Optical + RCA -> RCA - Overclock.net - An Overclocking Community
post #1 of 11 (permalink) Old 02-12-2011, 12:50 PM - Thread Starter
/Ben's Avatar
Rep: 65 (Unique: 61)
Ok, at the moment only my PlayStation 3 is connected to my crappy-single-RCA'd-stereo-system, lol. But I would also like to connect my Panasonic TX-P42G20 tv to it aswell - so I can listen to proper stereo - using some kind of device, perferably without switch or anything. Is this even possible?
Now, I've seen a device on eBay, but they're optical -> RCA. Not optical + RCA -> RCA.
Can sombody link me some kind of device which has optical + RCA -? RCA conversion?
Anything better? Perhaps a stereo system mod or something? I'd really love HD (display) porno sounds over my stereo speakers!
Thanks,
- Ben
/Ben is offline
post #2 of 11 (permalink) Old 02-12-2011, 01:37 PM
Retired Staff
Greensystemsgo's Avatar
Rep: 192 (Unique: 172)
so your stereo has one input, but you wish to put two devices to it? so you simply need a switch that allows the signal to only go one direction, the stereo though will not be able to decide which to play and will simply play both. go hit up a local electronics shop. here in the states id say radio shack.
Greensystemsgo is offline
post #3 of 11 (permalink) Old 02-12-2011, 03:35 PM - Thread Starter
/Ben's Avatar
Thanks. I'll guess I'll have to reach behind the TV everytime I want to change source...
/Ben is offline
post #4 of 11 (permalink) Old 02-12-2011, 04:14 PM
Retired Staff
No. What I'm saying is any devices plugged into this splitter will have access to the speakers at all times. so you'll need to make sure ones off or not playing. That's assuming their both rca. If your doing rca and optical then you might need some more controllers then its worth.
Sent from my DROID2
post #5 of 11 (permalink) Old 02-13-2011, 10:36 AM - Thread Starter
/Ben's Avatar
Sent from my DROID2
I don't think it works like that. I think the speakers just play what their source(s) gives them. Whether it's 1 or 2 sources.
/Ben is offline
post #6 of 11 (permalink) Old 02-13-2011, 02:47 PM
Retired Staff
Assuming you want to play two sources at once. Hence why you'd turn one off.
Sent from my DROID2
post #7 of 11 (permalink) Old 02-15-2011, 02:00 PM - Thread Starter
/Ben's Avatar
Sent from my DROID2
I won't have to turn any off at the moment. I've ordered the following components, this will be the setup:
TV -> optical cable ->
2-1 spitter -> optical cable -> digital to RCA converter with automatic switch-> stereo system
PS3 -> optical cable ->
/Ben is offline
post #8 of 11 (permalink) Old 02-18-2011, 01:29 PM
raidmaxGuy's Avatar
Rep: 89 (Unique: 76)
Uhhm hook the audio cable from the ps3 to your tv and hook some RCA cables to the "Audio/Video Out" connections on your tv, that way, when you do want to use your stereo all you have to do is turn it on
Proud furry since 2006
Disturbing the peace since 2010
All Bite, No Bark
(14 items)
Intel Core i7 7700k
GIGABYTE Aorus GA-Z270X-Gaming
EVGA GTX 1070 Hybrid Gaming
16 GB G-Skill DDR4-3000
Samsuning 960 Evo m.2 PCIe SSD
Coolermaster V750
Corsair H100
Corsair H440 Black/Red
Operating System
Windows 10 Professional x64
27" Samsung S27D590C Curved 1080p monitor
27" AOC I2757FH 1080p monitor
Keyboard
Coolermaster QuickFire TK
Mouse
Fallout 4 Steelseries Rival
Mouse
Hyena Agenda 18" mouse mat
Intel i7 6820HK
Nvidia GeForce 980m
Intel(R) HD Graphics 530
Hynix DDR4 2133
1TB HGST 7K1000 7200RPM
Dell 240W AC Adapter
Alienware 17 R3
Operating System
Windows 10 x64 Home Edition
IGZO-IPS TrueLife 400 nits UHD display
Mouse
Logitech G502 Proteus Core
Audio
Creative Sound Blaster Recon3Di
raidmaxGuy is offline
post #9 of 11 (permalink) Old 02-18-2011, 05:06 PM - Thread Starter
/Ben's Avatar
Lol, it actually works... I never realized my TV had analog in- and outputs. +REP!
/Ben is offline
post #10 of 11 (permalink) Old 02-18-2011, 05:13 PM
Retired Staff
NuclearCrap's Avatar
Rep: 305 (Unique: 199)
You shouldn't even need audio cables between your PS3 and your TV. The audio can be done via the HDMI cable. All you need is to hook up your speakers to the analog-out on your TV.
NuclearCrap is offline
