[SOLVED] 2.0 amplifier 150 watts rms... 8 ohms Does it exist? [SOLVED] - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 02-03-2012, 05:19 PM - Thread Starter
Mr. Original's Avatar
Rep: 18 (Unique: 17)
I have 2 tp1200 i am looking to power http://www.amazon.com/TP1200-300W-Tower-Speaker-Syst/dp/B002VLQHLM/ref=sr_1_1?ie=UTF8&qid=1328318128&sr=8-1 Is there a amp that does 150watts rms for 2 channels at 8 ohms? I searched but the most i can find is around 100 watts per channel i am trying to keep it cheaper hopefully <300$
Thanks for your help/expertise redface.gif
Mr. Original is offline
post #2 of 8 (permalink) Old 02-03-2012, 05:23 PM
Retired Staff
SgtSpike's Avatar
Rep: 236 (Unique: 195)
Last I checked, $100 was indeed cheaper than $300.
Regardless, I've seen lots of car amps that go in that range, if you want to hack something together. If you want it to be pretty, might be more difficult and expensive. I'm not that familiar with receivers that do more than 100w though, simply because I haven't ever needed to look for one.
SgtSpike is offline
post #3 of 8 (permalink) Old 02-03-2012, 05:25 PM
Retired Staff
pioneerisloud's Avatar
Rep: 1388 (Unique: 956)
Those speakers would run just fine with 100w RMS though. Just pick a good quality receiver, and that'll do the job fine honestly. If you feel that you need more power later (you shouldn't...but if you do), you can always amplify the speakers later with a seperate amplifier.
Retro Rig
(17 items)
Core 2 Quad Q9550 @ 3.4GHz, 1.15v BSEL Modded
HP DC 7900 Series
MSI GTX750Ti Low Profile
4x2GB Samsung DDR2-800
Intel 330 120GB
2x 500GB WD Black 2.5" RAID0
Optical Drive
Samsung DVDRW
Lite On 240w Bridged Rails
Stock HP DC7900 Intel
HP DC7900 Slim Tower
Operating System
Windows XP Professional SP3 x86
Operating System
Kubuntu 18.04 x64
Dell 2007FP
Keyboard
Razer Chroma
Mouse
Logitech G602
Audio
Dayton DTA-120
Audio
Micca MB42x
pioneerisloud is offline
post #4 of 8 (permalink) Old 02-03-2012, 05:36 PM - Thread Starter
I had a 100 watt per channel and fried the amp after using it to its max.... These play in a frat house so loud is the key ha ha i just want a amp that can blow up the speakers not the other way around....
post #5 of 8 (permalink) Old 02-03-2012, 05:44 PM
Retired Staff
You didn't fry the amp because of the speakers. If anything underpowering speakers will blow them faster than overpowering them due to distortion levels. Your old amp died on its own.
If you MUST run 150w RMS, this is the cheapest amplifier that I know of:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-652
I'd rather recommend a good quality 100w RMS amp or receiver instead though honestly. The difference will be negligible, and you're likely to distort things badly either way if you really are cranking things THAT loudly.
EDIT:
There's also this Pyle:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=248-480
Its a good bit cheaper, and for good reason. It claims 200w RMS at 8ohm though (I doubt it'll even do 100 though).
Retro Rig
(17 items)
HP DC 7900 Series
Intel 330 120GB
Optical Drive
Samsung DVDRW
Operating System
Operating System
Kubuntu 18.04 x64
Dell 2007FP
Keyboard
Razer Chroma
Mouse
Logitech G602
Audio
Dayton DTA-120
Audio
Micca MB42x
post #6 of 8 (permalink) Old 02-03-2012, 06:21 PM
Retired Staff
hertz9753's Avatar
Rep: 167 (Unique: 122)
There is also the H/K 3490 and it has preouts.
http://www.jr.com/harman-kardon/pe/HK_3490/
Don't walk behind me; I may not lead. Don't walk in front of me; I may not follow. Just walk beside me and be my friend.
AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 passive bi-amped(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's
Sub-Velodyne SPL-1000R
hertz9753 is offline
post #7 of 8 (permalink) Old 02-03-2012, 06:25 PM
mdocod's Avatar
Rep: 621 (Unique: 408)
For $300, this is easy: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=245-500
Rated 215W RMS into 8 ohm. $300.
If you can afford $400: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=245-502
A CPU performance comparison chart.
"Kind of a ring thing, comes with a dialer, you hit the symbols, it spins around and lights come on, it kind of flushes sideways" -O'Neill
mdocod is offline
post #8 of 8 (permalink) Old 02-04-2012, 07:45 PM
Linux Lobbyist
astrallite's Avatar
Rep: 206 (Unique: 163)
Those Crown amps will definitely put out a ton of power.
astrallite is offline
