"Budget"-Themed Home Theater Set-up - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 01-29-2013, 05:37 AM - Thread Starter
13ack.Stab's Avatar
Rep: 8 (Unique: 6)
Hey, guys.
I've been meaning to upgrade my home theater system for a long, long time now, but I've always had other things to buy that took higher priority. I've been rocking a 70" plasma TV that supports 1080i at best and two fifteen-year-old floorstanding speakers that sound pretty impressive for their age.
It's not exactly an impressive set-up, but it's done a great job over the past few years.
The other day, however, I received a new projector as a gift, and so I figured I might as well upgrade my sound system as well.
That said, I only have a little experience in this area, so I'd love to get some advice from you all.
I'm looking to get a 5.1-channel system, though I may just start with 2.1 and build it up over time. A friend recommended that I just go with a "home theater in a box" deal, but from what I've seen, they seem to be pretty disappointing.
I started out with an initial budget of $500 in mind, but that seems to be pretty low-end and, honestly, somewhat unreasonable. I would like to keep costs down as much as possible, but I also don't want to have to sacrifice too much quality. Go figure, right?
I'm completely open to suggestions, but here are some things that I found intriguing:
  1. Receiver: ONKYO TX-NR515 7.2-Channel Network 3D Ready A/V Receiver ($299)
  2. Front Left/Right Speakers: Klipsch WF-35 Icon-W Series ($269 x2 = $538)
Unfortunately, I'm already way over my budget, and I'm still missing a bunch of speakers and a subwoofer!
What do you guys think?
Thanks.
13ack.Stab is offline
post #2 of 8 (permalink) Old 01-29-2013, 06:22 AM
Location: "Joy is but the shadow of pain" You'll figure it out.
Rep: 57 (Unique: 54)
Buy a new reciever before spending more money on speakers, if the ones you have still work you could buy something more expensive and put the speaker upgrade on hold. And remember, a can of spraypaint, jar of Laquer and some sandpaper does wonders.
Huzzbutt is offline
post #3 of 8 (permalink) Old 01-29-2013, 12:15 PM - Thread Starter
13ack.Stab's Avatar
Rep: 8 (Unique: 6)
Hey, thanks for the reply.
I'm more than aware that I could add onto my system over time, as I mentioned in my post -- but what I'm really looking for is suggestions for the speakers and receiver.
I will, however, purchase the receiver first per your recommendation.
post #4 of 8 (permalink) Old 01-29-2013, 12:22 PM
Foolsmasher's Avatar
Rep: 93 (Unique: 80)
Best ballin' on a budget set of speakers:
Pioneer SP-BS22-LR Speaker System
Read the review here
Also, always budget more money for speakers than you do a receiver. As long as you aren't trying to drive 4 ohm loads, you'll always get more performance for your dollar with speakers than w/ amps. Unless your amp is clipping, you get into diminishing returns in sound in a big time hurry, so much so that in a blind test even highly trained ears can't distinguish a $5,000 amp from a $500 one.
Foolsmasher is offline
post #5 of 8 (permalink) Old 01-29-2013, 12:33 PM - Thread Starter
13ack.Stab's Avatar
Rep: 8 (Unique: 6)
Wow, that whole speaker set is pretty intriguing. I'll definitely consider getting them, thanks for the recommendation!
Your review link doesn't work for me, though.
post #6 of 8 (permalink) Old 01-29-2013, 12:36 PM
http://www.hometheater.com/content/pioneer-sp-bs22-lr-speaker-system
Also if you don't mind buying used, Denon receivers that are a year or two old do not hold their value well at all and can be had very cheap on eBay. Start looking at something like a Denon 1912 and see if it has the features you need.
post #7 of 8 (permalink) Old 01-29-2013, 12:38 PM - Thread Starter
13ack.Stab's Avatar
Rep: 8 (Unique: 6)
Actually, it just wasn't working on Chrome. Maybe Adblock was, ah, blocking it. Works fine in Firefox, thanks again.
post #8 of 8 (permalink) Old 01-30-2013, 09:55 AM - Thread Starter
13ack.Stab's Avatar
Rep: 8 (Unique: 6)
Does anyone else have some feedback on good speakers or receivers, or suggestions in general? smile.gif
