Need a cheap tv subwoofer - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 02-07-2010, 04:02 AM - Thread Starter
goobergump's Avatar
Rep: 179 (Unique: 154)
What's up guys! I was able to get a nice lcd tv, but the speakers have no bass whatsoever. Can you guys recommend me a cheap subwoofer under 30$. It doesn't have to be loud and quality, I just need a slight boost to add to the overwhelming treble. I also heard that you can use computer speakers/subs with the tv also?
Thanks for the help
Only on OCN can a topic which is indeed searching for another topic about a wallpaper, include topics such as male "seed", heatsinks, extreme winter cooling (the canada open a window comment), trolling, sarcasm, and the philosophy that is internet text communications.
OCN FINAL FANTASY CLUB!!! OCN Scandinavian Club! I PROMOTE HARD DRIVE SHORT-STROKING
goobergump is offline
post #2 of 7 (permalink) Old 02-07-2010, 04:08 AM
Retired Staff
Farih's Avatar
Rep: 108 (Unique: 89)
i got 3 huge subs here really cheap. i go to second hand stores and if your lucky you might find an old 80's dynacord sub or stage accompany bins. i found 2 15inch 400W rms dynacord subs for 350 euro, but i also found 1 old stage accompany scoop loaded with a JBL 600W rms woofer for 50 euro hooray ! new things like this cost over 3500 euro each !
2nd PC >>> Intel I5-4690K @ 4,6ghz - 16GB 2133mhz - R9 290X
3rd PC >>> FX-6300 @ 4,5ghz - 8GB 1866mhz - GTX960
4th PC >>> Dual Core E5700 - 2GB 800mhz - HD6670
5th PC >>> AMD AM1 5350 - 4GB DDR3 - 3,1TB storage
Farih is offline
post #3 of 7 (permalink) Old 02-07-2010, 04:31 AM
Retired Staff
kingsnake2's Avatar
Rep: 128 (Unique: 113)
You can use comp speakers you just got to get a 3.5mm to component adapter. For that price you might check craigslist or something. Your just looking for someones old home theater one or something.
Awesome OCN Moments (Click to show)
...And so it began, the battle for earth between two noble creatures, whos command over the internetz is known throughout the globe, but who, who will conquer the other in their quest for middle earth? Could it be edward? The mightiest of the magicians capables of creating 16 ghz super duper uber machines of pron capabilities, or shall it be videofx, master of pure action in his pants. Only fate will decide and until then the balance of power on middle earth shall be as fragile as the shell of a precious egg.
Danny Elfman's old band Oingo Boingo
kingsnake2 is offline
post #4 of 7 (permalink) Old 02-07-2010, 10:30 PM - Thread Starter
goobergump's Avatar
Yeah I tried using my comp speakers, they fit but won't work. What adapter am I looking for? Is there a possibility you could give me a link because I have no idea. The speakers I tried to use are a 3.5mm plug, not usb, if that helps
post #5 of 7 (permalink) Old 02-08-2010, 07:15 AM
Retired Staff
kingsnake2's Avatar
http://www.cablesdirect.com/search_r...e/RCA%20Cables
post #6 of 7 (permalink) Old 02-08-2010, 08:47 PM - Thread Starter
goobergump's Avatar
Thanks man. I sort of love you for informing me that I need that. I mean not really, but I'm grateful. But seriously, I'd totally give you a man hug.
post #7 of 7 (permalink) Old 02-09-2010, 10:38 AM
Retired Staff
kingsnake2's Avatar
lol, k Those are pretty cheap and you can get em anywhere
