Using old DVD (5+1) audio with new Samsung TV? - Overclock.net - An Overclocking Community
post #1 of 8 (permalink) Old 06-23-2018, 04:42 AM - Thread Starter
darkfirebg's Avatar
Rep: 6 (Unique: 3)
Hello guys,
I just bought a new Samsung UE50MU6100 and i really want to use my old DVD Philips LX3900SA 5+1 Audio system.
Problem is the DVD does not have HDMI nor optical audio connection.
According to its specification the DVD has the following connectivity options:
Analog audio Left/Right in
ComponentVideo out Progressive
Composite video (CVBS) out
Digital coaxial in
FM Antenna
Line out
MW Antenna
S-Video out
and SCART
While the TV has
Composite In (AV)
Digital Audio Out (Optical)
HDMI
Component In (Y/Pb/Pr)
Lan
USB
I tried hooking it up with RCA (both via scart and without) but it does not work. While it works perfect with my old Toshiba TV (2010 model)..
Do you see any options on hooking these two devices together?
Any help/suggestions would be appreciated..
darkfirebg is offline
post #2 of 8 (permalink) Old 06-24-2018, 11:01 AM
Tiihokatti's Avatar
Rep: 260 (Unique: 210)
TV's do not have any kind of analog outputs these days.
The only analog output the TV could have these days is the headphone output, and even that is usually removed because of that utterly stupid trend Apple made. And in your case exactly that has happened (no headphone output).
Your HTIB (home theater in a box) seems to have coaxial (aka. Digital) input as the only "viable" option, but your TV doesn't have it. Coaxial and optical are pretty much the same thing data-wise, except coaxial uses electricity and optical uses light to transfer the data from one end to another.
In a nutshell: You can't connect the speakers to your TV. The only thing that could barely be called a solution would be to get an external DAC (like this one) that uses optical and plug that to the L/R analog inputs of the HTIB.
Ppl should learn to add more info to their posts when they ask for help...
OCN Anime/Manga Club
[Official] OCN Headphones and Earphones Club
Tiihokatti is offline
post #3 of 8 (permalink) Old 06-24-2018, 11:20 AM
Linux Lobbyist
brucethemoose's Avatar
Rep: 453 (Unique: 358)
I haven't tried them myself, but you could get an optical to coaxial audio converter.
Sent from my Sig Rig
brucethemoose is offline
post #4 of 8 (permalink) Old 06-24-2018, 01:32 PM - Thread Starter
darkfirebg's Avatar
Rep: 6 (Unique: 3)
Tiihokatti, thanks, i found similar DAC around here for 15 EUR and will give it a try!
post #5 of 8 (permalink) Old 06-25-2018, 05:01 PM
Linux Lobbyist
That'll work, but it'll just be upmixed stereo. Also, there's a risk you'll get buzzing from cheap DACs, depending on which one you got.
Get an optical->coax converter instead, and you can send real 5.1 surround sound to your DVD system. And there's no risk of sound quality degredation, it either works perfectly or it doesn't work at all.
post #6 of 8 (permalink) Old 06-25-2018, 05:25 PM
Overclocker
JackCY's Avatar
Rep: 338 (Unique: 240)
Use your TV as a target device not as a source. This way you can split audio and video to different paths, send audio to your audio setup and video to the TV.
JackCY is offline
post #7 of 8 (permalink) Old 06-26-2018, 02:41 AM
Tiihokatti's Avatar
I'm looking at the HTIB manual at the moment, and I'm about to facepalm pretty damn hard at Philips.
– For your playback through DIGITAL IN
connection, set the digital output of that
player to PCM format.
Which means that the coax-in doesn't have support for DTS/DDL decoding... NICE JOB PHILIPS, NICE JOB!
In laymans terms (for the OP): The coaxial input is a pile of turd with no real use as long as the analog inputs work fine.
post #8 of 8 (permalink) Old 06-26-2018, 03:22 AM - Thread Starter
darkfirebg's Avatar
Rep: 6 (Unique: 3)
Thanks, the DAC seemed really cheap indeed, so maybe that's a better option.
I found relatively cheap (22eur) HAMA 42906, Coax IN/Optical OUT ODT available, and will order to give it a try. Hope it will work!
Edit: Which one do i need? Coax IN/Optical OUT ODT or Optical IN ODT (Toslink)/Coax OUT? Sorry, a bit lost here.
