New Logitech speakers issue. Speaker levels not balanced at low volume. Is this normal or should I RMA? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 07-02-2016, 04:35 AM - Thread Starter
Wort's Avatar
Rep: 0
Hey. Yesterday I bought Logitech Z333 speakers. Overall, I'm really satisified with the speakers, but I noticed one issue. When I listen to the music in the evening and turn the volume regulator almost to minimum, one of the speaker's volume is MUCH lower (you can barely hear. It's annoying because the sound is coming from one speaker only and it really feels weird. When I turn the regulator back to "normal" volume, both start working again.
Is this normal behavior of potentiometers / volume regulators or should I RMA?
Wort is offline
post #2 of 5 (permalink) Old 07-02-2016, 07:08 AM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Before you start blaming Logitech, and wasting a lot of time, you should determine if it's the speakers causing the problem or if you system is causing the problem.
You could:
Reverse the right and left channel sources being sent to the speakers and see if the problem moves too.
Try the speakers with a different source (smartphone?. another computer?) and see if the problem persists.
And, no, that's not the way potentiometers nor a speaker system should behave.
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 5 (permalink) Old 07-02-2016, 09:35 AM - Thread Starter
Wort's Avatar
Rep: 0
Same thing happens when I plug speakers on another PC. I also tried switching channels and the speaker plugged in L (left channel) has the issue...
Wort is offline
post #4 of 5 (permalink) Old 07-02-2016, 03:00 PM
Overclock Failed...
Then it's the speaker that's bad.
post #5 of 5 (permalink) Old 03-17-2017, 12:01 PM
I <3 narcissists
bigjdubb's Avatar
Rep: 219 (Unique: 136)
Low volume channel imbalance is nothing new and not usually the fault of the speaker itself. The problem more than likely lies with the volume control itself. It's very common with analog volume control (potentiometer), especially lower quality volume controls.
If you do a search for low volume channel imbalance you will find plenty of discussions.
EDIT: Sorry to necro this thread, for some reason it was showing up as new for me and I didn't even look at the date since it was bolded.
Gaming Rig
(12 items)
Couch Gaming Rig
(10 items)
Work rig
(11 items)
Ryzen 7 3700x
Gigabyte X570 Master
EVGA RTX 2080ti FTW3
G.Skill TridentZ RGB
HP EX920 m.2
Intel SSD6 m.2
Intel SSD6 m.2
EVGA G3
CORSAIR H150I PRO
LianLi PC-O11 Dynamic
Operating System
Win 10 Home
LG 32GK650G
Ryzen 5 3600
Asus x470i
Radeon VII
Samsung 970 evo
InWin A1
NZXT M22
InWin A1
Operating System
Win10 Home
Vizio 4k TV
AMD Ryzen 7 2700X
Asrock X470 Taichi Ultimate
GTX 750
Patriot Viper
HP EX920 M.2
EVGA G3
CORSAIR H150I PRO
NZXT Source 210
Operating System
Windows 10 Pro
BenQ PD3200Q
LG 32UD59
bigjdubb is offline
