink) Old 08-04-2011, 08:39 PM - Thread Starter
0razor1's Avatar
Instant LIKE!!
TBH , I can't stand those ultra low bass frequencies.. usually exaggerated and muddling on other 2.1 setups .. This way I like what I see.. the sharp drop is more like at 65Hz frown.gif
This should not disappoint me , and is alarmingly cheap!! In India , where things are crap expensive , contrary to popular belief, an AMD HD6950 card ( I just picked one up a fortnight back ) is for 350$ compared to the 220$ in the states..
Really!!
LOL!!
So the X600 it is!
Even though it's the blandest looker of them all../ I'll be taking off the side speaker's covers , should look better, something like this :
BTW , I like somewhat balanced sound..
looking at the frequency response.. this shouldn't be a problem , right ??
Steam --> 0razor1
0razor1 is offline
post #5 of 6 (permalink) Old 08-10-2011, 01:35 PM
Doomtomb's Avatar
Rep: 57 (Unique: 50)
Edifier 3080M, it has tweeters. The 3060M does not. That makes a HUGE difference.
Doomtomb is offline
post #6 of 6 (permalink) Old 08-10-2011, 01:53 PM - Thread Starter
0razor1's Avatar
Just picked up the X600 ..
Loving it ..
the highs are exceptionally well rolled off and the only thing lacking IMHO is v.low base.. else they do not disappoint. And they have tweeters, as you mentioned, make a BIG difference.
Same price as the M3200 , but didn't like the mids/ highs on the M3200.. the P3060 was too cheap ( for my liking) and hadn't any speaker grill . a bit of a problem since i live in a hostel, being small , they'd circulate a LOT.
I did boost the 60Hz frequencies from my soundcard mixer, makes things a lot better. Just goes to show a little extension of the frequency response into the ultra-lows would definitely helped. At least till 50Hz.
The P3080M was a shade more expensive, but honestly , it lacked the appeal of a good relatively balanced pair like the x600.
To add, the M3200s LOOK AMAZING in person .. Just wished they had red in stock.. Dislike blue.
Now need to find a good DAC for about 70$ in India = virtually impossible.
Steam --> 0razor1
0razor1 is offline
