Home surround 5.1 setup help - Page 3 - Overclock.net - An Overclocking Community
post #21 of 27 (permalink) Old 11-05-2019, 10:33 AM - Thread Starter
TAr
Rep: 20 (Unique: 18)
Quote: Originally Posted by UltraMega View Post
https://assets.bose.com/content/dam/...iii-am10iv.pdf
Looks like that VGA cable thing has bare wires on the other end that plug directly into the speaker outputs on a receiver, so any receiver should work.
If I unplug the rear wire will the 3 front speaker will work plus my subwoofer?
TAr is offline
post #22 of 27 (permalink) Old 11-05-2019, 01:27 PM - Thread Starter
TAr
Can u explain please what that means
Sorry I'm.just new to audio and dont know anything
TAr is offline
post #23 of 27 (permalink) Old 11-06-2019, 12:50 PM
JMCB's Avatar
Rep: 61 (Unique: 60)
Yes, they will work. Essentially what the bass module for the Bose system is doing is regulating the power for the speakers and some digital signal processing. You don't have to run all the speakers.
CPU: Intel i7 9900KF -- GPU: 2x Nvidia RTX 2080 Ti Founder's Edition -- Motherboard: Asus ROG Maximum XI Hero Wifi -- RAM: 64 GB DDR4 Corsair Vengeance RGB -- SSD: Samsung 970 EVO 500GB M.2 -- HD: WD 4TB Blue -- Power Supply: Corsair HX1200 -- Case: Thermaltake Tower 900 -- OS: Windows 10 Pro -- Monitor: Asus ROG SWift PG27UQ 4k 144hz -- Keyboard: Steelseries Apex Pro -- Mouse: Steelseries Rival 710
JMCB is offline
post #24 of 27 (permalink) Old 11-06-2019, 06:19 PM - Thread Starter
TAr
Thanks alot I will try it and will update how it did
TAr is offline
post #25 of 27 (permalink) Old 11-06-2019, 06:40 PM
Graphics Junkie
UltraMega's Avatar
Rep: 33 (Unique: 29)
Why are you trying to mix two different speaker sets?
i7 7700kK @4.2ghz
16GB DDR4 3200mhz
GeForce 1080 Ti
UltraMega is offline
post #26 of 27 (permalink) Old 11-06-2019, 06:47 PM - Thread Starter
TAr
So I wanna try.it tonight after work
So when I unplug
I should unplug the rear speakers from subwoofer and av reciver
Is that right?
TAr is offline
post #27 of 27 (permalink) Old 11-14-2019, 11:01 AM
Rep: 0
LFE!
The .1 (sub) is an essential component of a "5.1" system, handling the low frequency effects (LFE) to great effect depending on quality and location.
va_cavalier69 is offline
