Help me upgrade my home audio system - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 08-20-2011, 04:47 PM - Thread Starter
zerocrack's Avatar
Rep: 0
So here is what i have: http://www.e90post.com/forums/showthread.php?t=258459
I bought this on sale on black fridays few years ago and havent used it much since. I just recently model my living and hook this system up and notice the sound quality isnt that great so i am looking for an upgrade such as buying new speaker? I have about $200-$300 to spend but unsure how to get the best bang for the buck. I only need 2.1 btw
edit: wrong link, fixed
zerocrack is offline
post #2 of 11 (permalink) Old 08-20-2011, 04:55 PM
Rep: 38 (Unique: 38)
5.1 to 2.1 is no upgrade. i would instead buy a standalone equalizer to get better sound.
Techprimus is offline
post #3 of 11 (permalink) Old 08-20-2011, 04:59 PM - Thread Starter
zerocrack's Avatar
Rep: 0
well i read around a bit and i think i can buy a pair of really good speaker to swap out my current 5.1 and that pair of speaker can produce 5.1 since my receiver has 5 channel? and what do you mean equalizer?
I am a total noob at this so feel free to correct me.
post #4 of 11 (permalink) Old 08-21-2011, 05:37 AM
Retired Staff
soloz2's Avatar
Rep: 593 (Unique: 376)
2.0 or 2.1 can be a serious upgrade if you get a decent pair of speakers. You will loose some surround imaging from a properly set up 5.1 setup, but gain a lot more in stereo imaging, instrument separation, etc.
I have a cmplete 5.2 setup, but have only used 2.0 for the last couple years because it fit the room better.
You have an inexpensive receiver, but Onkyo's entry level stuff is pretty good. Upgrading your main speakers first is a great idea. With your budget you will likely wat to set aside $50 for stands and look at used bookshelf speakers. Start with a 2.0 setup for now. You can try your sub with better speakers, but after upgrading it will probably sound worse than no sub at all so I would consider selling your current speakers to increase your budget.
I havent looked at speakers in a couple years and the the speakers i would normally recommend are not made anymore. I did see that newegg has some martin logan towers on sale this weekend. I havent heard those ones but some of their higher end speakers are good, so they are probably a safe buy. I do recommend auditioning speakers before you buy if possible.
Sent from my A70S using Tapatalk
Current Sound: ODAC > SA Reference IC > Musical Paradise MP-301 6v6 tube amp> Tekton Designs 4.1 loudspeakers
Feedback: Heatware Ebay
soloz2 is offline
post #5 of 11 (permalink) Old 08-24-2011, 07:15 PM
hick's Avatar
Rep: 111 (Unique: 93)
LOL?!
Bookshelf or floor standing?
hick is offline
post #6 of 11 (permalink) Old 08-25-2011, 08:57 PM - Thread Starter
zerocrack's Avatar
Rep: 0
does those 2 matter in term of performance?
I was looking around on newegg and found this
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290034
are they any good? I am thinking about buy a pair of the speaker and save up for the bass then reciever. Is that going in right direction?
post #7 of 11 (permalink) Old 08-25-2011, 09:21 PM
I would go with these
http://www.ebay.com/itm/PAIR-Monitor-70-Series-II-CHERRY-Towers-Polk-Audio-/230661130726?pt=Speakers_Subwoofers&hash=item35b47989e6#ht_4994wt_1163
3 year warranty directly from Polk.
noak is offline
post #8 of 11 (permalink) Old 08-25-2011, 10:57 PM - Thread Starter
zerocrack's Avatar
Rep: 0
latest fry ad:
http://images.frys.com/art/facebook/newspaperads/110826_lisarbcfu/Arizona/FRYS_AZ_FRI_P1_082611.jpg
is the pair in jbl this: [ame="http://www.amazon.com/JBL-ES90BK-8-Inch-Floorstanding-Speaker/dp/B00166VDK8"]Amazon.com: JBL ES90BK 4-Way, Dual 8-Inch Floorstanding Speaker - Black: Electronics[/ame]
if so, i am gonna jump on that
post #9 of 11 (permalink) Old 08-26-2011, 08:16 AM
gorb's Avatar
Rep: 145 (Unique: 114)
The speakers in the frys ad are ES80s, not ES90s, but it's still a good deal.
http://www.jbl.com/EN-US/Products/Pages/ProductDetails.aspx?PID=ES80BK
gorb is offline
post #10 of 11 (permalink) Old 08-26-2011, 10:22 AM - Thread Starter
zerocrack's Avatar
Rep: 0
If i get that pair, what bass and receiver should i get later on to be on par with its? I want to make my system 5.1 down the road but a good 2.1 is okay for now
