Pansonic SC-PT870 - Overclock.net - An Overclocking Community
Pansonic SC-PT870
post #1 of 5 (permalink) Old 11-10-2011, 09:18 AM - Thread Starter
davidelliott-'s Avatar
Rep: 0
Hi,
I just purchased a Panasonic SC-PT870 Home Cinema system and i'm incredibly impressed! The system sounds amazing. The bass is rich and deep, music is clear. I'm using an Optical Cable from my computer to the receiver. I will take a video of the system asap smile.gif. Very impressed.
Centre: 250W 6ohms
Sub: 250W 6ohms
Sats (x4): 125W 3ohms
Overall - 1000W
davidelliott- is offline
post #2 of 5 (permalink) Old 11-10-2011, 06:54 PM
Eugenester's Avatar
Rep: 64 (Unique: 52)
Don't want to rain on your parade, but wait until you buy some "real" bookshelves/floorstanders. thumb.gif
My Little Pony: Friendship is Magic Fanclub!
Eugenester is offline
post #3 of 5 (permalink) Old 11-10-2011, 09:47 PM
mdocod's Avatar
Rep: 621 (Unique: 408)
Jeez.. Is it ever going to stop with the watts. Won't be long and they'll be claiming more total watts than you can even get out of a 110V-20A circuit.
Forget about the watts. The only people who should be concerned with or impressed by enormous wattage ratings are sound reinforcement teks and SPL drag contenders. The rest of the world listens at less than a watt per channel most of the time, and perhaps a few watts into a sub.
So, I'm going to pick on you for a moment as a teachable moment to others. Did your decision to go with that particular system have anything to do with the wattage rating compared to alternative options? The fact that the only information you chose to share initially about the system to others is the watts per channel, suggests that the wattage rating was an important factor in your purchasing decision.
As it turns out, for home stereo and home theater, wattage "ratings" are one of the least, if not, the least important characteristic of the system. Unfortunately, budget audio gear, with no specifications that would sound very good on paper when stacked against alternatives, has resorted to clouding the market with the misleading premise that wattage does matter, and have managed to perpetuate that lie into the masses of consumers by highlighting wattage ratings as the leading indicator of system performance.
The more important question about wattage ratings on your gear should be: How many CLEAN watts? AND- how clean is "clean?"
Many people will tell you that the best upgrade path for the system would be a better set of speakers. In my experience, it is the amplifier quality that is more important. It is counter intuitive because the amplifier is not the component that you actually get the "sound" out of, so the mind tells us, that the sound quality is dependent primarily on the speakers. In truth, even simple cheap speakers are generally capable of playing most of the listening range with reasonable enough accuracy. It's the amplification quality (not rated "quantity") that really brings out the "best" in those speakers.
A CPU performance comparison chart.
"Kind of a ring thing, comes with a dialer, you hit the symbols, it spins around and lights come on, it kind of flushes sideways" -O'Neill
mdocod is offline
post #4 of 5 (permalink) Old 11-10-2011, 09:50 PM
skatingrocker17's Avatar
Rep: 225 (Unique: 199)
I agree. HTIBs usually get the job done but aren't as good as something you put together yourself.
skatingrocker17 is offline
post #5 of 5 (permalink) Old 11-11-2011, 07:07 PM - Thread Starter
Rep: 0
' Did your decision to go with that particular system have anything to do with the wattage rating compared to alternative options?'
No. I choose it because it has a really deep and rich bass.
I'm happy with the system so meh smile.gif!
