Coaxial Output from pc to Onkyo SR600 - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 11-21-2016, 12:42 AM - Thread Starter
222Panther222's Avatar
Rep: 36 (Unique: 35)
Coaxial output pc >Coaxial receiver input>headphone plugged in receiver.
The input selection are dvd/video1/2/3/4/tape/tuner/cd
I selected CD input with the audio set to coaxial input the receiver (so it should be the pc signal).
It is detected in the Realtek digital output, the sound bar move when i do the "test" option or play music but still no sound in headphone..
If i select Speakers as default (which the signal is sent from pc 3.5mm to L/R Rca in the receiver CD input there is sound.
_
Never believe the hype.
Consoles aren't about hardware, they're about good games.
_________________________________________________________
222Panther222 is offline
post #2 of 2 (permalink) Old 11-21-2016, 08:03 AM - Thread Starter
Solved it was in the realtek digital output advanced tab, i had to set the default format to dolby digital live 5.1 surround. I also deactivated the front panel audio jack.
_
