Is there a way to boost a fm radio antenna? - Overclock.net - An Overclocking Community
post #1 of 2 (permalink) Old 03-22-2019, 05:15 PM - Thread Starter
lorcav123's Avatar
Rep: 0
I bought this FM radio clock:
https://www.aliexpress.com/item/Mirr...75954c4d9hfxdz
but the radio signal is too weak, on 80 % of radio stations I hear crackling. Is there a way to boost a fm radio antenna? I think that at least 20% boost would solve crackling problem....
I was told that I should try to extend radio antenna cable with some metal wire if I understood correctly? ???? I need to cut those rubber layer skin on antenna and that connect that to metal extender?
lorcav123 is offline
post #2 of 2 (permalink) Old 03-22-2019, 05:23 PM
486DX2 66
Serious_Don's Avatar
Rep: 205 (Unique: 125)
Strip off the last 1 or 2 inches of the rubber to expose the (copper?) wire inside. Try sticking that out a window to see if that helps at all and to rule out interference in your home.
I would cut about 5 feet of 16~ gauge speaker wire and completely replace that cable by soldering one end to the receiver and running the other end up the wall in a Y shape. Or you can try soldering it to the end of the existing cable (if you can't solder, just expose the copper wire about 1-2" and twist them together as good as you can).
Could also be that the stations you're listening to are > 90 miles away.
Can't hear my delta fans over my Death Metal crew
The sound of fallingWhen the pictures are movingBetween the memories
I Just Found Out My PCs Have A Power Button. Meh, Still Not Shutting Down Club Member #00001
Ban Thread Bot
(19 items)
HAF Baked
(16 items)
M-M-Monster Kill
4790k
Asus z97 Pro WIFI AC
Vega 64
16GB 'Team Pook' Xtreem DDR3
250GB Samsung Evo 840
2 x 3 TB Western Digital Black Sata 6gb/s
2 TB WD Green
Corsair HX850
Corsair H100i
Corsair 900D
Operating System
Windows 7
Operating System
Ubuntu
LG 27UD58P-B
AOC g2770pqu
Sony Bravia 40"
Keyboard
Corsair Strafe RGB
Mouse
Corsair Vengeance M65
Mouse
Gigabyte Ghost Extreme Accuracy
Audio
Sound Blaster X-Fi
FX 8320
Asus
Sapphire Tri-X 290
Corsair Vengeance 1600
Corsair Forse LS SSD
Samsung Spinpoint F3
Optical Drive
Asus 24x DVD-RW
EVGA
CM Hyper 212 Evo
Cooler Master HAF 922
Operating System
Debian 9 & Win7
Asus VH236H
Keyboard
Ancient Dell Mechanical
Mouse
Corsair MX65
Mouse
Pentium III
Intel SE440BX-2
GeForce MX 440 AGP 8X
Viking PC133 SDRAM
Viking PC133 SDRAM
Western Digital Caviar
Western Digital Caviar 39000
Optical Drive
LG DVD/RW
Stock
Operating System
Windoze 98
Audio
Sound Blaster Pro2
Audio
Sound Blaster 16
Audio
Sound Blaster Live!
Serious_Don is online now
