can i use bookshelf speakers for center speakers - Overclock.net - An Overclocking Community
post #1 of 27 (permalink) Old 12-10-2019, 11:37 AM - Thread Starter
TAr
Rep: 20 (Unique: 18)
I have Klipsch R41M 50-Watt Bookshelf Speaker and want to use one of them as a center channel and not sure if it work
TAr is offline
post #2 of 27 (permalink) Old 12-10-2019, 11:38 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1247 (Unique: 682)
yep.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 27 (permalink) Old 12-10-2019, 12:03 PM - Thread Starter
TAr
If I put them side ways will still work?
And also I have it in pair can I combine 2 of them side by side In the centre and use them as one speaker
This is the model Klipsch R41M 50-Watt Bookshelf Speaker
TAr is offline
post #4 of 27 (permalink) Old 12-10-2019, 12:11 PM
Bad5ector's Avatar
Rep: 10 (Unique: 7)
Depending on the AV receiver you might have the Bi-Amp option for the center channel, that would power both speakers at the same time and would have their own outputs. If you don't have a Bi-Amped center channel, you could I guess, double up on the speaker cable and combine the negative and positive ends of both cables and squeeze them all into the single center channel outputs on the receiver. The latter is pretty jank and probably wouldn't be good for both the receiver and the speakers long term. Probably best to stick with the single speaker as your center.
ShadowMoses
(21 items)
i7 7700K
ASUS ROG Maximus IX Formula LGA1151
EVGA GeForce GTX 1080 Ti Founders Edition
Corsair Vengenace Lpx 32GB DDR4 3200MHZ
Seagate ST1000DX001 SSHD 1TB 3.5in SATA3 64MB Cache Internal Solid State Hybrid Drive
Kingston HyperX Predator 240GB
EVGA SuperNOVA 1000 G1 80 Plus Gold Certified 1000W Fully Modular
RAD - EK-CoolStream XE 360
CPU Block - EK-Supremacy EVO - Nickel
GPU Block - EK-FC Titan X Pascal - Nickel
Pump / Res - EK-XRES 140 Revo D5 PWM (incl. sleeved pump)
Fans - 3 x EK-Vardar F4-120ER (2200rpm)
Coolant - EK-Ekoolant Pastel BLUE (concentrate 250mL)
Tubing - EK-DuraClear 11,1/15,9mm
Thermaltake Core P3 SE Snow Edition
Operating System
Microsoft Windows 10 Pro 64Bit
BenQ XL2720Z 27in LED 144HZ 1ms GTG FPS Gaming Monitor
42" LG TV
Keyboard
Corsair Gaming K65 Lux RGB Compact Mechanical Keyboard
Mouse
Corsair Gaming M65 Pro RGB Optical Gaming Mouse
Mouse
Corsair Gaming MM300
Bad5ector is offline
post #5 of 27 (permalink) Old 12-10-2019, 12:15 PM
professional curmudgeon
looniam's Avatar
Rep: 808 (Unique: 457)
you can do anything you want as long as you mind the ohms and RMS of both the speaker(s) and amp.
https://www.themasterswitch.com/how-...akers-and-amps
E: hold it, thats self powered? all you need is the signal (assuming line level input), you're good to go.
E: never mind reading fail on the self powered.
Remember the golden rule of statistics: A personal sample size of one is a sufficient basis upon which to draw universal conclusions.
Upload the computer to Dropbox and provide a link to it so others may download it to examine and give advice for repairs.
loon 3.2
(18 items)
i7-3770K
Asus P8Z77-V Pro
EVGA 980TI SC+
16Gb PNY ddr3 1866
PNY 1311 240Gb
1 TB Seagate
3 TB WD Blue
Optical Drive
DVD DVDRW+/-
EVGA SuperNova 750 G2
EKWB P280 kit
EK-VGA supremacy
Stryker M [hammered and drilled]
Operating System
Win X
LG 24MC57HQ-P
Keyboard
Ducky Zero [blues]
Mouse
corsair M65
Audio
SB Recon3D
Audio
Klipsch ProMedia 2.1
looniam is offline
post #6 of 27 (permalink) Old 12-10-2019, 12:27 PM
Graphics Junkie
UltraMega's Avatar
Rep: 38 (Unique: 34)
Why wouldn't it work? There is no technical difference between a center speaker and a side speaker. Generally a center speaker will have two speakers and a tweeter and side speakers usually have one speaker and a tweeter, but this is not a rule, just a generalization.
4K Rig
(7 items)
Intel 7700k @4.2ghz
Zotec 1080 Ti
16GB 3200mhz DDR4
250GB nvme + 500GB SSD + 4TB HDD
Samsung 4K 65 inch TV
Pixio PX276 27inch 144Hz 1ms 1440p
Audio
Sound Blaster z
UltraMega is offline
post #7 of 27 (permalink) Old 12-10-2019, 12:29 PM
Overclocking since 1998
briank's Avatar
Rep: 47 (Unique: 40)
General advice is that you want the midrange and high end of your L & R speakers to match your center speaker. Low end doesn't matter as much. Using the same model bookshelf speaker for L, C and R is actually an ideal setup. As voices move across the sound stage, it will sound more realistic with matching speakers. Turning the center on its side, while the L & R speakers are upright will cause a slight different in sound, but most will not notice a difference, mostly when sitting off center.
Ryzen 9 3950X
Gigabyte X570 Aorus Ultra
Powercolor 5700XT Red Devil
TridentZ B-die @ 3733CL16
Samsung 970 Pro
Adata XPG SX8200 Pro
Optical Drive
BD-RE
Seasonic Prime Titanium 750W
Noctua NH-D15
Fractal Define R5
Operating System
Windows 10 Home
LG 27GL83A-B 27" Nano-IPS
Keyboard
Corsair K68 Cherry Reds
Mouse
Razer Deathadder
7700K Delid @5.1GHz @1.4V
Asus Z270F Strix
Asus RX480 Strix @ 1400MHz
Corsair Vengance PC3200 2x8GB
Sandisk Ultra II 960GB
Samsung 970 Pro
2 x 3TB HDD
Optical Drive
LG BD-R
Seasonic Prime 750W Titanium
Noctua NH-D15
Fractal Define R5
Operating System
Windows 10 Home
Dell 27" 1080p
Mouse
Razer DeathAdder
briank is offline
post #8 of 27 (permalink) Old 12-10-2019, 12:36 PM
Jedi Mind Trick's Avatar
Rep: 90 (Unique: 72)
Any reason you want to do that?
I mean, as stated, you can do anything you want, buuuut if you don't have a bi-amped center channel on your AVR (as stated) you will run into issues with wiring where you either halve the resistance or double it; two 8ohm speakers wired together would either be a 4ohm load (not the worst, but I would not do this unless you know for a fact the speakers and your avr can handle it [most likely not] or 16ohms (probably not going to work, but if it did, it likely would not be loud enough).
You can put one sideways no problem, so I would just stick with that. If you want both there (for aesthetic purposes), I'd just leave it not hooked up. Sure, doubling the speaker could make it louder (at the same AVR level), but you can also just turn up the AVR more/raise the center channel level. If you are concerned about volume, I'd just look for a more sensitive speaker (increased sensitivity = less power to get a certain volume; most klipsches are pretty sensitive, so you can always test it to see if just one is loud enough).
Jedi Mind Trick is offline
post #9 of 27 (permalink) Old 12-10-2019, 12:37 PM
I can count to potato
Fluxmaven's Avatar
Rep: 36 (Unique: 13)
Yea a speaker is a speaker... You can use one as a center channel and you can turn them sideways.
If you want to run both and your receiver would need to be able to handle the Ohm load of running them. If they are each 8 Ohm and you wired them in series, it would present a 16 Ohm load to the receiver. In parallel, it would be a 4 Ohm load.
Darling
(20 items)
Sanic
(8 items)
Arctic
(12 items)
3900x
MSI x570 Ace
MSI Ventus OC RTX 2080
GTX 1080 FE
TridentZ B-die 3200cl14
WD Black SN750 with heatsink
WD Black SN750
Micron 5100 Pro (SATA m.2)
Optical Drive
LG Bluray drive
EVGA 1200 P2
Custom loop
Little Devil PC-V7
Omen 32
Huion Kamvas GT-220 v2 Graphics drawing display
Keyboard
Clueboard w/ 67g Zealios
Mouse
Glorious Model O
Mousepad
Tekmat AR-15 gun cleaning mat
Audio
JBL 306 MKII studio montors
Audio
Focusrite 2i4 Gen2
Audio
Monolith 10" THX sub
i7 6700
GA-Z270N-Gaming 5
GTX Titan Black
16GB Ripjaws 3200Mhz
WD Blue 3D m.2
Corsair AX760
Custom loop with external MO-RA3
InWin D-Frame Mini
i7 6700
MSI h270 tomahawk arctic
EVGA GTX 960 FTW 4GB
Basic 2133 16GB kit
WD Black
WD Gold
Toshiba x300
Patriot Scorch m.2
Optical Drive
LG Bluray drive
EVGA 1000 G2
Cryorig H7
Maingear Shift
Fluxmaven is offline
post #10 of 27 (permalink) Old 12-10-2019, 12:51 PM
Tiihokatti's Avatar
Rep: 262 (Unique: 212)
Actually there are issues with placing the speaker sideways, mainly involving the crossover between the tweeter and the woofer: http://www.itsharryclarke.com/blog/s...al-or-vertical
And this is exactly why all modern speakers have the tweeter and woofer in a vertical line instead of horizontal. And the typical center speakers have a weird woofer-tweeter-woofer setup to bypass the crossover issue of horizontally aligned speakers.
Some vintage speakers have the horizontal alignment on tweeter and woofer, and that is seen as a critical design flaw according to the modern audio science. A prime example of this is the Finnish Salora KS330 from 1976.
BUT! If you can make sure the speaker tweeter is directed towards the listener then there aren't any issues with using a normal vertically-designed speaker in horizontal alignment. It's just that if you move sideways (a wide sofa for example) the sound quality will most likely suffer as the frequency response gets wonky around the crossover.
Ppl should learn to add more info to their posts when they ask for help...
OCN Anime/Manga Club
[Official] OCN Headphones and Earphones Club
Tiihokatti is offline
