Difference between these earbuds? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 02-07-2011, 03:34 PM - Thread Starter
-Allen-'s Avatar
Rep: 127 (Unique: 111)
So I was browsing for new earbuds when I found these Panasonic Canal headphones for only $23! http://www.newegg.ca/Product/Product...82E16826181067 Thats less than half the price at futureshop!
I was about to buy them when I notice these with the same name: http://www.newegg.ca/Product/Product...82E16826181061
However, they were $4 cheaper??? When I compared the specs, the only difference was that one had a slightly longer cord.
Are they almost the same? Which one should I get?
-Allen- is offline
post #2 of 5 (permalink) Old 02-07-2011, 03:41 PM
48" Mousepad Extremist
AMW1011's Avatar
Rep: 70 (Unique: 67)
They both seem to use the same driver, based on the specifications, but the housing is noticeably different. For $4, I'd just take my chance with the more expensive ones.
That said, these are the absolute minimum you should buy and ignore everything else:
Celeron G4900
Asrock z370 Taichi
MSI GTX 980 Ti
Team Dark 3200 MHz CL14 16GB
2x Crucial MX500 512GB
EVGA 1300w G2
Corsair H80i
Lian Li PC-O11 Dynamic
Audio
Audio-GD NFB1.28 DAC -> Dragon Inspire IHA-1 amp -> ZMF Eikon
AMW1011 is offline
post #3 of 5 (permalink) Old 02-07-2011, 03:41 PM
MARK-20's Avatar
Rep: 37 (Unique: 36)
Judging by the specs they are the same! Just look different and one has a shorter cord
Id also recomend
MARK-20 is offline
post #4 of 5 (permalink) Old 02-07-2011, 03:41 PM
VROOM VROOM
thrasherht's Avatar
Rep: 380 (Unique: 328)
The cord on the more expensive set is longer.
thrasherht is offline
post #5 of 5 (permalink) Old 02-25-2011, 07:56 AM
Legionfalls's Avatar
Rep: 0
Originally Posted by -Allen-;12300473
So I was browsing for new earbuds when I found these Panasonic Canal headphones for only $23! eek.gifeek.gifeek.gifeek.gifhttp://www.newegg.ca/Product/Product.aspx?Item=N82E16826181067 Thats less than half the price at futureshop!
Well there's your problem! Always check online before going to Futureshop/Bestbuy/wherever us overcharged Canadians have to shop. I use Canada Computers/NCIX now instead of Tiger/Futureshop/Etc for this very reason.
I was about to buy them when I notice these with the same name: http://www.newegg.ca/Product/Product.aspx?Item=N82E16826181061
Hm, well I'm not sure which ones you should get but I've heard very good things about the Yuin PK2's if you really want great sound. However, they can be very pricey.
EDIT: welp, I didn't notice the thread was 2 weeks old, sorry biggrin.gif
Also, looks like one of them is out of stock anyway.
Legionfalls is offline
