Deciding between 3 Yamaha Receivers - Page 2 - Overclock.net - An Overclocking Community
post #11 of 21 (permalink) Old 11-28-2011, 06:08 PM
Linux Lobbyist
astrallite's Avatar
Rep: 206 (Unique: 163)
Originally Posted by mdocod View Post
In my experience, most of the cheaper receivers, like the ones being compared in this thread, will only increase their available output by ~66% when the resistance is cut in half TWICE, which means, less than 200WPC into 2 ohms for most ~100WPC rated receivers, even though they are rated ~100WPC into 8ohms.
Eric
Which receivers have you seen that can provide 66% more power when load is halved?
Most of the receivers I've seen only put out maybe 30% more power.
The two most powerful receivers made in the last 10 years--the 80lb Yamaha RX-Z11 and the 97lb Denon AVR-5805--both only output 44% more power when load goes from 8 ohms to 4 ohms.
A typical receiver these days may actually produce less power into 4 ohms then 8 ohms like this Denon 1612, which only produces 70% as much power into 4ohms, and if it goes up, most only increase it by about 30-40% such as this Pioneer VSX 821.
Even power amplifiers, like this $15,000 Denon, only increase power by 49% into 4 ohms.
astrallite is offline
post #12 of 21 (permalink) Old 11-29-2011, 01:22 PM
gorb's Avatar
Rep: 145 (Unique: 114)
and good luck finding a receiver that's actually stable into 2 ohms
gorb is offline
post #13 of 21 (permalink) Old 11-29-2011, 05:49 PM
Eugenester's Avatar
Rep: 64 (Unique: 52)
Not too hard to find those.
My Little Pony: Friendship is Magic Fanclub!
Eugenester is offline
post #14 of 21 (permalink) Old 11-29-2011, 08:13 PM
gorb's Avatar
I doubt that.
gorb is offline
post #15 of 21 (permalink) Old 11-29-2011, 08:43 PM
Linux Lobbyist
astrallite's Avatar
The Polk Lsi series drops down to as low as 2.5 ohms in the woofer range, NHT Classics are about 4.2 ohms across the woofer band, and the Revel Ultima series run about 3.8 ohms. These are among the hardest speakers to drive recently made that I know of.
A solid 2 ohm load across the woofer band would be extremely rare and you would probably need some huge monoblocks for that.
As far as a fully 2 ohm stable receiver (capable of driving a nominal 2 ohm speaker), I can't name one off the top of my head. I don't think even think Yamaha RX-Z11 or Denon AVR-5805 could handle that without the protection circuit kicking in.
post #16 of 21 (permalink) Old 11-29-2011, 09:05 PM
Eugenester's Avatar
I meant amps, like from QSC Behringer, Crown, etc. Since you would be using the pre-outs anyway if you needed that much power.
post #17 of 21 (permalink) Old 11-29-2011, 09:21 PM
Linux Lobbyist
astrallite's Avatar
post #18 of 21 (permalink) Old 11-29-2011, 10:03 PM
Retired Staff
hertz9753's Avatar
Rep: 167 (Unique: 122)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260901106567&category=39783&_trksid=p5197.c0.m619
Something like this?
Don't walk behind me; I may not lead. Don't walk in front of me; I may not follow. Just walk beside me and be my friend.
AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 passive bi-amped(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's
Sub-Velodyne SPL-1000R
hertz9753 is offline
post #19 of 21 (permalink) Old 11-29-2011, 10:11 PM
Linux Lobbyist
astrallite's Avatar
That's a power amplifier not a receiver. If you are going to talk about power amplifiers you might as well get a pair of Emotiva XPA-1s.
http://emotiva.com/xpa1.shtm
A pair of 1200VA transformers, 1000W/channel into 4 ohms, 240,000uF of capacitance.
post #20 of 21 (permalink) Old 11-29-2011, 10:30 PM
Retired Staff
hertz9753's Avatar
http://www.allegrosound.com/Sansui_B2101.html Pretty cool for a vintage amp though.smile.gif To be honest I couldn't run any of those amps in my house for very long without tripping a circuit.
I have a H/K 3490 and a pair of Lsi9's in 10x12 room.redface.gif
AVR-Onkyo TX-NR808
