Bose 302 cab help - Overclock.net - An Overclocking Community
Bose 302 cab help
post #1 of 3 (permalink) Old 01-25-2010, 06:32 AM - Thread Starter
anadalite's Avatar
Rep: 21 (Unique: 21)
Calling all audiophiles
Ok so a bose 302 cab was dumped outside my house so i took it in to see what was what.
Its obviously done some time, the wood is all bowed and what not but hte electronics are still in there, not that its a lot of electronics but there u go.
there is one driver in there, clearly not original as it has a huge sound cable running out the front rather than use the bose electronic they literally were running it as a housing fro a speaker.
The speaker in it is a mutant nw 1250 sb and is working although all i have to test it is my mates marshall valvestate amp which we desoldered the speaker connections to.
My question is what on earth does this electronics do?
is the mutant any good
is there any point in me restoring this cab in any way?
also, on the back panel with the electrics, there is two "output" jacks wired to what look like a separate transformer for each, a white cylinder attached to each transformer and all of it wired into speaker cable that splits into the two speakers that should be there as well as heading through a hole out the back presumably for an input. what the hell does it do?? lol
Help me out please XD
"insert non political reference here"
anadalite is offline
post #2 of 3 (permalink) Old 01-26-2010, 05:03 PM
Linux Lobbyist
Chipp's Avatar
Rep: 589 (Unique: 377)
The electronics are called a "crossover". This is a circuit that directs different parts of an audio signal to the different speakers in the cabinet (low sounds to the woofers, high sounds to the tweeters, etc).
I've never heard of the speaker that is in it - judging by the name and lack of info on the web, you're better off replacing it.
Whether or not to restore them is up to you. A lot of the older wood Bose cabinets were quite attractive, so if your 302 is from an early series and the basic structure is in good shape it might be worth trying to find drivers.
Personally, I think I'd pass this one up. Too much effort for too little gain.
post-flame-small.gifKeep the standards high and the noise low. Do YOU have quality content?post-flame-small.gif
Can't get enough of Overclock.net? Keep up with us on Facebook!
For any time-sensitive issues, or anything pertaining to our business operations, email is a far better way to contact me than PM. Please remember you can contact any staff member via email to their username @overclocked.net.
Chipp is offline
post #3 of 3 (permalink) Old 01-27-2010, 01:46 AM - Thread Starter
anadalite's Avatar
yeah thats what I was thinking at first but it doesn't work like a normal crossover because there are only two speakers in the cabinet, and the electronics in it go to two output jacks on the back panel for extension cabinets I suppose. I suppose it could split the signal into frequency ranges for the outputs...
Im thinking the same about effort-cost-gain ratio, the speaker in it is a mutant nw1250sb its a car subwoofer!!! 200 rms 700 peak, it seems to be in good condition so may make a little bass box for it and throw it in my car
thanks for your input
Was going to rep you but you cant get any more rep!!
