Onkyo TX-SR600 sound extremely flat vs old pioneer A331 - Overclock.net - An Overclocking Community
post #1 of 9 (permalink) Old 09-30-2015, 12:57 PM - Thread Starter
222Panther222's Avatar
Rep: 36 (Unique: 35)
Only have 2 speakers hooked to it and It seems that the amp doesn't send the frequency below 80hz to them.
I made sure speakers are well connected, that they are set to "Large" and sub-woofer option to off.
I also reset the receiver, it's like there is no low at all, even eq with the bass at +12.
Then when i switch to my old pioneer and the lows are there.
_
Never believe the hype.
Consoles aren't about hardware, they're about good games.
_________________________________________________________
222Panther222 is offline
post #2 of 9 (permalink) Old 10-01-2015, 06:31 AM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Have you tried messing around with these controls?
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 9 (permalink) Old 10-01-2015, 03:47 PM - Thread Starter
Yes there is no difference between DIRECT or STEREO mode and the AUDIO ADJUST button is for the treble/bass which even at +12 doesn't sound deep as the pioneer.
_
post #4 of 9 (permalink) Old 10-01-2015, 04:19 PM
Overclock Failed...
HDoes it make any change at all?
post #5 of 9 (permalink) Old 10-01-2015, 04:45 PM - Thread Starter
It does sound a bit more punchy but not deep as the other one. What could cause that?
_
post #6 of 9 (permalink) Old 10-01-2015, 08:01 PM
Overclock Failed...
I suspect you have some setting someplace set incorrectly. but, alas, I have no idea what that would be.
I use just a simple stereo amp, I have no truck with all the controls on Av receivers.
post #7 of 9 (permalink) Old 10-03-2015, 12:51 AM
Retired Staff
hertz9753's Avatar
Rep: 167 (Unique: 122)
Can you find that in the setup menu under speakers?
Don't walk behind me; I may not lead. Don't walk in front of me; I may not follow. Just walk beside me and be my friend.
AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 passive bi-amped(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's
Sub-Velodyne SPL-1000R
hertz9753 is offline
post #8 of 9 (permalink) Old 10-06-2015, 05:34 PM
DzillaXx's Avatar
Rep: 553 (Unique: 389)
Not all Receivers are equal.
I had tested a old crappy sony 5.1 receiver once before, and it was horrid compared to the yamaha I had. Lacked in the lower end, almost sounded like a tin can.
Onkyo Receiver have been known from time to time to sound more hollow, especially the lower end models.
Really not much you can do. It is a fault with the Receiver's weak AMPs and undersized power supply. Most likely it is limited by how much power can be feed into each amp.
If you can, send it back and pickup a Yamaha. Yamaha doesn't mess around with crappy sounding receivers. Denon make some good receivers as well.
Also a Powered Sub may help, but wont fix the real problem.
Also ^ Yes make sure you don't have any active crossover active on your speakers.
DzillaXx is offline
post #9 of 9 (permalink) Old 10-06-2015, 05:55 PM
Retired Staff
hertz9753's Avatar
Just stop.
AVR-Onkyo TX-NR808
